Apr 14, 2018, 02:42 PM
Have spacers?
Pierre has a speadsheet on his website for loading. Make sure ballast steps dont affect cg.
Good luck on the maiden!
Apr 14, 2018, 02:50 PM
Originally Posted by curdman
Have spacers?
Ok, I will take a look at it. I will test out ballast positions tonight. Somebody posted that this bird doesn't require as much ballast as the normal precision.
Apr 14, 2018, 03:05 PM
Alvaro Silgado's Avatar
I’ve coded an Excel macro to calculate the best ballast distribution to keep the plane’s C of G as close as possible to the empty C of G position:
https://www.facebook.com/permalink.p...00011675437816
Apr 14, 2018, 03:20 PM
Very generous sharing!
Apr 14, 2018, 03:32 PM
My pleasure!
Apr 14, 2018, 03:43 PM
Thanks Alvaro this will definitely help me! Scott, you getting a P2?
Apr 14, 2018, 04:03 PM
I wish.
Apr 16, 2018, 11:08 AM
Ja9
Ja9
Made some simple ballast spacers on the 3d printer. Bright orange for high visability if dropped in grass.
Apr 16, 2018, 11:11 AM
Exactly like mines!
Apr 16, 2018, 02:07 PM
I completed maiden flys great! Need to go through ballast, make spacers , double check cg.
Apr 19, 2018, 12:59 PM
My ballast kit is a little different, has 4 half large pieces and 4 half small pieces to find tune cg. So are you guys using the same amount of ballast as you would typically use on a precision or using less. Jiri was saying he was using half as much. So if both planes weighed 80oz. and the Precision was at 100oz, the P2 would be at about 90oz.
Apr 20, 2018, 02:50 PM
So, so far the only change I would have made is to make the bottom of the wings white or white black, so I can flip the plane upside down and not have to put covers on all the time. For me that is going to be a PITA.
Jun 01, 2018, 03:53 PM
Ja9
Ja9
2 x Pike Precision 2 ready to fly
My 2x Pike Precison2 are ready to fly.
The red one is a UMS layup and the white one is a C80 F3F layup.
Weight is almost similar on both at around 2180g. cg at 95mm
Sep 07, 2018, 01:30 PM
Well :-) after few months flying the PP2, it is the most agile machine I get since century :
Now my CG is 98 empty and my ballast sheet moving lightly forward my CG when ballasting, 1kg is enough in most of the conditions, but the glider can fly much heavier :-)
Pike Précision 2 - Samba Model (1 min 38 sec)
Sep 07, 2018, 01:31 PM
Once more ;-)
Pike Précision 2 - Practising under the rain (1 min 12 sec)
Alert Win a free Xplorer/Pike/Icon 2/or SMM or Kennedy Composites surprise. aussief3b Sailplane Talk 1 Mar 13, 2012 10:42 PM
Discussion Pike Brio 2.4 instal bluffman Multi Task F3X 4 Oct 24, 2011 11:45 PM
Discussion 2.4 receiver in Pike Perfect 3810 Multi Task F3X 17 Aug 05, 2011 12:05 AM
Discussion Precis Canard? Rain City Flyer Thermal 0 Aug 12, 2009 03:59 PM
Discussion 2.4 in a Carbon Pike Perfect Bruce T. Sailplane Talk 16 Mar 05, 2008 04:30 PM
