Jean Bart drive line - RC Groups
Aug 28, 2017, 03:19 PM
Feetech FS90R continuous rotation servo as motive power for Jean Bart.
Aug 28, 2017, 03:25 PM
I will attempt to use a modified Feetech FS90R for the drive line of Jean Bart.
I have removed a gear wheel and glued to other gear wheel together.
Original gear wheel configuration.
Aug 28, 2017, 03:40 PM
One gear wheel removed, and the two remaining glued together, with a brass porthole as distance keeper.
Does it work... Well yes, but the rotation is rather slow.
Maybe to slow, but on the other hand i've not used this rx(Tactic TR1424) and corresponding lipo for over a year.
So i'll charge the lipo and try again.
The propeller is the original one from the kit with a 2mm shaft fitted in a Ø 2/3 mm brass tube. Thats gives some friction and might have to be improved.
Finally a kitchen sink test. It floats very high and I expect dome ballast to be needed, or maybe a bigger lipo.
Cheer Søren
Discussion Ceramic Drive Lines Amp Abuser Racing Boats - Electric 13 Dec 22, 2016 04:05 PM
Discussion "Paul Bart" whips out his heater for assault on a traffic cone Curtis in Texas Life, The Universe, and Politics 3 Oct 06, 2016 02:31 PM
Discussion Barts to blame! Stuart A Life, The Universe, and Politics 5 Mar 31, 2016 10:49 PM
