Sep 17, 2017, 04:23 PM
does Tri-flight support D-shot
just replaced an old kk2 with an RCE-F3FC and Aikon 30a esc's . copter flies better then ever. however it will not run D-shot and from what info I can gather it seems Tri-flight does not support this yet. is this true or do I need to do some more research.
Sep 18, 2017, 06:36 AM
here's the answer to my question , may help someone else
RCExplorer - David (admin@rcexplorer.se) wrote:
Unfortunately the F3FC was designed before D-shot came around. D-shot requires hardware DMA ports, which the F3FC uses for other things. The 48pin F3 chip only has a few DMA enabled pins unfortunately. You may be able to, by heavily modifying the board to get it to work. But I have not tried it.
So you're stuck with Multishot and oneshot.
If it's speed you're after Multishot is slightly faster than D-shot600.
D-shot has other advantages though being a digital packet.
/David
Discussion SHOTS FIRED at Trump Rally… Police and Supporters Attacked kenpoprofessor Life, The Universe, and Politics 16 May 25, 2016 05:55 PM
Discussion BLACK TRUMP Supporter SHOT and KILLED Leaving Chicago Trump Rally kenpoprofessor Life, The Universe, and Politics 65 Mar 16, 2016 12:56 PM
Discussion Does the Guardian Support Thrust Vectoring? jamieFL Eagle Tree Systems 0 Feb 08, 2016 01:06 PM
Discussion Does Multiwii/w mgpr support OSD? DroneLTU Beginner Multirotor Drones 1 Oct 25, 2015 08:54 AM
Discussion Does the "CC3D Copter Control Rev 3" Board Support Voltage & Amp Sensors? Pyr8 Multirotor Drone Electronics 5 Sep 25, 2015 01:31 AM
