Castle Phoenix Edge 80hv with Hacker motor - RC Groups
Sep 17, 2017, 12:31 PM
kc8qpu's Avatar
I fly with a club member that has a Wind 110 that flies on 8s. He is using the Castle Phoenix 80 he with a hacker motor. A while back we programmed brake in his ESC to slow down the plane for landings and down lines. It worked. However now when he throttled back up the motor makes a clunk sound. Anyone else have any other problems like this.
Sep 17, 2017, 02:22 PM
Yes. Check to see whether or not the logging function is turned on. If it is, turn it off and your problem will disappear. I had this exact same problem with the exact same setup on a WindS110. It took me a long time to solve this, but as it turns out, logging slows the esc processing just enough to cause the motor to hick-up.
Ken
Sep 17, 2017, 02:40 PM
Zeeb's Avatar
Also, make sure that the Hacker motor he's using is not a 28 pole. If it is a 28 pole motor, the Castle ESC will not play nicely with that motor.
Sep 20, 2017, 09:22 AM
Another thing to look at is the amount of brake. For a 10s system 30% is about the maximum while smaller set ups can use a little more. During braking the ESC can't see the motors poles and it struggles to sync.
Sep 20, 2017, 05:37 PM
kc8qpu's Avatar
Thanks guys. Ill trying turning off the logging. Anthony we keep increasing the brake and it wasn't until 70% until it started braking at all.
Sep 25, 2017, 12:16 PM
What are your Brake Delay and Brake Ramp settings? Brake delay should be immediate and brake ramp should be medium. Brake strength <30% for 10s. Any delay will make the brake feel ineffective. A ramp higher than medium decelerates the motor too quickly and can cause damage. I have verified this!
Discussion Hacker 28 pole and Castle Edge 100 - low power KenCz Power Systems 27 Apr 26, 2017 01:41 PM
Discussion Hacker A60-6XS V2 - Castle Edge 100- low power KenCz Power Systems 6 Apr 20, 2017 08:50 AM
Discussion Need help with Phoenix Edge 540 65in (Motor/ESC) jobinseattle Electric Plane Talk 1 Aug 28, 2016 06:09 PM
Help! Castle phoenix edge lite 75 esc with only 1 capacitor Paleomanjim Power Systems 1 Aug 20, 2016 05:22 PM
Discussion Hacker Q80-8M with Castle Edge HV160? jseese Power Systems 2 Oct 26, 2015 02:37 PM
