Aug 29, 2017, 07:01 AM
Mini-HowTo
HELP! How do I Build This 2S Brushless Whoop?
Hello,
I've been dying to build this RakonHeli 66mm 2S brushless whoop.
The problem is, I have no idea how to build it correctly.
- How do I wire-up the ESC?
- How do I connect the ESC to the FC?
- How do I attach the vtx and camera to the FC?
- How do I add a buzzer?
- Are there any configurations in Betaflight I should tweak?
- Are there any other things I should be aware of when building it?
I have a pretty vague idea how to start. I watched a few build videos of other brushless micros, but I can't seem to find a specific tutorial for this quad.
If anyone can help me out or provide tutorials, I would be eternally grateful.
Here are the components (minus the obvious parts, of course)
Aug 29, 2017, 04:27 PM
aeropuppy's Avatar
The BR1103 8000KV motors are for the 2S 76MM frame.
The recommended motors for the RKH 66mm 2S are 0703 8000KV or 0703 10000KV and don't forget props and battery wires & connectors (See the RKH 2S 76mm BNF for battery wire details https://www.rakonheli.com/rakonheli-...bnf-frsky.html) .
I'm building the 2S 66mm DSMX soon; parts on order, using the FC & ESU you listed and recommended by RKH with 0703 10000KV Boldclash motors and DSMX RX.
Since I have the 1S 66mm BNF and 2S 76mm BNF versions, which uses the same FC, RX & ESC, I'll be using them as reference for the 2S build however there are good wiring diagrams on the RKH site. (I like the design so much I wanted a 2S 66mm version and decided to build one)
Schematic for wiring the FC here: https://www.rakonheli.com/furiousfpv...shless-fc.html
FC manual Here: http://furiousfpv.com/document/Manua...oop_Manual.pdf
ESC Schematic here: https://www.rakonheli.com/fishpepper...-esc-7937.html
Sorry I don't have more info...this will be my first complete build.
Hope this helps.
Aug 30, 2017, 04:17 AM
ADAMBOMB FPV did a complete build of this on youtube....3 part build series.
Discussion THIS video...how do they do it? krachall Beginner Multirotor Drones 62 Nov 01, 2018 08:27 PM
Discussion Help: How do I control this Gimbal Motor to turn slowly.. danmano DIY Electronics 6 Mar 20, 2017 08:00 AM
Discussion How Did I do for my first (semi) custom Whoop Build? fpvnoobe Micro Multirotor Drones 4 Nov 01, 2016 08:04 AM
Question How Did I do for my first (semi) custom Whoop Build? fpvnoobe Micro Multirotor Drones 0 Oct 30, 2016 07:28 PM
Discussion HELP PLEASE - How do I repair this beamerboy Electric Sailplanes 8 May 27, 2016 08:24 AM
