This thread is privately moderated by eagle60, who may elect to delete unwanted replies.
Aug 27, 2017, 10:24 AM
eagle60's Avatar
Wing ribs: alternative materials
After I saw in a ChillPhatCat's post a pack of balsawood ribs for a wing I have been thinking a while of the possibility to use cheaper materials for this components. Actually in Italy Balsawood is expensive and for sure it is possible to save something at least for rectangular (untapered) wings.
First alternative material is depron, which is also very easy to work : cut as many rectangular pieces as required ribs just a little bigger than the ribs themselves; make 2 ribs in playwood or aluminum as per cutting a foam wing; pack everything together with 2 threaded bars (2 or 3 or 4 mm depending on the rib size); finally cut the ribs with the hot wire. You can foresee also the slots for the spars (make them a little smaller as the wire will "eat" some material and the spar must be tight) and also eventual lightening holes. Off course the depron could be 3 or 6 or other mm size depending on ribs and wings size.
The second alternative is to use foam, but not the normal white foam, the more compressed one (see photo) that could be found yellow, blue, green, pink and maybe more colours : you just cut a piece of wing with the playwood ribs previously described and then slice it on the thickness you need.
It should be simple and easy.
Mini-HowTo A Wing Rib Cutting Jig For Constant Cord Wings. iflylilplanes Balsa Builders 9 May 27, 2019 05:28 PM
Discussion Alternative mold making materials? BiggsDarkLighter Sailboats 14 Oct 28, 2016 12:23 PM
Discussion Wing Rib Spar Material Rob_P Vintage & Old-Timer Designs 6 Sep 14, 2011 11:17 AM
Discussion Wing rib material options jwhitacre Sailplane Talk 5 Oct 23, 2009 10:23 PM
Discussion Trussed wing rib materials imfrankyj Fuel Plane Talk 1 Feb 23, 2008 10:53 AM
