Sep 05, 2017, 10:05 PM
New Product
SUNRISE MODEL BLHELI-32 ESC 30A 4in1 esc and f4 fc aio
FEATURES
BLHeli_32 is the third generation BLHeli code, following base BLHeli and BLHeli_S.
BLHeli_32 runs on an ARM 32bit MCU, initially it will be on a Cortex-M0 running at 48MHz.
So what can the increased MCU speed do?
First of all, it can run input signals with lower latency at faster rates.
Dshot up to at least Dshot1200, and at rates up to at least 32kHz is now supported.
Secondly it allows packing of more functionality.
Programmable pwm frequency, up to 48kHz, that can run motors even smoother, and also allows for moving of small but potentially disturbing humps in the throttle response. All ESCs have these bumps, with BLHeli_32 they can now be moved in the rpm range, to a place where the system has low sensitivity to them.
Auto timing. Which is not the option to choose if you're after max power. But if you want the most efficient running with very good robustness against desync, it is the perfect choice.
Programmable brake on stop force. Which allows control of the braking of fixed wing props.
Improved direction change in bidirectional mode.
SPECIFICATION
ESC SPECS
Con.Current:30A
Peak Current(10s):35A
SBEC:3A/5V
Lipo:2-4s
FC SPECS
F4 with OSD and CURRENT Sensor
Input: 2-4S LIPO
Output Voltage: 5V/2A
MCU: STM32F4 CPU
ICM-MPU6000 Accelerometers and Gyroscopes SPI
MicroUSB socket.
Weight:22g
Size(PCB):36*36mm, mounting hole: 30.5x30.5mm
Sep 06, 2017, 12:43 PM
FPV addict
mlilasic's Avatar
Sub
Sep 11, 2017, 07:36 PM
jdpworks's Avatar
What target does this use?
Sep 15, 2017, 02:58 AM
target:LUXF4OSD
Sep 16, 2017, 12:59 PM
FPV addict
mlilasic's Avatar
Sorry for this, but one question non related to this particular esc: where can be bought this long screw + spacer set from first picture. Thanks.
Oct 23, 2017, 09:32 AM
Hey,
do you know how many hardware UART-Inverters this board has?
Want to use frsky sbus + smartport
Oct 27, 2017, 03:12 AM
Same question here plus Smartaudio
Originally Posted by Casparian
Hey,
From what I see there is one accessible UART, worst case you have to do the hack. But unfortunately I would need an additional one for Smartaudio, which seems not to be there.
I wonder if you could use the LED pads for Smartaudio?
Dec 24, 2017, 08:44 PM
ManxFF's Avatar
i just bought this few hours ago and realized i dont have enough pads to run my crossfire and smart audio
Dec 30, 2017, 07:33 AM
You can softserial the led pad if you don't use it into some Uart TX pad to run smart audio. It seems to work on every FC i tried
Anyone has ever succed into getting the "sbus" pad to work? It never worked for me, always had to move my receiver on another Uart pad.
I am pretty interested into this FC, but I need 2 full Uarts for crossfire + GPS, and one Uart TX or led pad (to softserial) for smart audio control.
I wish we can use full Uart 6 for GPS as shown, sbus pad pour softserial Uart TX, and led pad for softserial Uart RX for the crossfire, but we missed the last softserial Uart TX for smart audio.
Anyone know if it is possible to softserial the buzzer pad?
Dec 30, 2017, 07:25 PM
more speed and less weigh
These are rebranded racerstar tattoo series by the looks
Dec 31, 2017, 04:48 PM
ManxFF's Avatar
Sugarkane, sunrise are the originals since the 4in1 Cicadas they make, models that don't meet quality requirements are the 1 that racestar buy and sell as tattoo f4s
Dec 31, 2017, 10:40 PM
ahh nice
Dec 31, 2017, 11:15 PM
Price? where to buy??? shipping cost?
Jan 01, 2018, 09:44 AM
ManxFF's Avatar
http://pirofliprc.com/Sunrise-Siskin...IO_p_4354.html
Jan 03, 2018, 03:02 AM
Has anyone been flying one of these for awhile? Feedback? Or is there another thread somewhere? Debating this board for a new build.
Discussion Asgard 4x25A Blheli_S / Asgard32 4x35A Blheli32 AIO - FC, 4in1 ESC PDB sevet Multirotor Drone Electronics 1540 Oct 07, 2020 11:59 PM
New Product EMAX Magnum Tower System: 4in1 30A Bullet ESC, PDB, F4 FC/BF OSD, XM+, VTX D Gains Multirotor Drone Electronics 425 Apr 23, 2020 10:01 AM
New Product [Sale $27]HGLRC F4 FLAME - FC/PDB AIO & HGLRC F4 Titan - FC/PDB/4in1 30A ESC AIO D Gains Multirotor Drone Electronics 124 Mar 31, 2019 03:14 AM
New Product VIFLY R220 M2 - F4 FC, 2205/2600KV Motors, BLHeli-S 25/30A ESCs - Seeking reviewers johnq816 FPV Talk 7 Sep 05, 2017 11:04 PM
New Product 6.5g XJB V1 F3 EVO FC AIO 5V BEC PDB with XR25A 25A Blheli 2-6S 4in1 ESC sevet Multirotor Drone Electronics 6 Jun 16, 2017 04:25 PM
