This thread is privately moderated by gryhrdoldfool, who may elect to delete unwanted replies.
Sep 20, 2017, 05:16 AM
Actual Theory of EDF's
As promised I have written out a brief description of how EDF's work. This description is only part of the whole story and I will endeavour at some later date add to it in such a way that it will benefit users. I have as yet, not worked out exactly all the consequences of a 'Real' world unit but so far I believe that the basic theory will remain both intact and applicable. Please read, I know many theories have been advanced on the pages of a good number of forums and for the reader this is just 'another' example. I do hope there will be some who read it through and digest.
ELECTRIC DUCTED FANS.
When I first looked at these little flight engines, like most, I thought they are somewhere between a propellor and an axial compressor stage, however I quickly realised they are something on their own. The nearest is a compressor blade that produces no increase in density, that is the compression should, ideally, be only a constant volume process. Having said that, like a propellor, they use the principle of forward procession - or pitch.
I will now lay down the configuration of this device, a duct that is parallel from entry to the end of the vanes, a 'concentrating nozzle'* and a fan with a 'solidity'** less than but close to one with a parallel platform continuing past the vanes. Finally this applies only to ducted fans that operate at less than 100m/s or 5000 watts/kilogram.
* ' Concentrating nozzle' : A nozzle that might appear to be converging but actually does not change the pressure of the flow or its velocity.
** 'Solidity' : where when viewed along the axial axis if the leading edge of one blade exactly matches the trailing edge of the blade preceeding it, it is a value of 1. Overlap would be greater than 1. A gap would be a value less than 1.
THE 'IDEAL' PROCESS.
I will start with an explanation of what I call the 'IDEAL' in other words if the unit was not constrained by the limits imposed by friction etc what would happen. We have to start by accepting two conditions that I will prove later are, in fact, a result of the power available and using a fan/duct combination.
THE VELOCITY, AT ANY GIVEN HEIGHT ON THE BLADE, THROUGH THE FAN DISC IS CONSTANT.
THE DENSITY OF THE AIR REMAINS CONSTANT.
I will refer to this velocity as 'Vf' and any subsequent reference to this will refer to the constant velocity through the fan or to IMPLY the power for 1kg mass I.E. (Vf^2)/2. Note Vf will be the axial value of the pitch.
The next stage is to set up four planes in the following order :
Pa1 a plane which sits sufficiently forward of the fan such that there is no effect from the fan.
Pf1 a plane which is positioned at the front of the fan at minimum presssure and a velocity of Vf.
Pf2 a plane which is positioned at the rear of the fan at maximum pressure and a velocity of Vf.
Pa2 a plane which sits sufficiently rear of the fan such that there is no effect from the fan.
Next start the fan and allow it to reach a stable condition.
The air starts to accelerate at some point between Pa1 and Pf1 moving towards the low pressure plane created by the mass of air moving from Pf1 to Pa2. It reaches Pf1 at a velocity that is equivilent to the pressure drop - Vf. The energy required for this acceleration is taken from the air. Consequently with no change in density it cools by the amount of energy required by this acceleration. THE TEMPERATURE AND PRESSURE ARE BELOW AMBIENT BY THE AMOUNT OF HEAT REQUIRED BY THE ACCELERATION. THE TOTAL ENERGY BALANCE HAS NOT CHANGED - ONLY CONVERTED FROM PRESSURE TO VELOCITY.
The air now enters the fan and the energy added although equivilent to the energy required for the acceleration is infact the extra energy required by a CONTINUOUS motion at Vf through the fan ( Note that at Pf1 the air has already reached velocity Vf). The result is that at Pf2 the velocity remains unchanged, the density remains unchanged but the temperature has risen by the energy added by the fan. This results in a pressure rise. There is a difference in pressure over the fan which we measure as thrust. THE TEMPERATURE AND PRESSURE ARE RETURNED TO AMBIENT. I initially struggled with how the energy was added by both the pressure side and the suction side of the blade, however I realised, after considerable thought, many sketches and calculations, that since the motion is considered constant both would add power more or less equally. So a single equation for power would reflect quite accurately the conversion of power.
Finally the air is returned to the atmosphere where its velocity energy is used to 'PULL' in the air entering the fan. This decays its velocity before plane Pa2.
EDITED addition : The velocity is converted back to heat and returns to the ambient. I added this because someone pointed out that to a new reader this was missing. I felt it was implicit, but I believe the critism was correct.
Here is an analogy which may help you to understand. Imagine a line of men stretching from plane Pa1 to Pa2 each holding the hand of both the man ahead and the man behind. You are the man at Pa1, your legs have no strength to help propell you forward, you are accelerated towards the fan by the man ahead pulling you, as you enter the fan you find your legs are gaining strength but you still can't use them to help you move forward, as you travel towards the exit of the fan you find this extra strength increases to a maximum at the exit, as you pass out of the fan you find that you can use your legs to propell you forward, you need this extra push because the man in front is pulling with less force and those behind are exerting more force on you, as you pass away from the fan your legs have less and less strength and you gradually loose the ability to pull the man behind you, finally you find yourself at Pa2 suspended exactly the same as you were at Pa1.
In other words the energy added to the exit stream is required to make the process 'CONTINUOUS' and cannot be used for anything else.
EDITED addition : I wrote the above to elicit some form of re-action, it is based on some work I did in the late 90's and early 2000's and is almost certainly an incorrect interpretation. I didn't receive the replies I'd hoped for and consequently since I will leave this still available on my blog, feel that it is important to add what is the most likely explanation.
PLEASE NOTE that this will make no difference to the power or thrust calculations and is just a difference in how the power is converted. The general principle remains exactly the same. I will ammend the analogy to indicate the difference.
Here is an analogy which may help you to understand. Imagine a line of men stretching from plane Pa1 to Pf2 each holding the hand of both the man ahead and the man behind. Those between Pf2 and Pa2 are not holding each others hands.You are the man at Pa1, you are accelerated towards the fan by the man ahead pulling you, as you enter the fan you find that strong forces envelope you body pushing towards the exit of the fan, you pull the man behind with increased strength, reaching its maximum as you exit the fan. As the man ahead exits the fan he lets go of your hand. You pass out of the fan letting go of the man behind you. As you exit you are moving with a slightly higher velocity than when you entered. You move away from the fan gradually going slower and slower. Finally you find yourself at Pa2 suspended exactly the same as you were at Pa1.
In other words the energy added to the stream through the fan makes the process 'CONTINUOUS'.
It is a beautiful example of a device obeying Newtons Laws, Impulse and Thermodynamics. However when you analyse it in a little more detail you realise it produces thrust with NO POWER. How can that be? - as it is its just moving air around, ALL the fan power is used up just moving the air. The Thrust? This is a reaction force, much the same as leaning up against a wall, the wall exerts a reaction force that stops you from falling over but cannot instigate any motion. (It doesn't push you the other way and make you fall away from the wall and if it did you'd really give it a telling off for contravening Newtons laws and impulse.) This reaction or 'thrust' is the necessary reaction to MAINTAIN the operation of the unit.
So far so good, (as a man jumping from a ten story building says as he passes the fourth floor.). We now need to examine what happens when the fan is moving forward at Vf. Take care to remember that it is the Fan Unit that is moving forward and NOT the air moving backwards. O.K. so now the air is stationary and the fan has a forward velocity of Vf. From the point of view of the fan nothing has changed, air is arriving at Pf1 at the same velocity as when it was stationary, the only difference is that the pressure and temperature of the air is ambient. Why ? Well, there doesn't need to be any reduction in pressure to accelerate the air - after all its just stationary, sitting around waiting for something to happen. The fan does its job and adds exactly the same amount of energy to the air as when it was stationary, it would appear that this would increase its temperature and consequently pressure to a level that raises them to above ambient by Vf. Hmmm in a sense it does but how does it convert this change into power for forward motion.
That dogged me for ages, I knew I was on the right track but how is this power converted into forward motion of the fan. Gradually I realised that in this 'IDEAL' state with no friction and therefore drag, (hard bit!) because of a change in direction of the resultant force applied by the motor to the fan, the power was converted almost instantly to forward motion. With no friction the blades are literaly sliding along a tube of air in a spiral motion exactly following the path of the pitch. Remember in this model the air is incompressible and acts like a fluid. Of course in the real thing we could never reach this stage, there must be some 'slip'.
Now imagine whats happening from the point of view of the fan. Create a tube of air Vf long but only as it is seen by the fan. Not the entry or exit. This tube is stationary and the blades of the fan are sliding along the spiral that is the pitch much like a propeller. Its very difficult to get your head round because we all instinctively imagine a reactive force but there isn't one because we've reached a limit where there is no force/thrust only power, all acceleration has ceased. It's much easier to comprehend from a point just before the limit, when we still have a little thrust and therefore reaction in the air, that is, where this tube still has some motion with relationship to the ambient reference frame and the fan has not yet reached Vf. Now continue this process until your tube of air is moving with a velocity of Vf and the fan has ceased motion. If you can do this then it becomes very obvious that from the fans perspective very little changes, the reaction either powers the air or the forward motion and has very little implications for the fan.
Before I continue, I will give a little background of how I arrived at this theory. The first thing I needed to know was how the power is added, I will start with a brief description of Euler's turbine equation. This tells us that there is a maximum amount of power that can be added or absorbed from the fluid. I will be working 'per kilogram' so we don't need mass in the equations.
At at a radius 'R' on the fan calculate the velocity in metres per second. We will call this 'U'. I don't have the symbol for pi so I'm afraid it will be pi!
U = 2 * pi * R * Revolutions per Second. The norm these days seems to 'D' or diameter so U = pi*D*Rps
Example. Hub diameter of a fan is 35mm ( 0.035m) and it rotates at 24,000 RPMinute or 400 RPSecond
U = 2 * 3.14159 * 0.0175 * 400 = 44m/s ( Rounded up )
Eulers turbine equation tells us that the MAXIMUM amount of power that can be added/absorbed from the fluid is -
Max power in watts = U^2 ( Remember U is in metres per second so watts). per kilogram
So now we have the maximum amount of power that our little fan can add to the air flow - but in what way? Although I am 99.9999% certain it will be in the form of an acceleration I.E. SQR ( 2 * U ^2 ) I thought I'd better check, I found a number of details concerning construction ,(on the web), and also looked at drawings and actual fans and although not all, a large number have an angle between the aerofoil root section and the axial axis of about 35 degrees and this confirmed my belief. How? Well there is a simple geometric relationship between pitch angle and U. Remember that we used Vf, well this is how I arrived at this value in an 'Ideal' world. The optimum angle is actually 35.264 degrees.
Vf = U / tan(Pitch Angle) Vf = U / 0.7071
I could just do this mathematically but for many an example is easier - so we will use our 44m/s
Vf= 44 / tan(35.264)
Vf= 44 / 0.7071 = 62.226m/s
if the fan is an acceleration machine then (Vf^2)/2 = U^2
( 62.226^2 ) / 2 = 44^2 or 1936 = 1936 so they are equal.
The next point to consider, is the constant velocity within the fan, a difficult idea for many to get their head around, but look at these points :
a). The available 'Area Effective' for a given fan will be about 90% of the swept area, there are tip losses, and blade thickness losses not quite enough for the 90%. However in the real engine we would, I believe, have a slightly reduced velocity through the fan, but with an increased area, some acceleration takes place in the form of 'swirl'* which is removed by the stator vanes resulting in an increased axial velocity and therefore appears as a reduction in effective area.
b). Constant cross sectional area from the front of the fan to the end of the vanes.
c). Empirically (by experiment) arrived at nozzles with an exit cross sectional area about 90% of the swept area.
d). Incompresible flow.
e). Temperature variations are so small that variation due to expansion would be less than 1-2%
These points lead to the fact that any other explanation is almost impossible, and the clincher is the 90% cross sectional area of the nozzles. Why? well simply, the entry effective area of the fan, is the almost the same as the nozzle exit area, the flow is incompressible and since the mass flow must be the same, the velocity cannot be much different. Even at the upper limit we could not expect the entry to the fan to be more than about 95% of the swept area which would indicate a maximum variation in velocity of less than 6%.
* Swirl : A rotational movement of the air, when viewed along the axial axis, and is due to the velocity through the fan being less than the actual physical displacement of the pitch and therefore a radial acceleration takes place.
Back to the 'IDEAL' cycle. Let us see what happens as the unit moves from stationary to a forward velocity at some fraction of Vf - which I will define as Vmotion or Vm for short. A proportion of the thrust and power is liberated from 'just' moving the air and is available for flight. The velocity is constant but its RELATIVE VELOCITY is now reduced by Vm. That is, when you examine the air stream flowing through the fan unit, its velocity relative to the exterior has reduced by Vm. From the fans point of view it only has to provide the power to accelerate the air from Vm to Vf. The available power is Vf, so we have liberated Vm for propulsion. So the applied vector swings a little so that we have a force that increases the pressure/temperature of the air to provide the power for a Continuous process at this reduced velocity and a force and power that is used for flight, both acting through the fan.
This takes the form: Flight power = (Vf^2-(Vf-Vm)^2) / 2
= (Vf^2-vf^2+2VfVm-Vm^2)/2
= (2VfVm-Vm^2)/2 watts per kilogram
(For those of you who understand its a little more complicated, the velocity Vf varies at different section heights and the maths for this is much more complex requiring integration, and even then exact velocities do not follow a fixed rule but depend on the specific unit and consequently the function that will represent the velocities at a given section height is individual, so for normal purposes if you know the 'mean' velocity the difference is minimal - sufficiently accurate for most applications.)
I'm not a great user of examples but I will now give an example of a unit that has a mean efflux velocity of 60m/s with a mass flow of 0.25Kg moving through the air at 25m/s
For where it is applicable, I apologise for a lack of a dot above the 'm' (mass flow).
Vf=60 Vm=25 m=0.25 Flight power (Fp) = ((2VfVm-Vm^2)/2 )*m = ((2*60*25)-25^2)/2)*.25 = ((3000-625)/2)*m =1187.5*.25 = 296.88 watts
Finally the available thrust. We can only obtain a reaction to the air exiting the fan so the thrust is the reaction to this air flow. The relative velocity of the air times the mass flow per second. When I first looked at this I thought it might be different in the respect that the mass flow would be the amount of air passing a plane relative to ambient refence plane and therefore would reduce mass flow in the form ((Vf-Vm)/Vf)*m but the mass flow relative to the fan is still at Vf and therefore this is relative thrust LEFT after the power for flight is extracted. Thus mass flow is still the same. There is a further, more mathematical check, and that is to calculate the 'thrust used' for the power equation and this bears out the following equation.
Thrust = (Vf-Vm)*m = ( 60 - 25 ) * 0.25 = 35 * 0.25 = 8.75N
The following chart is for a mass flow of 1kg, read the values at a particular velocity and multiply by the actual mass flow.
NOTE : The intersection of the thrust and power curve has no bearing on flght speed, I could have altered the scale and thus moved the intersection point.
What I will now do is examine the implications of this theory when applied to the real world. I have not as yet worked out exactly the effect that friction etc has on this model but am fairly sure it only creates a shift, which will actually aid its use as a flight engine although causing an increase in power losses. That is to say that once the velocity is obtained with a 'concentrating only' nozzle. Then from cross sectional exit area or 'Area Effective' of the fan, calculate the mass flow and produce a power/thrust diagram as above. For these calculations we can ignore the actual shaft power required to produce this flow.
1). Take off, poor initial acceleration, although since these units are to a degree load sensitive there will be a reduction in air flow and and an increase in pressure produced by the fan, releasing extra power for flight. This will be noticable as a reduction in R.P.M. However this reduction will be dependant on how well the electric motor is matched to the fan, a well matched unit will only produce a small almost un-noticiable reduction. Aircraft have a higher drag during initial acceleration due to the increased angle of attack required by the lift surfaces which increases the power required. After reaching a flight speed where this drag starts reducing this effect will decline.
2). Level flight duration for a particular throttle setting will be similar to a static run at the same throttle setting. I say similar since the unit has some load sensitivity and the time can vary by a small amount both longer and shorter.
3). Probably the most important for the modeller is the limit velocity. Most EDF's are built to the 50/75 ratio, that is the hub is 50% of the fan overall diameter which results in the swept area being 75% of the full area of the fan. Additionally to reduce intake losses there is a radius entry to the duct further increasing the air collection diameter. This all helps to obtain maximum air flow in the static or low speed situations, however consider the point at which the incoming volume of air exceeds the amount that can flow through the fan. An example is much easier to follow.
An edf unit that has an O.D. of 70mm and a hub of 35mm with a 1.5mm radiused lip and a Vf of 44m/s
The volume flow through the fan at 100% of the swept area (infact it's less than 100%!) . Where 'R' is radius o.d. of the fan
1) R^2 * pi * Vf * 0.75 = .035^2 * 3.14159 * 44 * 0.75 = 0.127 m^3
The total Air entry area. R1 is R+lip = 0.0365
2) R1^2 * pi *Vf = 0.0365^2 * pi * 44 = 0.184m^3
Now divide 1 by 2 and multiply by Vf to get maximum airspeed where the air supply equals the air moved by the fan.
(0.127 / 0.184) * 44 = 30.27 m/s
That is not all, at this velocity we have no space for the acceleration of the air to 44m/s. I don't have the necessary data to specifically say at what velocity below this that drag starts to increase dramatically, but suggest its at least 10% lower than this velocity giving a maximum air speed of about 27m/s or 60% of Vf. Its a very difficult problem to resolve, since reduction in intake area will reduce the thrust and power output when at low speed and static, so making initial acceleration to flight speed even more precarius. The duct form for fans needs a considerable amount of thought and experiment and that is for the future.
Finally I could say much more about how this theory affects development of the blade forms, how the upper limit on flight speed can be improved and many many more things concerning motor selection etc. However there is sufficient here for a good start and quite honestly I could write a small book on all of the aspects of a complete system. I will sign off for now.
Andy Slade 19/9/2017
Sep 20, 2017, 10:17 AM
Waste Nothing
RickC_RCAV8R's Avatar
Andy :
If I am digesting this awesome text correctly , it would seem that the general effective use for DF units in RC is basically a waste of time and expense . As you note in the acceleration part of the text , a model DF unit would only have the capability to generate a minimal amount of accelerated airflow once the model was already in a brisk forward flight . Not to add any appreciable amount of 'thrust' , in other words . This is borne out by the fact that model DFs are poor for initial acceleration from a stand still . At best , the model's DFs would only provide a mild trust boost at a moderate to high velocity . This would also verify that the controllable throttle range of a model DF is very narrow and in the upper percentile range between 70 % and 100% . They are basically full ON or full OFF in operation . (not effective as a throttleable power plant)
Does not the overall geometry of the DF thrust tube come into play ? A tapering of its length from 100% at the fan down to around 71% at the exit seems to be the ideal for preoducing the necessary pressure changes seen as a Newtonian 'trade off' as thrust .
What about the issue of models operating with low Reynold's Numbers ?
I wrap my old brain around this stuff on occasion just for kix . Electronix engineering is easier to handle mate . Lovely article . Cheers
Sep 20, 2017, 10:53 AM
eagle60's Avatar
Impressive n useful to understand principles, but going to real world many things could be different : take the prop system (I stick on props because are what I use) when you are in flight and the plane has speed the motor absorption decreases (6/8 to even 20 % in some cases); this is due to the fact that the system is rigid and preconfigured, i.e. the prop does not have variable pitch and is selected for the speed range that will be used, the electric motor has a fixed max rpm (even without prop) so when plane does not have speed the power required is higher and this is obtained with an higher "sliding" of the magnetic fields inside the motor (decreasing also efficiency and rpm); when the plane gains speed the prop "easy up" and the motor gains rpm reducing absorption. I do not know ducted fans but I am afraid something similar could happen.
Sep 20, 2017, 11:08 AM
eagle60's Avatar
For RickC_RCAV8R
I just read your comment ( you posted it while I was writing mine) : do not forget that Andy was
treating an ideal situation, but ideality is not reality : given the fact that a lot of power is wasted for the system poor efficiency (as discussed in the previous post to get same thrust of a prop with a fan you must spend 2/2.5 the power) you will have thrust at any throttle setting, maybe not so prompt as with a prop, but still a thrust.
Then in the reality your fan will work in a position between the 2 discussed, i.e. part of the power is used for the air flow (acceleration) and part for the thrust.
Sep 21, 2017, 05:07 AM
Hi, thank you both for your comments. What I am finding when I examine this from the perspective of a 'real' unit is that most of the losses are 'overhead' in other words they are losses that enable this process to occur. The only losses that do affect this process are the inlet losses and the eflux losses, resulting in a lowering of the entry to the fan velocity, a small increase in velocity across the fan and a degree of swirl, this is because the fan has to add extra power to the eflux to overcome these losses. This is why we see the 90% cross sectional area at the nozzle. What I have found is that at entry the effective area of the fan is higher around 95/96%. So the mass flow is constant. Additionally I have found that this is a self regulating condition and any fan of this type will move as close to the 'IDEAL' as the these losses allow. The implication of this is, like all airflow devices, finish is the most important aspect - the better the finish the closer the unit moves towards the 'IDEAL'. If you therefore measure the efflux velocity and know the exit area then calculating the power and thrust chart remains the same whether 'IDEAL' or 'REAL'. Unfortunately at the moment we are moving, so my wife doesn't appreciate me sitting in front of a computer or sitting with a pencil and pad ! When I have the time I will continue with my analysis and update my blog as and when I can. Just bashed this out quickly so sorry for the poor way it is written.
Sorry rick not answering all your points, the optimum taper angle as is usual for a nozzle is about an inclusive angle of 11 degrees, I have considered what would happen if the nozzle was truly convergent and add pressure into the system, in short you may be right but remember the energy has to come from somewhere and that somewhere is the fan, and would consequently have an impact on the initial mass flow through the fan, I suspect that you would get a trade off in power which would further reduce the efficiency of the system. In other words your better off having a slightly larger unit and employing the extra power to increase velocity/mass flow in a standard format.
As for Reynolds number, yes crucial in the design of the blades and requires a blade length to give a value somewhere between 100,000 to 120,000 any less and the efficiency drops further - higher if you can but extremely difficult at these sizes.
Sep 22, 2017, 05:58 AM
Sorry about yesterday, I didn't have much time and just scanned the replies. I made a very muddled entry and will now look properly at you comments and try to answer as well as I can. The Reynolds numbers still stand but it is not always possible to reach these values with a small fan - its not Vf that you use its the relative velocity along the blade chord, which of course, is considerably higher than Vf . However everything else was written with out proper reference to your comments. You were refering, in the case of nozzles to reduce the outlet diameter to 70.71% (1/ root 2 ). What you are sugesting is a doubling of the efflux velocity which would be 0.9 * 0.7071 or about 64% cross sectional area and require four times the power. The problem would be that a fan and its stators are not designed for this kind of pressure rise, the pressure would be reflected back to the fan, flow would be drastically reduced, a large amount of swirl produced and the net result would be a break down of flow. It has become a compressor and not a fan. However it is not as fanciful as it first looks, it may be possible to create a single stage compressor to achieve exactly what you propose, it would be horribly innefficient, probably 50% relative to shaft power and even with the most powerful brushless motors available today, the mass flow would be quite small. There would be a considerable number of problems to overcome, size of blades, low Reynolds number, duct shape and many more too numerous to write here. But, look at it this way, early EDF's used brushed motors and had a through efficiency of about 36% and this unit would have a final through efficiency of around 35%, not so different. The disadvantage would be that the thrust would be relatively small but with a high power output. The main advantage would be that it is a true impulse flight engine and consequently have power available from the start ( in exactly the same way as a gas turbine ). Provided you could design a suitable intake, it could fly a small aircraft at high speed. Just a last point, in practice you would not use a convergent nozzle to produce the pressure rise this would be achieved over the compressor and its stators. Its a jet engine without the combustion chamber.
The pressure rise for our 60m/s unit would be, allowing for a 60m/s flow rate, thus 75% of our energy converted to pressure ( roughly 5400 watts/Kg). Calculated adiabatically 1.067 : 1 Quite possible at these sizes. The 60m/s adds a component to our pressure but I have not included it here because I would hope to maintain this velocity through the unit up to the point of acceleration.
A probable eflux velocity in excess of 110m/s, difficult to calculate since I am assuming a total temperature rise of 7 degrees at 20C ( 293A) ( converting all the power to heat), using an efficiency of 85%,for the acceleration, which is low and I would expect a little more. A thrust of 110N/KG, sounds a lot but our actual mass flow would be nearer 0.1/0.15 Kg so 11-16N. You might even scrape an extra metre or so from the waste heat of the motor (joking really).
Point I am making is don't stop thinking or dreaming, everything is just a problem waiting to be solved. There's always a solution, you might not like it, but it's there!
Poll Could yesterday's ruling by the FAA actually help the hobby? RyanNX211 Balsa Builders 53 Jan 07, 2016 03:15 PM
Poll Could yesterday's ruling by the FAA actually help the hobby? RyanNX211 Vintage & Old-Timer Designs 8 Dec 20, 2015 09:58 AM
Discussion New Actual Science Poking Holes In Climate Change-Global Warming Theory kenpoprofessor Life, The Universe, and Politics 9 Oct 05, 2015 10:28 AM
Anyone actually flown EDF-75(s) yet? Hawker Electric Ducted Fan Jet Talk 0 Dec 07, 2002 01:08 AM
