Canterbury "J" # 532 - Page 3 - RC Groups
Oct 08, 2017, 08:15 PM
Modeler/ Historian
Stephen Vick's Avatar
Great job. She looks fantastic.
Oct 11, 2017, 03:53 PM
hey guys, I am now back to where I was thinking and planing the hatch cover coaming, I put in a 1/8 X 1/4 strip of bass wood under the decking and trimmed the decking and have a temporary piece of 1/16 X 3/4 bass now to do more thinking before I mess this up,.... I also am considering using an epoxy on the deck, some one here said to use spar varnish, just thinking...
Oct 11, 2017, 07:36 PM
Modeler/ Historian
I used Tung Oil on mine. When have you ever seen a glossy varnished deck on a real boat?
Oct 11, 2017, 09:47 PM
on the show room floor ??
Oct 12, 2017, 06:24 AM
Modeler/ Historian
Nope. The decking is a non skid surface Perhaps planking on cabin tops but not the deck which is walked on. Even on high end super yachts . Anyway. Tung Oil is very simple to use and the results are great. However, your boat, your preference.
Oct 12, 2017, 05:30 PM
I've been busy, I did a mock-up of the rear hatch, not sure ?.... I also mocked-up the main hatch coaming and I played with color.....
Oct 13, 2017, 06:27 AM
There's a variety of wood finishing products out there that provide a satin (my preference) or even flat finish. Easiest way is to find a local wood working expert and talk to them.
Oct 13, 2017, 03:00 PM
Dick L.'s Avatar
I stopped using tung oil after finding it caught a lot of dust on my handgun grips. Just an FYI
Oct 15, 2017, 02:48 PM
I have now moved on to Plan 'B" regarding the rear hatch...
Oct 16, 2017, 01:47 PM
I have been thinking about hardware, both standing and running rigging, any suggestions?? or recommendations
Oct 16, 2017, 03:26 PM
Modeler/ Historian
CJ rules gives much leeway as far as hardware is concerned. I kept mine fairly simple You can see my build thread My next will be more race oriented and incorporate more adjustability. I can say that I prefer stranded wire for shrouds and stays. And incorporate as many ways as possible to take it all apart. I find fishing swivels and clasps to be invaluable
Oct 20, 2017, 06:30 PM
back at it, working the brain, running out of trees, yes, buy more wood, a hatch cover in the making.....
Oct 20, 2017, 10:12 PM
Modeler/ Historian
My hatches were made using 1/32 birch ply (the same used for the deck) Assembled with 30 min epoxy and completely water proofed using thinned epoxy. after I was satisfied that the hatch would be secure, I next planked/ detailed the hatch. I also made a "race hatch" from 3mm polycarbonate "Lexan" sheet. I have run with "A" rig in 20 MPH with gusts of 30 MPH, burying the lee rail to the centerline , and only shipped a quarter cup of water in an hour. Don't overthink it. A 1/8 inch combing and good hatch overhang is enough. water follows the path of least resistance, so give it the easy out.
Oct 27, 2017, 08:19 PM
still working the hatch detail, I hate watching glue or paint to set or dry..... thinking of hardware/ fittings and mast, so I go to the BOOK of Rules, and I come to section 3: Rig and 3.2, and 3.2.3 Mast Stubs SHALL be permitted and then I go to section 3.3.7 check stays and their attachments ONLY in Conjunction with a mast stub and shall be attached to provide support for the stub.
Now the questions , what is a mast stub, ??? dimensions for said stub ??? and how is it attached to the other mast parts ????.. and I am sure other unasked questions
Oct 28, 2017, 12:24 AM
Kevin Gault
poltergeist's Avatar
I think the term "mast stub" is a carryover from the original rules for the class in New Zealand. I think it refers to a short "stub" that includes the main boom and gooseneck, that stays in place on/through the deck, and the mast sits on top of. I've never seen a C-J rigged this way, but I assume some of the boats down under are set up like this. So far, I haven't had any luck finding a decent picture.
Build Log Canterbury J #590 "Shamrock V" Stephen Vick Sailboats 206 Jun 23, 2017 10:24 PM
Build Log "Dreamer" a Gaff Rig Canterbury J Build cgbillb Sailboats 60 Dec 09, 2016 04:34 PM
Build Log Dreamer a Canterbury J Graff Rig cgbillb Sailboats 1 Sep 04, 2016 04:27 PM
Discussion Canterbury J # 529 Build Ed Crowell Sailboats 477 Sep 04, 2016 12:11 PM
Discussion Anybody here have a Canterbury J sailboat? Ed Crowell Sailboats 62 Nov 11, 2014 02:52 PM
