Feb 21, 2002, 01:56 PM
jean-claude Terrettaz
bidule's Avatar
Fw 109
HO suberb temperature today in Ontario almost spring !
First and second succesfull fligth of the Jamara 109 ..setup is :
Jeti 15/4 + 40 esc
9/6 folding prop and 50 mm. collet
7 1700 scr or 8 1000 scr
38 amp full power, perfect for Handlaunch.
4.5 minutes fast tracking of the sky ,I move the CG @ 50 mm for better control ,the beast will snap @ the correct CG.
I really enjoy this first contact..
Feb 21, 2002, 01:58 PM
bidule's Avatar
FW109
Feb 22, 2002, 05:04 AM
Nice looking FW-190, what kit is it ? I am just finishing a Balsacraft Bearcat with a Magnetic Mayhem fo power, but it won't be flying for a while, the snow turned to ice. Welcome to Ontario!
Feb 22, 2002, 07:25 AM
That's a Global or Jamara FW-190 ARF.
Feb 22, 2002, 01:33 PM
Lithium Member
Herb's Avatar
... there is in fact a Jamara/Global Me-109 as well, which from what I have seen is also grossly out of scale - but - usually at least - flies just as miserably as the FW-190 .
Sep 01, 2002, 01:24 PM
pval3's Avatar
howdid it fly?
thinking baout the plane for a conversion . . . how did it fly, what battery/ motor combo did you use and do you still like the bird after flying it for a while??
Sep 03, 2002, 06:17 PM
Brushless combo
Hi there,
After several attemps with different power combos I finally got it to fly with a Mega 22/10/6 8x5 APC 1100 AUU.
I also tried 8xCP1300, but it turned out a bit heavy but still flyable.
How it handles? Really FAST !!!, this is the fastest one I have in my fleet, or at least for this little size.
It will tip stall very easily, no slow flying with this one.
It needs about 30-40 feet to take sufficient speed to take off, however up in the air it flies with 1/3 - 1/5 throtle, or you can push the envolope full speed.
After a couple of bad landings I came to conclude this is a little tough plane, nothing seems to break it.
Enjoy !
Discussion fw 109 aeronaut16 Beginner Training Area (Aircraft-Electric) 6 Mar 05, 2007 09:55 PM
Discussion Gws Fw 109 ATIS Parkflyers 8 Feb 13, 2007 11:08 AM
GWS fw-109 DUMBERTHUMBS Parkflyers 9 Mar 14, 2005 08:25 PM
