Sep 13, 2017, 10:56 PM
New Product
AKK is bringing forth new items all the time
AKK it is truly one of the best on the 5.8mhz market right now and AKK is well known for the quick speed of new arrivals.
AKK Tech is committed to providing the best and the most affordable FPV gears for the majority of consumers in the FPV market .
We are looking for advices of new products which are suitable for AKK, or improvement advices of old products. As long as advices adopted, free samples or further rewards will be sent.
Pls get an affiliate link to promote AKK on your website/blog/ social media( facebook,twitter etc,)/forums to receive a high commission on every order you refer successfully. Just need to register at akktek.com. affiliate project.Please follow akktek facebook channel, join the activities to win prizes: https://www.facebook.com/akktekfpv/
Posts on this thread : #230, #260, #300, #330 , #360, #400,#600,#700,#800,#900,#1000, #1300,#1400,#1600,#1800,#2000,#2200 will get one new product to test. (the other akk fans will be contacted by akk team at random). Recommend akk, let more FPV guys know this affordable brand you will be found by akk team.
pls visit akk tech official website, you will find what's called incredible prices: akktek.com
AKK VTX Parameter Guide this image has been resized, click the black bar of this picture to view the bigger image.
New product details:
AKK A3 aio camera released on July 11, 2017:
AIO FPV camera+transmitter+atnenna all 3 functions in one limit size and weight. weight:4.7g
Output power 25mW/50mW/200mW Switchable, Compatible with 5.8GHz googles and monitor.
Switchable Power AIO Camera is a must-have for both indoor and outdoor flying.
Nickel-plated 4 Leaf Antenna , RHCP circular polarization clover to Antirust and get strong signal.Installs in seconds.
Requires 1S LiPo battery, Suitable for Ultra Micro RC Aircraft. A RTF FPV device for beginners.
FPV Camera:
Output Power: 0/25mW/50mW/200mW (switchable) (Set output power on 0, to avoid frequency interference)
Input Power: 3.2-5.5V
Sensor: 1/3 "CMOS
Camera Resolution: 600TVLA
AKK AIO Camera is the leader of low illumination flying.
Mini illumination: 1 lux
Format: NTSC
Transmitter:
Support Video Format: NTSC
Output Impedance: 50 Ohm
Output signal strength: 13±1dbmdBm
Output Power: 25mW: 14dBm /50mW: 17dBm /200mW: 23dBm
Wireless Channel: 40CH
Antenna: RHCP circular polarization clover leaf antenna
Antenna Size: 22x29mm
Operating voltage: 3.2V ~ 5.5V
Current consumption: 25mW: 250mA-510mA /50mW: 270mA-640mA /200mW: 330mA-740mA
Audio carrier: NO
AKK A3 5.8G 40CH VTX 0/25mW/50mW/200mW Switchable 600TVL 1/3 Cmos Micro AIO FPV Camera (23 min 41 sec)
AKK X2:
25mW/200mW/500mW/800mW power switchable
Support parameter adjusted and work with Betaflight,fligth controller,OSD
Super mini size and light weight,One button frequency and power setup.
7-24V input and can be provides 5V output for your camera.
Filtered power ensure super clean video, born for racing.
4 kilometres with AKK X2 5.8Ghz 40CH 25mW/200mW/500mW/800mW Range Test:
AKK X2 5.8Ghz 40CH 25mW/200mW/500mW/800mW Range Test (5 min 0 sec)
FPV Reviews: The Akk-Tech X2 VTX, featuring Smart Audio (10 min 20 sec)
AKK X2P 5.8Ghz 40CH 25mW/200mW/500mW/800mW Switchable Betaflight OSD FPV AV Transmitter with Pigtail :
Can be filter the power and make sure you get clean video.
Support PIT-Mode and work with Betaflight,fligth controller,OSD
look at the Super strong signal of akk x2p:
DrAbsurd FPV AKK X2P 800mW Range Test:
DrAbsurd FPV AKK X2P 800mW Range Test (5 min 33 sec)
AKK A5 AIO camera with vtx released on September 19, 2017:
AKK A5 FPV 5.8 GHz micro camera system for Tiny Whoop - Unboxing, inspection and testing (9 min 10 sec)
AKK F4 Flight Controller with Integrated OSD support SD Card
Weight: 7.5gram
PCB Thickness: 1.2MM
Processor: STM32F405RGT6
Transmitter: MPU6000 integrated accelerometer/gyroscope
Preset firmware version:3.1.7-OMNIBUSF4SD
Signal of receiver supported: PPM/SBUS
Barometer: BMP280
OSD: Flight Control Board IMU with Integrated OSD, support ground station Betaflight OSD parameter configuring; support tunning PID with OSD by using remote controller; Transmitter power, frequency band/CH can be tuned with OSD based on the Betaflight.(Support FPV transmitter like AKK X2/X2P)
Galvanometer: Integrated Gal, power current consumption real time monitoring available
Power supply: Built-in power module BEC
SD card slot: standard SD card slot
AKK F4SD flight controller review (6 min 14 sec)
AKK FX2:
AKK FX2 Key features:
Support Parameter-adjusting mode
25mW, 200mW, 500mW and 800mW power switchable
OSD configuration using FC Uart
7-24V input with 5V output
With MIC
Button control Channel select mode:
Channel select mode
Band select mode
Power select mode
Specifications:
AKK FX2 40 Channel Smart Audio VTX Review (10 min 41 sec)
AKK FX3:
FX3 is similar to the FX2 but has a smaller profile that uses 20x20mm mounting pattern, in the cost of lower max output power, to be designed for smaller micro builds.
AKK FX3 Review : 20X20, MMCX, Smart Audio, $19, and 600mW! (8 min 10 sec)
AKK X5:
Features:
Support 0.01mW Parameter-adjusting Mode
25mW, 50mW, 100mW and 200mW power switchable
OSD configuration using FC Uart (F3/F4/F7 with OSD)
5V input with 5V output
AKK Nano1: the smallest vtx on the market:
AKKTEK Nano 1 Video Transmitter / Tiny FPV Pod (15 min 35 sec)
AKK Nano2: the smallest FC Uart support VTX on the market
Support 0.01mW PIT-Mode
OSD configuration using Smart audio (F3/F4/F7 with OSD)
5V to camera @ under 300mA
AKK Nano2 Micro Smart Audio VTX Review 👍 (3 min 34 sec)
AKK EIO 5.8 GHz 48CH 25mW FPV Transmitter with AIO Mini Camera and DVR for FPV Quadcopter Drone:
Micro cámara FPV con DVR integrado | AKK EIO:
Micro cámara FPV con DVR integrado | AKK EIO (6 min 28 sec)
AKK AIO-SA (AKK AIO- SA is the first AIO camera on the world with smart audio ) ------announced on Dec 27, 2017:
Key Features:
Support 0.01mW Smart Audio & P Mode
MJX Bugs 8 Pro 1.3km AIO AKK Jumper T8SG Air Hogs DR1 Review (5 min 10 sec)
New AKK AIO FPV Cameras // Overview (5 min 51 sec)
AKK A1-OSD --------announced on Dec 27, 2017:
Key Features:
Customized callsign available
OSD can display parameters on 5.8GHz FPV goggles or monitors
CH, Band ,FR, voltage and flight time adjustable
OV231 lens perfect for low light
Super light weight
AKK A1-OSD (4-IN-1) 5.8Ghz, 48Ch, 25mW - VTX, 600TVL, 1/4 Cmos - Camera, Dipole Antenna, OSD (6 min 17 sec)
AKK A3-OSD --------announced on Dec 27, 2017:
Key Features:
0.1mW/25mW/200mW power switchable
AKK A3-OSD AIO FPV Camera Review (6 min 16 sec)
FPV AKK A3 5.8G 40CH VTX 0/25mW/50mW/200mW 600TVL with Mjx Bugs 2 B2C Long Range 999 meters Drone (5 min 26 sec)
LitisRC Cicada 180 Racing Drone basic /advanced announced on Jan 20, 2018:
LitisRC Cicada 180 Racing Drone(Basic Version)
Feature:
Strong power system and incredible fast and nimble response speed
Specialized plastic cover protect easy damaged parts like motor, camera and ESC, the comprehensive protection can guarantee you a secure flight
AKK X2-ultimate:
Key features:
Support Smart audio
25mW/200mW/600mW/1200mW power switchable
OSD configuration using smart audio
7-26V input with 5V output for camera
With MIC
AKK X2 Ultimate 1200mW Vtx long range test (oh, it is GOOD!) (7 min 42 sec)
AKK X2-Ultimate vs TBS Unify PRO V3 | Review and Video Signal Test comparison:
AKK X2-Ultimate vs TBS Unify PRO V3 | Review and Video Signal Test comparison (9 min 8 sec)
ZOHD ORBIT - Review with AKK X2 Ultimate 1200MW Video Transmitter (18 min 6 sec)
AKK FX2-ultimate 1200 mw------announced on March 18, 2018:
Key features:
Support Smart audio
With MIC
AKK FX2 ultimate, no issues for 1.4km and a vertical landing:
AKK FX2 ultimate, no issues for 1.4km and a vertical landing (10 min 1 sec)
AKK Nano3:
Specification:
Output power: 25mW/200mW switchable
Input voltage: 3.2-5.5V
Antenna connector: IPEX
Cable connector: 6pin
Dimension(without mounting hole): 19*19mm
Weight: 2.3g
Feature: Smart Audio
AKK Nano3 - Vtx Backpack - Setup (10 min 6 sec)
AKK Aluminum Heatsink ----------- announced on April 10, 2018:
2 pcs Heatsink $0.99
AKK FX2-ultimate-mini :
AKK FX2 Ultimate Mini 1.2W VTX - Review & Flight Footage (12 min 17 sec)
AKK FX3-ultimate ------------------------ announced on June 10, 2018
AKK FX3 Ultimate 600mW Micro VTX Review 😀 (4 min 49 sec)
AKK Infinite DVR VTX: announced on July 24, 2018
Key features:
Support Smart audio
25/200/600/1000mW power switchable
With MIC
640*480, 30fps, loop recording
AKK Oscar's Backpack VTX: announced on September 10, 2018
Oscar's Backpack VTX Support Smart Audio, the hole position of OBVTX compatible with RunCam Micro Swift 3, RunCam Micro Swift 2 and RunCam Micro Eagle, not compatible with Foxeer cameras. Dsigned by Oscar Liang, Developed by AKK.
Key features
Support Pit Mode
25mW and 200mW switchable
AKK FX2-Dominator : announced on April 15, 2019
Key features:
Support Smart audio 250mW/500mW/1000mW/2000mW power switchable
One button frequency and power setup OSD configuration using smart audio 7-26V input with 5V output With MIC
AKK Race VTX : announced on April 15, 2019
Key features
Support Pit Mode
Slow Power On
OSD configuration via smart audio
AKK Pagoda Antenna : announced on April 15, 2019
Specification :
Item: Pagoda Omnidirectional Antenna
Gain : 5dBi
Max. Power : 50w
Connector : SMA male
Color : Black
Length : 64±3mm
Max. Dia. : 22.5±1mm
Min. Dia. : 3.5±1mm
Frequency : 5.8G
Impedance : 50Ω
VSWR : <1.5:1
Polarization : Circular Polarized
Radiation : Omni
AKK Diversity RX : announced on April 15, 2019
This is a diversity receiver with two RX modules.
Note: AKK Diversity RX doesn't come with cover to fit with your goggles
Specifications:
Frequency: 5.8GHz
Sensitivity: -93 to -95dbi
Number of CH: 48 Channels
Antenna connector: SMA Female
Input voltage: 5V
Current Consumption: 5V @ 380mA-400mA
Compatible with FatShark goggles
Built-in Low Power Buzzer
AKK X5 Pro (16*16/smart audio): announced on April 15, 2019
Key features
Support pit Mode
AKK A6 : announced on May 22, 2019
Feature:
Output power: 25mW
Input power: 3.2–5V
Current consumption:3.2V-5V,250mA(type)
Camera resolution: 600TVL
Video system: NTSC
Field of view: 120°viewing angle
Antenna dimensions: 22mm X 29mm diameter
Antenna: 4 lobe right hand circular polarized
Frequency: 5.8GHz 5 bands 40 channels,
with Raceband: 5658-5917MHz
Weight: 4.3g
AKK Nano Camera for Oscar's Backpack VTX : announced on July 9, 2019
Parameters:
Image Sensor 1/3" CMOS
Resolution 1.3 megapixel 1288h X 968v @60fps
Lens 1.6mm FOV160°
Signal System PAL / NTSC selectable by OSD keyboard
Integrated OSD Yes
S/N Ratio 38dB
Day/Night Color/B&W
Power DC 4.2-5V
Current DC 5V 120mA
Net Weight 2.5g
Transmission Mode CVBS
Dimensions 19mm*19mm
Last edited by akkteck; Jul 09, 2019 at 08:19 PM. Reason: add new item name, thanks!
Sep 14, 2017, 09:43 PM
Would love to try this out on my alien/kiss pdb setup.
Sep 14, 2017, 11:07 PM
Sumfear's Avatar
Looks interesting. Would be interesting to check interferences and smart audio.
Sep 17, 2017, 08:07 PM
Thank you all guys above.
to mlilasic, your reviews are good, PM sent.
Sep 18, 2017, 05:11 AM
RC "dream becomes reality"
stipesb97's Avatar
Hi, im really curious about this type of vtx. I would like to make a review.
Sep 18, 2017, 12:11 PM
After picking up some X1's and having no issues for a few weeks, I went ahead and ordered some X2's. I can't wait to get them in and try the new features, Pitmode and SmartAudio. This is a welcome update to the X1. Only minor nit pick is I wish the SMA connector was centered like it was in the X1. I look forward to reading reviews of those who have been at this hobby longer than I.
AKK continues to move in the right direction. They have quality products at a good price. I first found them after getting their BS2 cameras (great btw!) for my whoop. I really do feel that they value customer feedback and deliver great products.
Sep 19, 2017, 07:42 PM
Thanks guys above for support akk. Only a few samples i have to.....
@Vabch22, thanks for bought x1,x2, bs2, i will send you one new tpye x2p several days later.
Sep 20, 2017, 01:06 AM
Hittin Gaps With D Gains
SteelRainSpo's Avatar
I would like to be considered for testing, here is my YouTube channel link:
https://www.youtube.com/channel/UCx7...u0eV4EOxkxziTg
Sep 21, 2017, 01:34 AM
Jay 123's Avatar
lc filtered tx is perfect, great improve compared to X1, x2p should also be a good product
Sep 21, 2017, 02:30 AM
People are more interested in mmcx clover/ pagoda antenna, it seems mmcx is the trend, but nobody sells linear antennas with mmcx, and people using linear antennas prefer to connect it directly to the board with the IPEX plug, and AKK released new X2 transmitter has just sma and mmcx two choices, so some people suggest don't solder the antenna cable directly in the board
Sep 21, 2017, 02:40 AM
mmcx one
Sep 21, 2017, 09:38 AM
Thank you! Guess I will have to build another quad now.
I agree. If all goes well, the x2/x2p should be a great vtx.
Sep 21, 2017, 08:16 PM
Thanks to the above guys, a little confuse about the discusion of X2P on facebook.
Byars said MMCX plug please don’t solder the pigtail
Brewer said Yes!!!! Direct soldered pigtail!!!
André said Nice product but please don't solder the antena cable directly in the board, use the IPEX plug instead. Many pilots like me use linear antennas and we prefer to connect it directly to the board with the IPEX plug. Thank you
Build Log AKK A3 new arrival akkteck FPV Equipment 3 Sep 27, 2018 05:34 AM
New Product AKK A5 new arrival 5.8Ghz 40CH 25mW Transmitter 600TVL FPV Switchable Camera akkteck FPV Equipment 0 Aug 02, 2017 04:43 AM
