Can you put 2 receivers in a drone? Possible? - RC Groups
Sep 03, 2017, 04:55 PM
Question
Hey RC experts and enthusiasts! I have a few questions about receivers.
1)If installing multiple 2.4ghz receivers in a drone/plane, can you piggyback them? In other words: link them together and get 16 channels instead of 8 for example? Theoretically.
2) Can you run 2 receivers off of one ESC?
3) If you have a 8 channel receiver, and a 4 channel transmitter... will that work? Can you control the receiver with the transmitter? Or do you definitely need a transmitter that matches the channel level of the receiver? I guess Im asking cause I know you have to match things like DSM and DSM2 on transmitter and receiver, but Im not sure what else needs to be matched.
The reason Im asking is cause Im working on a project plane. The receiver/transmitter that comes with it is a 6 channel DSM2 spectrum. I want to add a bunch more servos to the plane so I can do random funky unnecessary cool stuff. So I want to add a second receiver, plug a few servos in the plane, and take apart an old transmitter and turn it into a control board that can sit on my lap or off to the side with a joystick and switches etc. Thats the plan. So if anyone comes up with any advice they want to share with me knowing my project, Im all ears. Thanks everyone!!
Sep 04, 2017, 06:55 PM
No bounce, No play.
davidmc36's Avatar
Best bet is FrSky. Supports two Rx's and 16 channels right out of the box.
Sep 04, 2017, 07:50 PM
If it flies, I can crash it.
rocketsled666's Avatar
1) Many radio systems support channel expansion, you don't necessarily need a second RX. If your FC has serialRX support you have additional options.
2) Yes. But the BEC that's in the ESC, which is what provides the power, has limits. Depending on what else you attach to those RXs, you might overload the BEC.
3) The transmitter has to have as many channels as you want to use. But you don't have to use them. A 4 channel RX will work with an 8 channel TX and a 8 channel RX will work with a 4 channel TX. In both cases, you will only get 4 channels.
What you're suggesting doing is using two TXs and two RXs in the same plane. There is no problem with doing that. They will coexist just fine. Many people do this. On more complex scale models a second TX with a co-pilot might be used to control the extra functions. More commonly, camera drones use one radio system for piloting and a second for camera/gimbal control. You don't have to worry about anything except #2.
You plan to run servos and servos draw current. You need to add up all the current that the servos can draw (assume worst-case, that they all draw their maximum at the same time) and make sure the ESC's BEC can handle it. Most ESC BECs are 5A max, which is good for about 4-5 servos. If you plan to use more than this, which it seems you do, you should use a second stand-alone BEC to power the second RX and its servos independent of the primary flight RX/servos, which are powered off the ESC's BEC.
Sep 04, 2017, 09:16 PM
Awesome! Thanks david, I'll look into the frsky
Sep 04, 2017, 09:19 PM
Ok perfect. I have an extra esc and batteries. I dont mind throwing another esc in there, just trying to avoid adding more battery weight (thats why I was hoping to run the main setup + the new rx and servos off the one ESC). All in all, the 2nd receiver will only really run a couple servos, maybe 3-4 max. So glad you filled me in that its ok the run 2 rx in a setup. Heck, actually thanks for answering period haha. I didnt think anyone was going to so I went ahead and bought a few servos and rx already! Just waiting for it to come in the mail.
Sep 04, 2017, 11:22 PM
You can use a second ESC just for its BEC and just not connect a motor, sure. But you can get a stand-alone BEC that'll be smaller, for cheap $.
In either case, plug the ESC (or BEC) in to the BATT port of the second RX. You don't need to plug it in to the Throttle channel, and this will let you use channel 1 for one of your servos.
Sep 08, 2017, 09:09 PM
Ok. Ive never used a BEC and dont know much about them, guess this could be a good time to get one! Any recomendation on what type to get? I dont mean brand, I plan to go to banggood for low priority things like this. But Im seeing thing like:
3A 5V 2-5s
5.3v
3A/5A/7A/15A
6A 6V
Not sure what I need really. I have a 3cell 11.1v lipo and plan to add the second RX with maybe 3 or 4 servos. Doesn't seem like a servo would call for much power
Sep 08, 2017, 10:46 PM
You have used a BEC, you just don't realize it. The thing on the ESC that powers the RX is a BEC. It's just built in to the ESC instead of being a separate device. Many ESCs (the ones for multirotors) are BEC-less (they call them "Opto" which isn't what they are, no one knows why they're called this).
The best efficiency will be a BEC that's got about 20% more capacity than you need, and that has an input voltage range that's closest to the battery you'll use. But in practice it doesn't matter a lot. Though it's worth noting that higher-Amp BECs usually have reduced maximum output currents on 6S (like, it'll be rated for 10A on a 3-4S pack but only 5A on a 6S).
How much the servo needs is a function of the size of the servo and the load you're going to put on it. The swash servos on my big FBL heli can draw close to 5 Amps each when they're working hard. Tail servo pulls a lot, too. These servos have metal cases with heat-sink fins machined in to help keep them cool. In contrast, the tiny servos in my UMX 2S A-10 probably max out at a couple of hundred milliamps.
If you're just going to use the servos to do things like point a camera or operate a door or drop-release you don't need big servos so you don't need a big BEC. I'd go for a 5V 5A good for 2-4S input voltage. If the servos have to carry flight loads (control surfaces) then it'll depend on exactly how big the servos are and how much control surface they need to move and how fast you'll be moving when they do it. Not easy to figure out. But the servo's specs will say what it's maximum current draw will be. Jut use that if you're not sure how much load the servo will have to deal with.
Sep 10, 2017, 01:16 AM
Ok lots of good info. Well when the new rx and servos come in the mail, I guess Ill just test them with a multimeter to see how much juce they use, add them up and see what bec I need at that time and add 20% to it to be safe. Thanks rocketsled!
Nov 13, 2017, 02:16 PM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Did you realize you need a FrSky Transmitter to run the FrSky reciever you ordered?
Your transmitter and reciever must be the same protocol and I don't see any mention from you about a transmitter.
Discussion Can I put 2s lipo in 1s quadcopter. please help Tallent911 Power Systems 3 Dec 05, 2016 08:07 AM
Question 70mm DPS 3000kv 4S EDF... what can I put this in? :S Psychosix Electric Ducted Fan Jet Talk 6 Sep 07, 2016 04:39 PM
Help! Mid side 3D plane that I can put a 20CC gasser in jdm85 Fuel Plane Talk 10 Jun 10, 2016 03:26 PM
Discussion Can I put a 500 mah battery in a sky viper that comes with 650 mah batteries? DeezDrones Beginner Multirotor Drones 8 Mar 14, 2016 04:16 AM
Help! i need help finding a micro small bb gun i can put on my drone danishguy Volenti Non Fit Injuria Extrema 18 Jan 28, 2015 07:23 AM
