LED lights for FPV 210mm racing quad - RC Groups
Sep 19, 2017, 11:29 AM
I must apologize if this question has already been posted in an earlier thread, but I have been searching the web for (updated) solid info on this matter without any luck.
I have a 210mm racing quad with an IR-filtered lens. I want to be able to easily connect and disconnect LED-lights, hopefully through the balance connector of the battery, which will enable flying in low light conditions.
Does anyone have any particular products (hopefully cheap from Banggood, eBay or similar) which can fit my needs? That is, LED-lights which are lightweight and bright enough to make flying FPV at night at moderate speeds possible. I can solder and assemble myself if that makes things cheaper/more available.
Sep 21, 2017, 05:54 AM
Noone interested in this subject? I have found this, could it work? I'm planning to make a balance plug contact on it, so that I can connect it directly to my 4S battery (but only using three of the cells). It has high power and small footprint, so I would guess that the weight is low compared to using many smaller LEDs.
Sep 26, 2017, 04:08 PM
Quad Erat Demonstrandum
scousethief's Avatar
For night flying you want 12v Led's , the easiest way to go about this is to buy one of the LED strips such as these ( or similar )
https://www.banggood.com/45CM-1210-4...l?rmmds=search
and then solder the batt lead to a balance lead connector
or these
https://www.banggood.com/LED-3-SMD-5...l?rmmds=search
New Product FPV Race Track Equipment with LED Lights TheDroneCircuit FPV Racing 11 Nov 24, 2016 04:19 PM
Discussion High-light LED for FPV Racer Bigbond FPV Racing 0 Nov 06, 2016 09:08 AM
Discussion If you had to build another 210mm race quad, what frame would you buy? spllouder FPV Racing 45 Oct 13, 2016 07:27 AM
Discussion LED light for Quad quadlover123 Beginner Multirotor Drones 10 Sep 23, 2015 03:48 PM
