Robart Rechargeable Electric Air Pump - RCGroups Review - RC Groups
Pump up those air retracts and anything else around your house! The Robart Rechargable Electric Air Pump makes quick work of air retracts on giant scale aircraft. Let's take a look at this handy device!
Robart Rechargeable Air pump
Product:Robart Rechargeable Electric Air Pump
Retail price:$59.95
Input voltage:AC to DC Plug = 12V
Input Voltage:DC Power Port =12V
Max Inflation Pressure:150psi.
Operation Temp:68-140 degrees fahrenheit
Size:2.16"(L) x 1.76"(W) x 7.80"(H)
The Robart Rechargeable Electric Air Pump is designed to give you a worry free retract filling system that is reliable and easy to transport! With its easy to use design and rechargeable battery, it will become a must have for your flight box!
Let's jump right in with Mean Joe and check it out!
What's in the box
The Robart Rechargeable Electric Air Pump ships with the Air Pump, fill tube, adaptor fitting, 8" of airline, AC charger, DC charger, and velvet storage bag; everything you need to get started filling your retract systems right out of the box. Just charge the unit and it's ready for use!
The one thing I would suggest picking up as an option is the Robart 164E-A accessories pack. This kit includes the inner tube fill w/lock, needle ball adaptor, and bulk tube fill. These add ons will come in handy for all of your air filling needs. Whether you are at the beach or pool needing to fill up rafts and beach balls, or on the road with a low tire, you will be covered.
How it works
Robart has made the 164E Rechargeable Electric Air Pump super simple to use, just connect the unit to your system, select the air pressure you require, and hit the power button. The unit will fill your system up to the air pressure setting you selected and then shut off. It is just that easy!
Mean Joe tested the unit using the Robart 192 Large Air Tank paired with the Robart 590P-PRS 90 degree pneumatic main. With this set up I was able to fill the large tank 8 times from completely empty to 100psi taking an average of 1 minute to fill each time. During normal use, you will not be completely emptying out your tank between flights. Depending on your system set up, I would guess you would use less than half the air in the tank for each flight. This should give you more than enough air to last all day at the field. In the event that you forget to charge the pump or share your air with other pilots (this will happen once they see it) simply plug the unit into the cigarette lighter on your vehicle, and in about 45 minutes you will be fully recharged and ready to go again!
The one thing I wanted to make sure and point out is that during the operation of the pump unit, the fill tube end can become EXTREMELY HOT! Please make sure you handle it with care. Other than that, I encountered no issues at all and the unit worked flawlessly.
Review Video:
Robart Rechargeable Air Pump - RCGroups Review (2 min 15 sec)
In Closing
If you are in the market for an easy to use, extremely portable air filling system for all your air needs, then look no further than the Robart Rechargeable Electric Air Pump. ~Mean Joe
More Information
For more information on the items used to test this unit, please check out these helpful links.
Robart 164E-A Accessories Pack
Robart Large Air Tank
Robart 590P-PRS 90 Deg. Mains
Nov 02, 2017, 03:03 PM
7 KCAB driver
Whiskey Bravo's Avatar
Mine has quit taking a charge. Has anyone here taken their's apart and if so how does it come apart?
Dec 20, 2017, 03:11 PM
Everything RC
flypilot's Avatar
There is also a cheaper option out there if anyone is interrested :
RC pump for pneumatic systems.. (4 min 10 sec)
Dec 25, 2017, 08:40 AM
Same Day Delivery
mike3976's Avatar
What's wrong with a el-cheapo 12 volt tire pump powered by a old 3s li-po, 2200 mahr battery, fills the air tank In seconds.
Dec 25, 2017, 08:44 AM
Everything RC
flypilot's Avatar
Absolutely nothing
Help! Finding an electric air pump/valve for a pneumatic landing gear F22dangerzone Large EDF Jets 14 Mar 08, 2015 09:30 PM
Help! converting electric tire pump for air brush THE HORSEMAN Electric Motor Design and Construction 1 Apr 19, 2010 12:36 AM
Discussion Robart electric fuel pump lightthings Flight Accessories 0 Apr 12, 2010 01:23 PM
Article Sullivan's Streamer S754 Smoke/Diesel & S752 Glow Fuel Electric Pumps Mini-Review RichN Engines 0 Mar 19, 2007 02:15 PM
