THOR V2 205mm T700 carbone frame - RC Groups
Aug 31, 2017, 10:28 AM
lokanaft's Avatar
Mini-Review
Hi to all! I want to tell you about my frame:
I design it for Runcam Mini and Runcam Split. Both of them fit perfectly and completely protected.
In the new version I made additional holes for fixing camera to avoid hitting frame into the video.
In the kit, all the screws are titanium. 3 different sets of screws for fixing PDB or FC. Spare M2 screw and nut for fixing XT60.
Standoff are 28mm.
In fact, the difference in the rigidity of this frame between T300 and T700 is not too great. Therefore, you can not overpay. But then you will get a frame from the first revision.
I do not get any benefit from sales. I just draw it for you. I will accept any constructive suggestions.
You can buy this frame on Ali.
Or there is a clone on the BG, but it's not from my Ali vendor.
This will remain after the frame assembly:
This is the weight of titanium screws for motors. If you buy them separately:
Sep 14, 2017, 04:40 PM
lokanaft's Avatar
Achieved speed 257 km/h on this frame =) https://www.instagram.com/p/BY-sT6Snhmw/
Sep 17, 2017, 01:48 AM
lokanaft's Avatar
Now you can see many clones on Ali - it's all frames of the first batch from the same carbon. It's all 2-way (0/90 degrees layers) carbon.
I do not understand why the chinese can not immediately cut from normal carbon.
Oct 08, 2017, 05:17 PM
I like the frame layout. Would concider it for split if the cf was good. Good idea to use titanium. You could use armattan productions even if it would cost more. The wait for THE split frame continues.
Oct 09, 2017, 10:44 AM
lokanaft's Avatar
This is prices from armattan:
It's price for 2mm top. They wiil make 2.5mm only, if order over 10.
And material:
Oct 12, 2017, 02:34 PM
lokanaft's Avatar
Good news. 45 degrees version in stock:
This means a maximum hardness, as I planned! =)
Nov 10, 2017, 04:00 PM
Desko
I want to buy this frame, but I donīt know what do you mean with 45 degres version, whats the difference between normal and 45 degres exactly?
Thanks.
Nov 11, 2017, 12:34 AM
lokanaft's Avatar
This means the direction of the main fibers in carbon. 45 degrees version much rigid, than 90.
Write in the comments to the order, that you need high-quality cut.
Dec 28, 2017, 02:16 AM
I really like this frame but is there some camera mount available for Yi or similar HD camera?
Dec 28, 2017, 02:37 PM
lokanaft's Avatar
You can find any 30x30mm mounting for camera holder or just use basic for strap
Dec 28, 2017, 02:40 PM
lokanaft's Avatar
My new setup:
But it's burn before fly:
Dec 29, 2017, 02:20 AM
Could you give me some specific link to any suggested mount?
Dec 29, 2017, 02:21 AM
You were trying 8s setup or what?
Dec 29, 2017, 01:33 PM
lokanaft's Avatar
You need for gopro session and what degrees? I can draw it for you.
Yes, it's 8S... Was...
Jan 02, 2018, 06:08 AM
Desko
Where is the high quality cutting?
Hi,
I order this frame adding in comments "High quality cutting" expecting that round edges. First frame came without rounded edges, I contact with supplier and sent me another one, this one even is worse cutting and no rounded edges...
New Product Thor 210V2 205mm X 5mm CFi Frame @75g Mini CAM mount - only 29$ sevet Mini Multirotor Drones 4 Sep 17, 2017 01:42 AM
New Product Thor 210V2 205mm - 5mm 75g Carbon Fiber X-Frame D Gains Mini Multirotor Drones 0 Jul 17, 2017 05:12 AM
New Product XS5 205mm Carbon Fiber Frame Kit for Racing Whitehouse Micro Multirotor Drones 0 Mar 05, 2017 02:32 PM
New Product Free testing Eachine ZMR250 V2 PCB Frame Kit Carbon Fiber With LED Board TS Banggood RC Mini Multirotor Drones 12 Nov 18, 2015 02:49 AM
Discussion 205mm Carbon Fiber Blades for T-Rex 250 and Gaui CSRC Tech Crew Electric Heli Talk 2 Jul 20, 2009 11:14 AM
