Aug 25, 2017, 10:59 PM
Black_Angel's Avatar
Curtis Youngblood Rave90ENV - 700 Electro with Align 800MX
I got My Rave90ENV a week ago or so. ENV means its frame take both Electro And Nitro, and i will do both. So the Electro setup will come here, then my Rave90ENV with ASP91 Nitro who will be converted to gasser will be posted in Nitro Heli HERE
I just ordered Align 800MX 440KV for the electro version of this heli
The general setup for the heli in both power setup is:
Cyclic servos X3 : JX PDI-6221MG
Tail Servo: JX Servo PDI-6208MG
FBL: Full size Kbar ( for gov on Gasser version)
RX: Going to test out a 8CH FD1000 Receiver Long Range with sbus and telemetry support on a 500 first, not shure yet if i use this or i get one of my good old FrSky V8FR-II
RX/fbl power: 2 x 3.2V 3200mAh LiFePO4, I will built this 2s package with 2 single round LiFePO4 with IN4007 Rectifier Diodes to get voltage at 6v
Electro setup:
Esc: YPG 120 hv
Lipos: 2x6s 5000 as 12S
More update and photos soon
BA
Aug 28, 2017, 08:37 AM
Electro setup:
Esc: YPG 120 hv
BA
BA,
The 1N4007 is only rated at 1 A, maybe i'm wrong, but it isn't enough to power the servos...
https://www.diodes.com/assets/Datasheets/ds28002.pdf
Aug 28, 2017, 08:49 AM
Hi Daniel, thanks for the info, i have no experience with 1N4007, i found the solution in Rcexl single ignition as solution to get as near 6v as possible, LiFePO4 is listed with 3.2v. First solution im thinking of is use 2 leads from cells, one with diode for ignition and one without for rx, servos and kbar.
BA
Aug 28, 2017, 09:40 AM
BA
BA,
I think you need a BEC, because the servos has a Umax = 6V.
Brand:JX
Item:PDI-6221MG 20KG Large Torque Digital Standard Servo
Dead band: 2μs
Working frequence: 1520μs / 330hz
Operating Speed (4.8V): 0.18 sec/60
Operating Speed (6V): 0.16 sec/60
Stall Torque (4.8V): 17.25 kg.cm (239.55oz/in)
Stall Torque (6V): 20.32 kg-cm (281.89 oz/in)
We need pics!
Aug 28, 2017, 09:45 AM
Yes photos will come, i see no problem with 6.4v for the servos..
BA
Aug 28, 2017, 10:59 AM
BA
Yes, they should be ok...
A Little off topic, overvoltage in brushless motors isn't a problem, you can use a 4S motor with 6S however should be give a close look to the current. Or it burn out.
Aug 28, 2017, 11:12 AM
Yes i readed many uses 2s lifepo4 on 6v servos. Its also said the 6v limit is counted as 5x NiCd who have a max 7.2 when fully charged. I also see some uses 2s lipo direct on 6v servos, i would maybe not do that, but 2x lifepo4 im fine with.
This is by the way my first 12s setup.. All my other large helis are 6S and on bec
BA
Aug 28, 2017, 12:47 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Just a suggestion.. Unless you already have the servos why not go the HV servo route? These days they arent much if any more expensive, but they make powering the electronics much easier as you can just use a bog standard 2S LiPo.
I never use anything but HV servos these days, it just seems to be the way servos are going.
Aug 28, 2017, 12:58 PM
Hi JPF, good point, but i need to be near 6v for ignition ( this heli built is combined nitro and electro setup) and i already buyed servos.
BA
Oct 12, 2017, 10:05 AM
Rave photos
Will upload some Rave photos here
Nov 05, 2017, 01:41 AM
Here is some new photos and some update. Im also planed to fly Rave as gasser, but first it will fly as electro. Got most ready now, main head and tail is serviced and new bearings in bladeholders so all will be smooth.
BA
Nov 05, 2017, 02:01 AM
Atomic Skull's Avatar
BA
They had a gasoline version of the Rave? I thought it only came in electric and nitro?
Nov 05, 2017, 02:22 AM
Correct Atomic, this is a project to run nitro engine with gassoline, just started it here: https://www.rcgroups.com/forums/show...R#post38577201
BA
Nov 13, 2017, 08:48 PM
Old new guy
TheX's Avatar
Definitely going to follow this.
Nov 13, 2017, 10:08 PM
Thanx for following the trad TheX, busy getting new home ready but soon thee will be more progress both on the el version here and on my other tread with th ASP91 engine.
BA
Discussion setting up DX6i with Curtis Youngblood Rave 450 Robert Boudreau Electric Heli Talk 3 Apr 22, 2015 06:57 AM
Alert curtis youngblood 325mm blades are awesome driftinsequence Mini Helis 6 Sep 14, 2007 11:53 AM
Question Curtis Youngblood's Motor? Baron Johnson NeuMotors 4 Aug 05, 2007 08:10 PM
Discussion Curtis Youngblood and Marcus Kim at Joe Nall 2006 video 34Ford Joe Nall 7 May 23, 2006 06:10 AM
