Feb 19, 2018, 01:58 PM
JohnVHRC
JohnVH's Avatar
Im in the US and interested, who has some? Olgol?
Latest blog entry: FMS Discount Codes! Click here!
Feb 19, 2018, 02:16 PM
Oleg Golovidov
olgol's Avatar
John,
yes, I have a couple in stock at the moment.
$250 (carbon wings, std layup), shipping $35.
I will be setting up an ordering form for it, to gauge the interest in the USA and Canada, and then decide if I should order a larger batch...
Email me if you want to get one right away.
oleg.golovidov@gmail.com
Feb 19, 2018, 02:20 PM
Oleg Golovidov
olgol's Avatar
Hawk pilots take 1st and 2nd planes in the 'unofficial world championship' among the 1m hand launch pilots.
https://www.rcgroups.com/forums/show...&postcount=220
Feb 19, 2018, 04:30 PM
JohnVHRC
JohnVH's Avatar
Originally Posted by olgol
John,
I like them, little out of my price range Thanks.
Mar 02, 2018, 04:09 PM
Don C's Avatar
Newest toy from Oleg, beautiful. Think I'm going to use push rods as I'm more comfortable than pull springs.
Mar 02, 2018, 06:57 PM
F3-RES model on the board, Don?
Mar 02, 2018, 09:59 PM
Ivo Plachy
itplachy's Avatar
Thinking about using BMS-101DMG in Hawk. Does enybody have an experience running it on single cell LiPo ?
Ivo
Mar 02, 2018, 10:21 PM
Don C's Avatar
Dave, Peter Goldsmiths Opal
Mar 11, 2018, 03:30 AM
alienw9's Avatar
Ivo
They should work fine, but with less speed and torque.
Blue Bird BMS-101DMG - Operating Voltage 3.7V - 6.0V
Stall torque / Speed @ 3.8V 0.6 kg.cm / 0.11 s/60° 8 oz.in / 0.11 s/60°
Stall torque / Speed @ 4.8V 0.8 kg.cm / 0.09 s/60° 11 oz.in / 0.09 s/60°
Stall torque / Speed @ 6V 1.0 kg.cm / 0.07 s/60° 14 oz.in / 0.07 s/60°
Blue Bird BMS-101HV Servo - 6.0V to 8.5V
Stall torque (6V) 0.9 kg.cm 12 oz.in
Stall torque (7.4V) 1.1 kg.cm 15 oz.in
Mar 11, 2018, 06:58 PM
Ivo Plachy
itplachy's Avatar
Thank you for the info.
Ivo
Mar 18, 2018, 10:02 AM
alienw9's Avatar
Hawk 1m DLG - slope fun
Hawk 1m DLG - slope fun (4 min 47 sec)
Mar 18, 2018, 10:49 AM
Oleg Golovidov
olgol's Avatar
I am happy to announce that I signed an agreement with High Quality models about distributing these beautiful high performance 1 meter models in the USA and Canada.
I truly believe that Hawk is one of the best, if not the best, 1 meter glider now in production. Both from the performance, quality, aesthetic points of view.
While I already have a couple kits in stock and available for sale, the first 'real' shipment of Hawks is still in the planning stages. If you think you want one, help me out and submit your order on my little web-page below. This will get you on the waiting list and will tell me how many models I should be asking for in the first shipment.
http://olgol.com/Hawk1m
Mar 19, 2018, 12:24 PM
Oleg Golovidov
olgol's Avatar
White on black carbon looks nice despite it simplicity.
Pics from FB...
Mar 22, 2018, 03:00 PM
alienw9's Avatar
Servo tray
I 3D printed servo tray that would fit better and catch the curvature of the fuse, for better adhesion.
Apr 01, 2018, 06:44 AM
Team Falcon
Scrib's Avatar
Picked up one of these beauties from Oleg.
Nicely constructed.
Just finished the build. AUW 122g CG 46mm!! I need to figure out if this is going to be a problem. With some extra effort, I could shorten wires and maybe ditch servo connectors. I might save a couple of grams if I'm careful - hopefully it would result in moving the CG back some.
I used:
AR400 - must sand down the servo connectors by about 2mm to fit vertically in the fuse
400 mah lipo
BB A10S for Ailerons
BB BMS101 for tails - pull spring.
Flitz peg with carbon patch on top. May add patch on bottom if it doesn't feel strong during launch.
Must use epoxy or foam safe CA, foam is not Rohacell.
I believe there is enough room for a small ballast stick to be inserted past the rear-most servo. I'll get some small sinkers and give it a try. Will add a small balsa block to anchor the ballast stick.
Some notes:
1) included springs for tails are way overkill IMO, I bent up some softer ones which are plenty strong.
2) elevator horn is kinda wimpy. be careful handling
3) it is a tight fit up front with the gear I've chosen, might get away with 4 x BMS101 and save a little room.
4) If you plan to use a ballast stick, you will want to cut down the front wing bolt. It is a few mm too long and blocks the center of the fuse.
It is a good looking bird!
Jason
Build Log Nano Spec Micro DLG - Now evolving into, Nano Spec Ultra V3 1M DLG RobertTHaas DLG Hand Launch Gliders & F3K 253 Apr 20, 2016 10:26 PM
Discussion Order from 27 Nov still being packed in EU Wharehouse _-SOLVED sebip HobbyKing 0 Dec 08, 2015 11:35 AM
Help! Ummwhat the _ _ _ _? Helicopterkid Mini Helis 2 Aug 19, 2009 09:51 PM
New Product New 1m rotor model from LAHeli pwkpete Electric Heli Talk 83 Nov 30, 2006 09:32 AM
