Sep 02, 2017, 01:55 AM
→ 404 Not Found
Justapoke's Avatar
Sonicmodell - Mini Skyhunter - V2 - 1238mm Wingspan FPV EPO KIT
New release: New V2 of the mini Skyhunter from Sonicmodell:
https://www.banggood.com/Sonicmodell-Mini-Skyhunter-V2-1238mm-Wingspan-FPV-EPO-RC-Airplane-KIT-p-1194170.html
This 1238mm Wingspan Mini Skyhunter V2 (un-assembled kit) is a middle sized FPV plane of the legendary Skyhunter air frame series, it’s unique twin-boom tail wing design makes it fly super stable and agile, the compact fuselage is easy for hand-launch by yourself. In order to decrease the tail weight, we use high strength carbon fiber reelpipe instead of normal tube, the EPO molded wing and fuselage reinforced by carbon fiber tube and strips, is light in weight but solid and strong in structure, pre-cut hatches for FPV gear offers multiple mounting choice for your camera, Vtx, GPS and battery.
Description:
Brand Name: SONICMODELL
Item Name: Mini Skyhunter V2
Wingspan: 1238mm(48.74")
Length: 855mm(33.66")
Wing size: 19.5dm2
Flying Weight: 830g
Wing load: 42g/dm2
Features:
* Middle size FPV plane for mid-range FPV flying
* 1238mm wing span compact size offers the good portability and flexibility
* Very big room inside fuselage with sliding equipment tray for FPV gear and big battery
* Pre-molded 9g or 5g servos location for rudders if you plan on using them
* Pre-cut hatches for gimbal / cameras / video transmitter / GPS / rudder servos
* Multiple camera mount option, compatible for FPV and HD camera in the market
* Molded hand grip for hand launch
* Tail boom length adjustable for the best CG setting
* CG: On the main spar (Slightly forward for maiden flight)
* Unassembled kit easy for DIY purpose
→ 404 Not Found
Justapoke's Avatar
Recommend Parts (Not Included):
Motor: 2212 KV1400
ESC: 30A
Servo: 9g*3pcs
Propeller: 8*4
Lipo Battery: 11.1V 2200-3600mAh 25C
(As listed by Banggood)
[edit]
Sep 02, 2017, 02:41 AM
→ 404 Not Found
Justapoke's Avatar
Reserved
Sep 03, 2017, 08:07 AM
Whats new on the V2 version?
Sep 03, 2017, 08:52 AM
→ 404 Not Found
Justapoke's Avatar
That remains the question for now..
Probably just some minor tweaks, I can't see anything huge different at this point.
Sep 03, 2017, 12:49 PM
Sure, I'll be following this one...
Jan 09, 2018, 12:25 PM
Any updates or has this been moved to another thread?
Jan 09, 2018, 08:02 PM
→ 404 Not Found
Justapoke's Avatar
No updates besides a slight price drop. Thread is not moved but there might be some post in the old v1 thread, I don't know.
Oct 23, 2018, 06:28 AM
The version v2 with the 2217 in 1250kv and a lipo 4s 3300mah with propeller in 8x4e is such correct to make the flight mid range (4 see 5km) ?
And how long will it be flying knowing that I will install a matek f411 wing with a GPS and fpv ?
Feb 28, 2019, 05:34 PM
mike_o's Avatar
Amazingly little activity in this thread, and even less in the original RMRC V1 thread Anyway, I just ordered one (KIT) from Banggood (has HobbyKing completely given up on FPV planes??) to be used as a FPV/UAV platform to join me on travels. Initially, I purchased an Eachine Fury wing for that, but that airframe is simply to unsettled to provide any decent video. Now I hope that I can receive the MSH in time for my next trip.
While waiting for the package to arrive, I have prepared the motor and electronics. A 2836mm 1120KV RCTimer motor will swing a Graupner 8x5 E-prop on 3S - most likely a MultiStar 3000mAh. An Omnibus F4 is loaded with Chibios Arduplane and ready for mounting.
Has anybody documented the efficiency of this plane? I'd like get to below 120mAh/km @3S (equivalent 90mAh @ 4S). And what is the sweet spot wrt speed?
While waiting, I'll take the liberty to post Koestel FPV's nice review (in French) to kick a little action into the thread:
Sonicmodell Mini SkyHunter V2 : Unboxing, Montage, Maiden (8 min 24 sec)
Feb 28, 2019, 05:41 PM
mike_o's Avatar
See above video. I think I heard Koestel quote 7km at 1000mah at 4S on the maiden flight, so with the 4S 3300mAh battery mentioned, you should be able to reach at least 20km (round trip / aller et retour), or 10km range. Endurance would be 20-30min depending on throttle behaviour.
Feb 28, 2019, 05:45 PM
mike_o's Avatar
I can see one major difference: A strip of CF embedded in the outer part of the wings. This should get rid of the hefty flapping, we saw in the V1.
Mar 01, 2019, 01:53 PM
→ 404 Not Found
Justapoke's Avatar
Well it's not something hard to do, to add a few carbon strips yourself. But nice they have done that job for us now.
Suprised this thread is not very bussy, still like the Mini Skyhinter a lot!
Mar 04, 2019, 02:23 PM
mike_o's Avatar
Banggood is taking their time shipping my plane. I most likely wont receive it in time for my overseas trip at the end of this week. Very disappointing.
Justapoke: could you tell me, what is the diameter of the tail boom CF tubes? I'm considering machining or 3-D printing an alternative mechanism. with the entire horizontal stabilizer rotating around a connecting rod and with the servo buried in the main wing...
Less battery weight required for balance and no fiddling servo wires thru the boom.
EDIT: Still not even active tracking from BG. I took the consequense and brought out an old trusted plane:
https://www.rcgroups.com/forums/show...&postcount=107
Mar 04, 2019, 06:18 PM
→ 404 Not Found
Justapoke's Avatar
Sorry mate, I don't have the V2 so have no idea what size it will be.
I do have a version 1 but might be a different.
Maybe someone else can jump in?
New Product Eachine Micro Skyhunter 780mm Wingspan EPO FPV RC Airplane BG Tobey FPV Aircraft 254 Sep 05, 2017 12:05 PM
Discussion Skywalker X2 X-2 Mini FPV Flying Wing EPO 950mm Wingspan RC Airplane PNP TheMadCADer Electric Plane Talk 1 Oct 03, 2016 01:46 AM
New Product Sonicmodell Mini Skyhunter 1238mm Wingspan FPV RC Airplane PNP Whitehouse FPV Aircraft 2 Feb 17, 2015 08:19 PM
New Product Sonicmodell Mako Flying Wing 1213mm Wingspan FPV RC Airplane PNP Whitehouse FPV Talk 0 Feb 10, 2015 08:01 PM
