Sep 09, 2017, 08:37 AM
Beemans2's Avatar
Hamilton Edge 540
This is my 26% Pilot RC Hamilton Edge 540. It has a 78 in wingspan without the winglets and is the largest that I could easily get in the back of my Tahoe. It has a 35CC DLE with rear mount exhaust. I used a B & B Specialites muffler with smoke ports rather than the supplied one because I heard bad things about the one that comes with the engine and it would not have fit without cutting away part of the engine box. I am currently running a Xoar 19/8 Beachwood Propeller. It has MKS DS1220 Digital High-Torque Servos. To get the CG to spec I used a rear mounted rudder servo and mounted the batteries at the forward rudder servo position. It uses two 2200mAh LiFe Receiver Batteries connected to a Smart-Fly SuperReg, a Tech Aero ignition battery eliminator IBEC, a PowerBox Smokepump. I have 3 voltages (2 batteries and the reciever voltage) and engine temperature telemetry on a Futaba receiver. I included a CORTEX 3-Axis Aircraft Gyro mostly because Frank has them in his airplanes and I wanted to try it out.
I mounted the the 14oz fuel and smoke tanks above and below each other. Cooling the engine under the cowl was a challenge. It would have been much easier with a opposed twin. First flight was a success with 12 clicks of down elevator and two clicks of right aileron required to trim. I think I am going to like this airplane.
Sep 09, 2017, 08:42 AM
Beemans2's Avatar
Video of maiden flight
Maiden of the Hamilton (6 min 12 sec)
Sep 13, 2017, 09:37 AM
mondofresh's Avatar
What a beauty!
Sep 23, 2017, 09:18 AM
Beemans2's Avatar
My first flights indicated that it was tail heavy (it climbed hands off inverted). I have a version of an EDGE 540 on FlightSim that matches the size of my real one and adjusted the CG to have the same characteristics I found on my first flight. Then I moved the simulator CG until I got the desired characteristics (hands off level flight inverted or upright). This was about 0.6 inches forward or more nose-heavy. From the weight of the plane and the weight of the batteries I calculated I needed to move the batteries 13 inches forward. I moved the batteries in front of the fuel tank (and moved the smoke pump).
I flew the reconfigured plane yesterday and the balance was perfect. The new placement is shown.
Sep 23, 2017, 03:46 PM
Beemans2's Avatar
Here are my build notes.
https://www.rcgroups.com/forums/show...8&postcount=64
May 20, 2018, 12:57 PM
Beemans2's Avatar
Hamilton Edge 540 Update
I changed a few items on the Hamilton this year. First, I must of had a hard landing or two because the wheel rims were broken. The originals were hard tires with almost no give so I replaced them with durbo soft, a wider and much softer tire. Second I changed the smoke tank to three line because with a two line I needed to clamp the feed to the muffler to avoid pumping the smoke oil there when filling the tank. Clamping the smoke oil line meant opening the canopy and I went to great pains to make sure I did not have to unbold the canopy between flights (small power off switch on the side). Hopefully, I will not have to do this any more. Third, I made an extended control bar for the tail wheel. It is about twice as long and should give me more ground control in those crosswinds.
Discussion Pilot RC Edge 540 V3 Hamilton 78" Aviator1165 3D / Fun Fly Fuel Planes 95 Sep 14, 2018 10:02 AM
Discussion EF 60 inch Edge 540 EXP vs 3DHS Edge 540 58 inch richord 3D Flying 5 May 29, 2016 02:02 PM
Discussion Fliton Mini Edge 540 or E-flite Mini Edge 540? That is the question. CGReload 3D Flying 4 Feb 13, 2008 03:17 PM
Poll Mini Katan V Fliton Edge 540 V Fliton Edge 540 Cliddy 3D Flying 30 Feb 08, 2006 04:47 AM
Poll Mini Katan V Flinton Edge 540 V Filinton Edge 540 Cliddy 3D Flying 2 Feb 05, 2006 06:23 PM
