Aug 29, 2017, 09:26 PM
Help!
Programming esc Seaking 90amp
Anyone in the OC ca that can help me I can bring my controller and my boat to you thanks
Aug 30, 2017, 12:40 AM
aka MicroModDude
microhelidude's Avatar
You try a program card?
Hobbywing program card for SeaKing Boat ESC's
https://www.offshoreelectrics.com/pr...-seaking-pcard
Aug 30, 2017, 12:59 AM
No I haven't ,...is this what I'm going to need to solve my problem because I get a series of beeps when I plug in the batteries. Also I thought you could could program from your transmitter ?
Aug 30, 2017, 01:06 AM
Fast electric boats maybe
Jeffro Bodine's Avatar
You can but its confusing counting all the beeps
Aug 30, 2017, 01:09 AM
Just Plane Nutts
AirDOGGe's Avatar
You can. I've never used a card, and fortunately the SeaKing and Turnigy Marine ESCs are the easiest.
Here's the manual. Programming instructions begin on page 2 in the lower left of the page: SeaKing 90A manual with programming instructions: http://ibuyrc.com/manual/07E-C-SEAKING.pdf
You turn on the transmitter and hold full throttle, then continue to hold throttle while plugging in the boat battery. The ESC will go into programming mode and you can then release the throttle back to the neutral, middle position.
At this point the ESC will play a brief melody followed by groups of one to four low-pitch beeps, then loop around to do it again over and over. Each set of beeps represents one of four programming options as shown in the manual (cell count, timing, etc..). When you hear the sequence of beeps representing the option you wish to alter, push the trigger forward towards the reverse/brake position for a moment to select it and then release the trigger back to the neutral position.
After selecting an option, you will hear a repeating series of higher-pitched tones representing the selections for each option. The tones will either be 1 to 4 beeps, a single, longer and lower pitched beep, or a long beep combined with one or more short beeps. Again, look at the manual to identify the combination of tones/beeps that represents the parameter you wish to set.
When you hear the correct sequence of tones for the parameter you wish to set, momentarily squeeze the trigger to the full throttle position and then release it back to neutral. The ESC will make a unique sound and then drop back into the selection mode again for the 4 main options.
Repeat the process to set all four options correctly fr your set-up (reverse/no reverse, cell count, LVC cut-off voltage and motor timing). When finished, unplug the boat battery to end the programming session. Turn off the TX last after unplugging the boat for safety reasons.
Here's a clip of me programming a similar 60A Turnigy using the same codes. This is just an example of the programming process and is not intended to replace the instruction manual.: https://youtu.be/lsi4z2Cms28?t=0s
Aug 30, 2017, 01:36 AM
Yes I tried so many times to follow those steps but I get beepbeepbeepbeepbeepbeepbeepbeepbeep
All I want to do is get my boat on the water 😬
Aug 30, 2017, 01:37 AM
Just Plane Nutts
AirDOGGe's Avatar
Try reversing the throttle on the transmitter. Make sure the TX is bound to the RX and that the pack is fully charged too.
Note that the manual has a troubleshooting section at the end for identifying the beep pattern you hear.
Aug 30, 2017, 01:55 AM
I put the throttle channel on the remote on reverse held the throttle at fill while turning on the remote plug in the batteries went into program mode on the ESC and my remote doesn't connect when I push the full brake and try to go into each of the parameters
Aug 30, 2017, 02:35 AM
Ok I finally got it I had to turn the knob on throttle trim back and forth until" just right "while pushing the trigger brake to go to parameters also doing the same when choosing the setting .the forward only and 6 cell count which are the only two parameters I could only adjust. So I left the other two alone (default). Everything works thanks Airdogge
Aug 30, 2017, 04:39 AM
you should still buy a program card so you can set all settings correctly. the good thing about the HobbyKing card is you can use it on more than just one esc size of the same brand.
Aug 30, 2017, 02:32 PM
aka MicroModDude
Where you plan on running your boat in the OC? I like to run Saturday or Sunday afternoons st Tri-City Park in Placentia that has a very nice lake.
Aug 30, 2017, 07:34 PM
yeah thats a great spot
Aug 30, 2017, 07:43 PM
microhelidude do you have a small bolt, because I do,maybe we can race ?
Aug 30, 2017, 07:54 PM
aka MicroModDude
Don't have one yet. Its on my list of to do's. Just have a few small and mid size boats I run like the FT011, FT012, and a couple others.
Discussion New Seaking Pro 120A ESC? Kenny_B Racing Boats - Electric 3 Mar 02, 2017 07:34 AM
Discussion Do you program those new small blheli ESC like the old ones with programming card? FlyingPancake Multirotor Drone Power Systems 9 Jun 08, 2016 01:35 PM
Help! Programming Seaking 180A ESC V3 Capt'n Crash Racing Boats - Electric 3 Mar 22, 2015 10:06 AM
Help! Program a SeaKing ESC cgbillb Dock Talk 4 Jun 21, 2011 05:53 AM
Question HIFEI 90amp HV esc dusmmdb34 Electric Ducted Fan Jet Talk 2 Mar 18, 2009 10:29 PM
