Maxima 9 CH Receiver - RC Groups
Aug 24, 2017, 12:58 PM
I have a need for a 9 CH receiver without Telemetry . My Tx is a Evo 9 converted to 2.5 ghz with a Hitec Spectra module.
Can I use the Maxima 9 ch receiver driving a mixture is analog and digital servos instead of the Optima 9 ?
Aug 24, 2017, 03:21 PM
All Thumbs
Ranald's Avatar
Hi Sportflyer,
I'm certain that the Spectra module will not bind/drive the Maxima receivers.
The Spectra is perfect for Optima and Minima receivers. The Optima 9 will do super.
It's my understanding that if you want to use the Maxima 9, you'll need to drive it with the Aurora 9X and use low-deadband digital servos.
- subject to correction by Hitec, of course.
Aug 24, 2017, 08:50 PM
I have been using Optima and Frsky Hitec Minima compatible RX. They work great.
After reading the Maxima RX info in more detail , you are right that the Maxima will only work with Aurora9X and digital servos.
Awaiting Hitec inputs to confirm.
Last edited by sportflyer; Aug 24, 2017 at 09:46 PM. Reason: add more info after checking.
Aug 28, 2017, 10:28 AM
Xpress..'s Avatar
This information is correct, the Maxima line of receivers will only work with Hitec transmitters that use an integrated 2.4Ghz module (Aurora 9X, Flash 7, Flash 8).
Question binding maxima receivers the_crack_fox Hitec/Multiplex USA 1 Aug 04, 2017 08:16 AM
Discussion Low cost 7-9 ch Spektrum DSM2 or DSMX receivers Zerts Radios 1 Apr 08, 2017 07:35 AM
News Hitec Maxima SL 9-Channel Micro Receiver Low Latency Receiver for Flybarless Systems ndfly700 Electric Heli Talk 12 Apr 27, 2016 03:54 AM
Careful! Hitec Maxima 6 XL Not Compatible w Aurora 9 Tranny LSF226 Radios 3 Feb 08, 2016 10:42 AM
Discussion Hitec Aurora 9X telemitry with Maxima Receiver? Barnaby01 Radios 0 Jan 13, 2015 06:06 AM
