Convert Phantom 2 FC & NAZA M Lite to NAZA M V2 v4.06/v4.02 - RC Groups
Sep 08, 2017, 06:50 PM
After some long sleepless nights finally got it.
It's ready the software to upgrade Phantom 2 FC and NAZA M Lite with firmware from NAZA M V2 lastest version 4.06.
It works, I tested in a Hexacopter (with NAZA M Lite with NAZA M V2 v4.06 firmware) and Quadcopter (with Phantom 2 FC with NAZA M V2 v4.06 firmware).
Here is an image of the software and the ZIP with software inside.
After all this work I think I deserve a free cup of coffee (if you like my job use PayPal donation inside software).
Sep 08, 2017, 07:27 PM
UPDATE:
Finished flashing both flight controllers with NAZA M V2 firmware v4.06 and all went ok, the images show the bootloaders from each controller and the DJI Assistant for NAZA M V2.
The motors start ok, no problem with serial key, they fly good, can't find any problem so far.
Need to do some more tests to see if everything works without any problem.
Sep 09, 2017, 04:15 AM
Don't see comments from anyone.
Is there anyone interested in this?
If not I stop the project because my problem is solved.
Sep 09, 2017, 09:17 AM
Yes. How you did it?
Sep 09, 2017, 09:25 AM
Searching the internet, filtering a lot of information, compile the good information and luck, some reverse engineering and many sleepless nights.
Sep 09, 2017, 10:59 AM
Test and give me feedback. (moved to the top).
Sep 10, 2017, 11:19 AM
Did anyone test the software?
Sep 11, 2017, 07:21 PM
Or the software is working perfectly or no one is using it or simply lost my time thinking that someone would be interested in this.
Sep 11, 2017, 10:39 PM
I've been interested in this since I've seen the Lite -> V2 upgrade. However, at the moment, I don't have any Naza's handy for this. Perhaps time to check Ebay.
Sep 12, 2017, 12:05 AM
B.P
B.P
What is different to the original Lite > V2 hack? Is it newer firmware than what was available with the old hack?
Sep 14, 2017, 07:01 PM
Yes you can upgrade for v4.06 the other one was v4.02.
And not only NAZA lite, but also the controller used in Phantom 2, Vision and Vision plus, converting them to NAZA M V2.
Sep 20, 2017, 04:18 AM
I would like to get some feedback from this.
Sep 20, 2017, 04:41 AM
B.P
B.P
OK so I have a Naza lite that I flashed to the 4.02 firmware using the old hack.
Can you confirm that using your tool to flash to 4.06 will not result in the motor lockout that would happen if I upgraded through the Naza M V2 software?
Also, once the upgrade to 4.06 has been completed can you use the Naza M V2 software as usual?
Sep 20, 2017, 05:35 AM
Yes you can update your Naza Lite to v4.06 using this software and you don't get motor lockout or serial key error, it is completely functional.
To configure the new flashed FC (Phantom FC or Naza Lite) you use DJI Assistant Software for NAZA M V2 as you used with v4.02.
It's possible to restore the original firmware using the connection of F1 and F2, and then flash with original software from the assistant for that flight controller.
Sep 26, 2017, 05:13 PM
So many downloads and no feedback!
Did anyone test the new firmware?
Did anyone upgrade a Phantom 2 FC to NAZA M V2?
For me it's frustrating because I spend a lot of time to produce this and get no feedback.
Discussion DJI Naza M Lite to Naza-M v2 Firmware* v4.06 Fidy$Trainer Multirotor Drone Electronics 6 Oct 01, 2017 08:10 PM
Discussion Seems that NAZA M V2 v4.06 firmware can be used on the other DJI MC rcaridade Multirotor Drone Electronics 2 Sep 26, 2017 11:29 AM
Discussion Naza M-Lite - Upgrade to V.2 fw. 4.06? Corpze Multirotor Drone Electronics 3 Feb 18, 2017 08:51 PM
Discussion NAZA-M V2 Firmware V4.06 Bladefold51 Multirotor Drone Electronics 0 Jan 27, 2016 09:10 AM
Discussion Phantom 1.1.1 - Naza M v2 - Naza M Lite rodrigofaillace Multirotor Drone Electronics 0 Apr 20, 2014 05:37 PM
