This thread is privately moderated by myrcmodel, who may elect to delete unwanted replies.
Sep 15, 2017, 04:36 AM
myrcmodel's Avatar
Tarot Gimbal for GoPro 5
TAROT GoPro 3DⅣ Metal Brushless Gimbal is specially designed for GoPro 5 on the basis of Tarot T-3D gimbal.It integrated all the high end technology of Tarot gimbal, it adopts CNC integral structure design,which brings the light weight gimbal and stable performance. With unique internal wiring design, built-in IMU gimbal control module, specialized servo drive module, this gimbal is able to support Pan Follow (PF) mode and First Person View (FPV) mode.This gimbal can work independently.
Main Features:
Specially designed for GoPro 5
Easy to install
High precision driving algorithm to control the motor precisely
Gimbal rotation speed is controllable
Gimbal support PF mode and FPV mode
Specifications:
Supported Camera:GOPRO Hero 5
Input Power: 3S-6S Li (11V-26V)
Working Current: 30mA(@25V)/50mA(@12V)
Stall Current: 350mA(@25V)/700mA(@12V)
Attitude Control Accuracy: +-0.02°
Max Controllable Rotation Speed:
TILT: +-200 deg/s
ROLL: +-200 deg/s
PAN: +-200 deg/s
Controllable Rotation Range:
TILT: -135°to +45°
ROLL: +-48°
PAN: +-330°
Support S-Bus/PPM/DSM receiver
Working Environment: -20℃~+50℃
Weight: 153g
Dimensions : 60mm*75mm*100mm
Assistant Software Supporting Platform: Windows XP; Windows VISTA; Windows 7;Windows 8(32 or 64 bit)
(Linked)
(Linked)
Oct 26, 2017, 08:02 AM
teryn1's Avatar
GoPro 6?
Nov 09, 2017, 08:47 PM
myrcmodel's Avatar
Originally Posted by teryn1
GoPro 6?
No, specially designed for GOPRO 5
Apr 05, 2018, 03:26 AM
GoPro6
There is no difference between the hero 5 and the Hero 6 size wise, so the hero 6 will fit the gimbal, as far the internal workings of the two different cameras are concerned I cant say, as I have only ever owned a Hero 6, but as I have just purchased this gimbal, I'm seriously hoping it is going to work. As far as i am aware both the hero 5, 6 and indeed the new Hero has the same mini HDMI output so you will not be able to use the usb cable built into the gimbal (unless there is some sort of converter cable available). I intend on using mine as an FPV as well as for recording, so I have also purchased a HDMI to AV dongle. Ijust need to work out how it all goes together.
May 27, 2018, 12:38 PM
Any more experiences with this gimbal, recommended?
Nov 13, 2019, 08:57 PM
Hi.
I am looking for a way to configure this gimbal upside down. Do you know any way to do this?
thanks!
Discussion TAROT GOPRO 5 3DⅣ Metal Brushless Gimbal for GoPro 5 TL3T05 myrcmodel Multirotor Drone Talk 11 Oct 20, 2018 02:39 AM
Question tarot 2d brushless gimbal for gopro hero 3 for sale (pre built) FlyingMonkeyRc Multirotor Drone Talk 0 Jan 03, 2014 08:15 PM
Discussion tarot gimbal for gopro. zhangdanchen Multirotor Drone Talk 57 Jul 28, 2013 12:26 AM
Discussion tarot 2aix motor gimbal for gopro. mike662520 Multirotor Drone Talk 0 Mar 13, 2013 07:00 AM
