Sep 13, 2017, 05:58 AM
Originally Posted by TweakRacer
For the vTX it is supposed to be SmartAudio right (may need to determine the UART and set to SmartAudio)? So can configure via Taranis Lua script, or even with just via the BF OSD with any receiver (I fly Spektrum). Or am I all wrong here?
Also, can you top mount the lipo? Top plate looks cutout for dual straps.
As far as I know smart audio is not supported (Smart audio is a TBS invention and should only be used on their product, even if there is at least one VTX on banggood which claims to use it).
The VTX use ch 6 on sbus to change channels. Be care full! Do not switch it or use ch 6 in flight. I would and will disconnect it, because of possible malfunction and failsafe issues of the frsky rx (I will change the rx to a frysky xsr for having s.port telemetry and a better reliable signal).
Mounting the lipo on top is possible. I recommend using real bat straps and not the one which are included in the package .
Kind regards
Sep 13, 2017, 01:08 PM
TweakRacer's Avatar
Kind regards
Thanks for the quick reply. Ordered mine yesterday. ��
After watching more video reviews, and reading the PandaRC VT5804 documentation, it appears that this vTx does not have SmartAudio. Without starting a debate, suffice it to say that I agree with Joshua Bardwell that it is not illegal to use the SmartAudio protocol in the several EWRF vTx products on Banggood. I will be replacing the stock one with one of those.
Thanks for also confirming my suspicion that top mounting will work. I just hope the 1.5mm top plate will be strong enough. Are the slots cut for 16 or 20 mm wide straps?
By the way I found replacement frame sets on Aliexpress for $37, manufactured by Topacc.
Sep 13, 2017, 09:21 PM
You can't beat the price on this.... looking to get but looks like it won't give me 70degree camera tilt... can someone verify max camera tilt on this... and what's the fly weight without battery of course....
Sep 14, 2017, 06:47 AM
Frsky D8 binding
Dear all,
after binding the frsky D8 rx successfully (solid green light) channel movement and action (eg arming, throttle up ...) is only seen in BF receiver tab when sbus is NOT connected to the VTX. Therefore I removed the sbus connection from or to the VTX. Has anybody seen this too?
Stock VTX is not the PANDARC as mentioned in this thread but labeled as ARVTX200.
Any thoughts?
Sep 15, 2017, 03:27 PM
youtube.com searchfor danqfpv
Danq0's Avatar
neither straps will fit, the holes on top are only 14.5mm wide which means youll either have to cut the straps to fit, or bottom mount the battery, or stuff the battery strap underneath the frame
Sep 16, 2017, 05:07 PM
Hey Danq0 ..... I'm think'in about buying this.... please let me know max camera angle...Thanks in Advance!
P.s. to measure ... just use your smart phone protractor app. and hold it on the bottom while the camera lens is vertical for anybody looking for an easy way to measure your camera angle...
Sep 17, 2017, 06:13 AM
Camera angle is about 65 to 67^
Sep 17, 2017, 06:28 AM
BFight 210 - F3, CCD, OSD, a new benchmark? (review, work in progress)
Did anybody of you get correct current reading?
It seems that some modifications has to be done because of the Omnibus F3 pro version used in the BFight 210.
Any comments are highly appreciated.
Sep 17, 2017, 03:27 PM
<Marty>
Check out Project Blue Falcons video series on wiring the F3 series boards it has all the info you need and is very informative and easy to understand the way JC explains it..
I think this video covers it if not check out his play list..
Flip32 Omnibus: How To Power (F3/F4/Pro/NonPro) (11 min 33 sec)
Sep 17, 2017, 06:46 PM
Thank you so much! ... Decided to buy the frame and install a 2-stack f4 30a in it... gonna put rcINpower 2700's on it... also gonna use spacers and mount a runcam micro on it.... hoping to get it down to 235-240g's..... gonna be nice... just used that stack on my fuuton with this set-up and it's pretty awesome! ....
Sep 18, 2017, 12:47 AM
Danq0's Avatar
I cant believe I hadnt thought about downloading an app for that. thanks for the idea!
Sep 20, 2017, 12:08 PM
<Marty>
Lost my Bfight couple days ago and finally found it this morning, it hit a wooden fence and suffered some damage...right rear arm/motor missing with the wires ripped out of the motor and one lost rx which i planned on replacing anyway i have a pair of replacement arms i ordered that came in the other day...Does anybody know if or where i can get a replacement CCW motor? I did a google search but nothing found in the same size..
Or am i gonna have to replace all 4 or maybe use a different motor of the same size and KV ? Here's a picture it looks a bit different then when i took off..
Sep 20, 2017, 12:24 PM
Sorry for your heavy landing. If i would be in your situation the best solution would be to replace all 4 motors except you find the same ones!I could be that the Floverfly motors are just rebranded https://www.banggood.com/de/4X-Racer...op-buytogether
Sep 20, 2017, 01:00 PM
<Marty>
Was kind of thinking the same thing...Just not sure what motors to get, i don't want any of the racerstar motors , maybe i will try some of the ifly RD2205 not sure yet..Defiantly gonna be grounded for a while tho
Sep 20, 2017, 01:24 PM
RCX se2205-2600 are really nice... you can get them for $9.99 w/ out warranty .... I bought 9 so far without issue ... good thrust numbers for the weight and price... can't get better...
Mini-Review Lanchi Monster 76mm F4, OSD - FPV quad with a "real bite"? (Review work in progress) SoloProFan Micro Multirotor Drones 25 Dec 26, 2017 05:56 AM
Mini-Review IdeaFly IF88 - FPV Racer with Omnibus F4 (review) SoloProFan Micro Multirotor Drones 30 Dec 02, 2017 04:25 PM
Mini-Review IdeaFly 210 Grasshopper 230 kmh (??) FPV Racer (review, work in progress) SoloProFan Mini Multirotor Drones 21 Jul 08, 2017 04:53 AM
Mini-Review Eachine Falcon 210 Pro - Better than the first EF210? (review, work in progress) SoloProFan Mini Multirotor Drones 35 Mar 01, 2017 10:02 AM
Mini-Review IdeaFly 210 - RTF 210 FPV Racer (review, work in progress) SoloProFan Mini Multirotor Drones 8 Jan 12, 2017 03:53 PM
