New Product
Holybro Kopis 1 FPV Racing Drone
Holybro Kopis 1 FPV Racing Drone 5mm Arm w/ F4 5.8G 40CH Dshot1200 RunCam Swift 600TVL Cam PNP BNF
LINK HERE Kopis is a high-performance FPV racing drone from Holybro, low-deck design means centralized mass and excellent handling. Stretched-X motor layout is the choice of top racers because the rear props are further from the "dirty air" coming from the front props. The result is smoother cornering and higher top speed. The FPV antenna is in a unique location behind the quad, to protect against damage. Kakute flight controller and Atlatl video transmitter give perfectly integrated control of all quadcopter systems. Tmotor AIR40/2450kv motors give a great balance of raw speed and flight time. They won't kill your batteries either! Kopis gives all the performance, looks, and durability of a hand-built machine, without ever having to pick up a soldering iron! We provide PNP version (without receiver) and BNF version (with Frsky XSR receiver) for choice. Description: Brand: Holybro Item name: Kopis 1 FPV Racing Drone Wheelbase: 210mm Integrated bottom plate and frame arm: 5mm thickness Other plates: 2mm thickness Weight: 300 grams without battery ESC: 30A BLHeli_32 (DSHOT1200 compatible) support 2~6S LiPo Motor: T-motor AIR40 2205 2450KV Features: 5mm full 3K carbon fiber Twill Counter-sunk screws for great appearance and smooth finish Kakute F4 FC with soft-mounted gyro for great filtering of vibration Betaflight OSD included. Monitor voltage and battery capacity in your FPV goggles. Change PIDs and Rates using your transmitter sticks 5.8GHz 40CH atlatl video transmitter Control the VTX channel and transmit power from the OSD using your transmitter sticks. No more button-pushing. Programmable LED board controllable in Betaflight. Buzzer included. RunCam Swift Mini FPV camera. Adjustable camera tilt from 0 degrees to 90 degrees uptilt. Serial receiver supported (SBUS, iBUS, Spektrum). Legacy PPM and PWM receivers not supported. |
Thread Tools | |
Similar Threads | |||||
News | Holybro Shuriken X1 ARF Racing Drone | RCG_Jason | FPV Racing | 138 | Feb 03, 2019 07:55 AM |
New Product | Holybro Kopis 1 - 300g BLHeli_32, Kakute, BF switchable VTX BNF/PNP | D Gains | Mini Multirotor Drones | 0 | Aug 29, 2017 03:09 AM |
Link | Holybro Shuriken 250 RC Racing Drone ($188.99) | r3crac | Vendor Talk | 2 | Mar 13, 2017 10:05 AM |
Discussion | My first racing drone (Holybro shuriken x1) | Jonny3773 | Mini Multirotor Drones | 3 | Feb 22, 2017 09:27 AM |
Discussion | XJB-75 75mm F3 5.8G 40CH Mini FPV Racing Drone BNF 4 In 1 ESC Oneshot 600TVL 1/4 Cmos | scousethief | Banggood.com | 9 | Feb 09, 2017 10:26 PM |
