MPA-4P Module - RC Groups
Aug 22, 2017, 02:38 PM
Pro Bro ozzy
Tim B's Avatar
Question
MPA-4P Module
2 question about the new MPA-4s.
Will the original MPA and new MPA-4P is a Multi-Port Safe Parallel Module share the same MPA-to-Cellpro 10XP Interconnect Cable?
And
Do I guess right that the battery balance plugs connect directly to the MPA-4s balance ports? No need for any other connectors.
Thank for the info.
Tim
Aug 22, 2017, 04:16 PM
And
Thank for the info.
Tim
Yes to both.
The input (charger) side is a standard XH 10S connector, just like the 6 port MPA.
The output connector is a "universal" XH connector which allows any standard 2s-8s XH battery balance lead to connect directly.
Aug 22, 2017, 05:58 PM
Pro Bro ozzy
Tim B's Avatar
Thank you..
Time to place an order.
Tim
Help! 90mm EDF with 3800kv 4p with 100A turnigy ESC Carrface Power Systems 8 Feb 23, 2017 10:38 AM
Discussion Help in understanding Powerlab 8 and MPA and parallel charging in general silentflyers Batteries and Chargers 9 Feb 03, 2016 09:28 PM
Discussion Do You Have A Revolectrix GT500 & MPA Board splais Batteries and Chargers 5 Feb 02, 2016 07:14 PM
Discussion Questions on Fuel Tables and on MPA schnellschnell FMA Direct 1 Jan 14, 2016 05:49 AM
Discussion MPA Safe Parallel Module KAW_Concours FMA Direct 2 Aug 21, 2012 08:15 AM
