Jumper T8SG Multi-Protocol 2.4G 10CH Compact Transmitter with 4 in 1 module - RC Groups
Aug 22, 2017, 10:24 PM
drone contribute
YSeph's Avatar
I just find this Transmitter from Jumper:T8SG
It's really like Futaba appearance
The Jumper T8SG Multi-Protocol radio features a compact size and a host of protocol options all built in to one product. The CC2500, NRF24L01, A7105 and CYRF6936 RF Chip modules are all integrated with the main RF Module. Various protocols can be quickly and easily selected from the model menu allowing you to bind the radio to just about any major protocol in todays market. The T8SG also features sound and vibration alerts, back lit LCD display, smooth gimbals and assignable switches.
The T8SG is a truly portable solution for all your models without compromising on that real radio feel and functionality. Control all your favorite RC items from one radio and have more space for models!
DeviationTX Software comes pre-installed with the T8SG.
Description:
Brand Name: Jumber
Item Number: T8SG
MCU: STM32F103RCT6
Storage: 25VF016B (2MB)
4IN1 RF chip: JP-4MP(CC2500, NRF24L01, A7105, CYRF6936)
Transmission power: adjustable 0-150mw
Display screen: 128*64, 1.7 inch LCD
Channels: 10 (up to 12 depending software)
Prompt mode: sound and vibration
Power supply: 4*AA or 2S Lipo
Dimension: 188*151*86mm
Weight: 338g (not include battery)
RF Chip Data
Cyprus Semiconductor CYRF6936: DSM/DSMX, Walkera Devo
Texas Instruments CC2500: FrSky, Futaba SFHSS
Amiccom A7105: FlySky, FlySky AFHDS2A, Hubsan
Nordic Semiconductor NRF24L01: HiSky, Syma, ASSAN and most other Chinese models
Aug 22, 2017, 10:56 PM
BGjim's Avatar
seem great!
Aug 23, 2017, 02:20 AM
Sumfear's Avatar
Let me choose between this and Taranis X7... ummm... ummmm... hard to decide....
Aug 23, 2017, 04:40 AM
SeByDocKy's Avatar
THis is the perfect radio !!!!! compact, with the 4-in-1 !!! sound and vibrations feedback and deviationTX . 12CH ok lack maybe the voice ......
WANTTTTTTTTTTTTTTTTTTTTTTTTTTTTT ))) This radio will be the next hot cake of BG (Jumper is a OEM brand of BG)
Latest blog entry: Youbi XV-130 130MM FPV Racer
Aug 23, 2017, 12:45 PM
tHe n00b on YouTube
Wow! Compact 10CH 4-in-1 radio. All the Deviation features in a smaller foam factor. Perfect!
Aug 24, 2017, 07:18 PM
This looks like the perfect radio for park flyers, small, cheap and light.
Aug 25, 2017, 06:03 AM
139 and still buying
Serge Roth's Avatar
Access to the USB plug is lousy thought tru, one has to remove the back cover to get to it.
Aug 25, 2017, 09:21 AM
tHe n00b on YouTube
Running same Devo 7E Ultimate deviation firmware.
Trainer / Simulator / PPM output port and a 2dBi removable antenna.
Around the same size as Devo 7E.
Run on 2S lipo.
Why is the USB port hidden inside the case?
MCU close up. STM32F103RCT6 / 256KB MCU
Major flaw:
1. USB Port is hidden inside the case
2. Poor gimbal/rocker design that has no bearings
Original blog post by deviationtx member dc59 at http://rc-dc59.blogspot.my/2017/08/d...mper-t8sg.html.
Aug 26, 2017, 02:26 AM
Hi,
can you change the Mode from 2 to Mode 1???
Thomas
Aug 26, 2017, 05:28 AM
F3A Team Finland
Finnspeed's Avatar
Hehe, nice little radio but why did they have to copy Futaba-style model name and appearance? That seems downright silly to me.
I would recommend getting the Walkera version instead.
Aug 26, 2017, 05:38 AM
Serge Roth's Avatar
The Devo 7E has no multi-module, a MCU that needs upgrading because of limited memory, limited range, as it is only sending with 10mw (it can be modified for more mw, but the mod is only for strong nerves and very steady hands), and has a crappy antenna.
Aug 26, 2017, 07:54 AM
tHe n00b on YouTube
Devo 7E can be modded with 4-in-1 module but you will need to solder one wires to the MCU pin which is a delicate process. Again you need to do another ultra delicate process of MCU upgrade to get to where this new Jumper TX already at.
This is a great compact all in one TX despite the Futaba style TX appearance and model name. I would say, total newbie friendly TX that no serious modding required as compare to what you need to mod with a Devo 7E.
Aug 26, 2017, 06:34 PM
I just wanna fly, fly, fly
Brainstorm's Avatar
Brilliant! I couldn't help it and pre-ordered mine a few days ago.
ltwvince: Thank you for all the pictures!!! I saw that the measurements match the Devo 7e almost exactly. Seeing the two side-by-side has me even more excited.
Gimbals with no bearings?!? WTH?!?! Hopefully we will find a way to upgrade the gimbals.
I can live with the hidden USB port. I'll probably just find an extension cable or cut a big hole in the back of the TX.
PS: Obviously we'll have to add some 3-position switches as well. Looks like all the stock switches are 2-position, like on the Devo 7e.
Aug 26, 2017, 06:42 PM
Reavski's Avatar
Originally Posted by Brainstorm
Gimbals with no bearings?!? Hopefully we will find a way to upgrade the gimbals.
What would be nice is if the gimbals were interchangeable with the 7E's. I upgraded my 7E quite a while ago with just the NRF module (before 4-in-1s or even 3-in-1s were even a thing), and I wouldn't mind cannibalising it for parts at all. Hardly ever use it beside my 4-in-1 Devo 10, but that compact size cannot be underappreciated.
Aug 27, 2017, 02:09 AM
tHe n00b on YouTube
I'm just reposting pictures from dc59 post.
I hope they do come out with some gimbals for upgrade. Even Walkera doesn't have gimbal replacement that I'm aware of.
Hidden USB port is not a big issue since is quite easy to mod with some extension cable.
You're right about the switches, they all do looks like 2-position switches.
New Product [Updated]Flysky FS-i6X 2.4GHz 10CH AFHDS 2A RC Transmitter --FREE TEST BG Tobey Radios 295 Sep 05, 2017 05:07 PM
Discussion Multi protocol module for FLYSKY I6 etc etc scousethief Banggood.com 50 Jul 22, 2017 11:06 AM
New Product (Updating)New Version Flysky FS-i6S 2.4G 10CH AFHDS 2A Transmitter With FS-iA10B BG Well Mini Multirotor Drones 189 Jun 28, 2017 07:51 PM
Cool 【ONLY$49.99】【Last day】Flysky FS-i6S 2.4G 10CH AFHDS Transmitter With FS-iA6B Receiver BG Tobey Banggood.com 1 Mar 09, 2017 10:50 AM
Discussion Flysky FS-i10 10CH 2.4GHz AFHDS 2 LCD Transmitter with Receiver BG Tobey Radios 4 Aug 28, 2016 05:28 AM
