UK WOT4 to be electrified
OK ... I have a WOT4 Mk2 .... IC / EP version.
I have two power systems on bench ... ASP 61 Glow 4250 650kv Turnigy. Originally I was going to fit the ASP Glow ..... Guys at my club have been discussing with me final power solution for my WOT4 ..... 4:1 in favour of E-Power !! So ...... its a 4250 650kv / 4 - 5S setup back again on the cards !! Just need to build a 32mm extension motor box to take the motor. Laser cutter in ops !! Nigel |
OK ....
4250 650kv .... 5S 3000 ..... 50A ESC .... 13x8 prop with alloy spinner 4 standard servos The elevator and rudder servos will be fitted to rear of fuselage to shorten control rod span and give direct control. No added ballast as the servos in rear compensate for the bigger motor up front. AUW ready to fly with the 5S in .... 2.22kg ...... which is less than I expected .... Photos later once all completed. Nigel |
I also amended the tailwheel set-up to Chris Foss original where he used a rubber band as shock absorber link ... just means bend the stock wire close to the plastic mount horizontal to bottom of rudder ... bend a hook and cut of excess. Then embed a U wire into rudder to take the band ...
Nigel |
She has extended servo arms - so once trimmed / sorted - I can then dial her up for extreme antics ....
Nigel |
I have one of the Sullivans that just has an inline spring along the bottom of the rudder and it's just not strong enough to keep the tailwheel aligned in a lot of crosswind. The Chris Foss solution will let me use the same basic setup, but improve the centring tension. Hope the maiden goes great! ![]() |
I use that tail design on most of my models as it really gives you good service but stops breaking rudders !
I really hate the setups where you embed the wire rod into the leading edge of the rudder ... has no shock absorbing or damage limitation at all. OK .......... Thrust tests : On the 5S - ESC is about on its limits .... so may swap out for larger. 52A WOT and 900W But static thrust is a whopping great 3.5kg .... for a 2.2kg AUW ... Next is the twin 4S ... 38A WOT and 530W Static thrust 2.35kg .... so still enough to be interesting !! Nigel |
just gave it a 5 min flight .... evening and wind died just enough to get her across the road for a quickie ...
PERFECT !! 5S and 4250 dragged her up there and she flew a dream ! Flew a full 5mins as calculated .... LiPo came down at 42% ..... so that gives me between 6 and 7 mins with a lot of low throttle work ... 5 mins with spirited. Stupid me - I fired up my headcam - but forgot to start it recording ! Only niggle - Why can't any factory get cowl blocks right so screws don't pull out or blocks split ! I just have to fix the top cowl screw block ... Nigel |
Here's flight with 3S packs .... I made mistake - should have been 4S ... but in the rush to power up - picked up wrong ones !!
Then on 4S as it should have been !
But the ultimate of course was with 5S .....
Am I happy ? You bet !! Nigel |
The servo extenders I had on Rudder and Elevator arms have now been removed, standard arms with same stroke length of horn / arms now .... Tx DR full rate increased to compensate and regain resolution.
Wheels - Sullivan Skylite 3" have been fitted to replace the smaller stock wheels, that should help with the nose overs on grass. Just waiting for weather to improve so I can go fly her again. I had plain forgot how good the WOT4 is ... now its making me hanker after the AcroWot - to replace my Zlin Z50 I crashed. Nigel |
Electric fired smoke being added now ....
Canister to each UC leg ... the trigger is powered and controlled via the Rx ... Flick Gear switch on Tx and #1 smoke ignites ..... flick gear switch again and #2 smoke ignites .... the trigger being sequenced. The canisters require a short length of fuse in a small ring round the detonator, a plastic card piece taped over to hold against the solid fuel till it ignites. Hopefully once weather clears - I shall be able to test and video ... Nigel |
The 5S combo pulled the motor box apart during a flight ... but luckily the damage on crashing was minimal.
I decided to replace the ply box with alloy Stand-offs fixed to the firewall which is suitable for Glow motors. I repositioned the threaded fixings and bolted up .... she lined up perfect with just enough gap spinner to cowl. The thrust line was slightly less down than previous so I expected a slight trim adjustment ... As usual she took off like a scalded cat ! 5S makes her 'ballistic' ! But the trim was spot on literally ... and she tracked nicely showing the prop line was good. Here's the video ... (I think battery ran out on my Headcam and why the video cuts short ... )
Nigel |
Thread Tools | |
Similar Threads | |||||
Discussion | WOT4 from UK ...... | solentlife | 3D / Fun Fly Fuel Planes | 4 | Aug 28, 2017 09:42 AM |
Discussion | UK iconic model ... WOT4 Mk2 .... | solentlife | Sport Planes | 1 | Aug 25, 2017 06:45 AM |
Discussion | This must be the southern part of the UK. | RCWorks | Life, The Universe, and Politics | 11 | Jun 30, 2017 06:55 AM |
Discussion | What is this, a shooting in the UK? Can't be | kenpoprofessor | Life, The Universe, and Politics | 57 | Oct 13, 2015 03:52 PM |
Discussion | UK Timeless classic (WOT4) - Mini 4 | solentlife | Foamies (Scratchbuilt) | 3 | Aug 05, 2013 01:57 PM |
