PowerLab 6 and Hybrid Chemistry Cells - RC Groups
Sep 15, 2017, 07:51 PM
Help!
I am new to using the PowerLab6 and I can't quite seem to figure out how to do discharge tests with hybrid chemistry cells. I am only doing single cell testing and I want to do it on the Samsung INR18650-25R5, LG 18650HG2, LG ICR18650HE4, Sony US18650VTC5, and Sanyo UR18650-NSX cells. I can't seem to find anywhere if this is even possible, and if it is, I would greatly appreciate any instructions on how I would go about doing this. Thanks!
Sep 18, 2017, 01:24 PM
Sindland MC SAA
Howard Matos's Avatar
Good Day,
An 18650 cell is a Lithium Ion cell and will charge the same as a Lithium Polymer cell which is supported in your charger.
Howard
Oct 24, 2017, 03:45 PM
Except its not compatible other than top voltage. Since they discharge to 2.5V and charge from 2.5v and so it wont allow it.
And it also wont allow charging of packs without balance leads, and many have non. Require non, and have built in balance and under/over voltage protection.
Other than 2S max, and then it has a 15 min CV limit which is around 1.5 hours short!
So not really...
Help! PowerLab 8 V2 - Cell voltage monitoring issue haha0606 FMA Direct 7 Jan 11, 2017 08:57 PM
Question PowerLab 8 V2 'Cells No Add Up....' After install 3.33 TankPilot Batteries and Chargers 5 Jan 12, 2016 07:48 PM
Question Setup PowerLab 6 and 8 to charge 4.35 cells? darkfa8 Batteries and Chargers 6 Jun 24, 2015 10:43 AM
Discussion Wrong Cell Count with Powerlab 6 sdobbie FMA Direct 12 Sep 13, 2014 12:09 PM
Help! powerlab 6 does not charge 3 cells batteries dbrosh FMA Direct 15 Apr 18, 2014 11:48 AM
