Aug 31, 2017, 01:56 PM
Multiple esc's. 2 throttle 1 accessory
Hi, I'm working on a fishing boat. (with reel) My problem is I'm have a heck of a time operating a esc on any channel other than the throttle CH . I've disconnected the BES, and only use the signal line. All esc's are brushed. The Third Esc is to run the reel. Any ideas? thanks
Aug 31, 2017, 04:26 PM
I've had no problems on a boat with 2 ESCs and one servo, it just sits there and works. What does your setup consist of (radio, esc models), and what is the actual problem?
Sep 01, 2017, 09:40 AM
I'm trying to operate the third esc on a channel other than the throttle channel. Like you would with a servo. i have two 12v 12ah SLA running two viper 40's and the third esc is a no name brand. (link below) All on a HK6ch.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Sep 01, 2017, 09:06 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
Any proportional channel should operate the ESC once it is set up.
Switched channels, not so well...
Sep 02, 2017, 10:51 AM
The radio receiver thinks that everything plugged into it is a servo. If a servo works plugged into the channel wanted, the ESC, if it is working, should also work. Both require exactly the same signal. Some ESCs like to wake up to a valid neutral signal, some need the reverse switch on the transmitter to be set differently, depending on whether it was designed to work with Futaba or not.
To check whether a device works or not, a servo tester is the ideal thing. Amazingly cheap on fleabay, no real excuse for not having one.
"Using only the signal line." I hope that the ground line is still connected? Check the drawings in the "electrical discussion" thread.
Sep 05, 2017, 11:34 AM
thanks guys. i reattached the ground and all is well.
Discussion Why are my ESC's limited to 2-3s instead of 1-10s? Intentional ESC Abuse. nerobro Multirotor Drone Power Systems 3 Jul 05, 2017 07:00 PM
Discussion Is it normal for my ESC at 1/2 throttle to get really hot? G.F. Beurling Beginner Training Area (Aircraft-Electric) 16 Sep 30, 2016 04:04 PM
Discussion Why are my ESC's limited to 2-3s instead of 1-10s? Intentional ESC Abuse. nerobro Mini Multirotor Drones 0 Oct 21, 2015 09:32 AM
Question 2.4 1 Tx unit, multiple Rx's ?? AC-racing DIY Electronics 9 Nov 23, 2010 03:13 AM
Discussion 2 BL Motor's, 2 BL ESC's, 1 ESC hotter than the other!!?? Stuart Warne Power Systems 8 Nov 26, 2007 11:45 AM
