Airbot Typhoon32 35A 4in1 ESC - RC Groups
Aug 22, 2017, 01:23 PM
All new 4in1 ESC with 35A with the following specifications:
4in1 ESC with 30.5x30.5 mm Mounting holes, supports DSHOT 1200, BLHELI32 firmware.
Link to Airbots store
Update:
The Typhoon32 V2 has been released with an extensive capacitor bank, also capable of 6S. I would recommend this version over the V1.1.
If you want to buy on banggood, then the holybro tekko32 is the same as the typhoon32, but they replaced some of the ceramic capacitors with tantalum capacitors. This increases the filtering, but is more costly to manufacture.
Link to Holybro Tekko32 at banggood
Link to Holybro Tekko32 with Kakute FC combo
Features:
32bit ESC with BLHELI32 firmware
Supports 2-4S lipo input (A shame it doesn't support 5S)
4PWM input
Voltage output (VBAT)
NO BEC
Supports oneshot / Multishot / Dshot PWM
Mount holes 20x20mm (Must be a typo)
Supports damped light
External capacitors needed (is included)
$59.99
It seems that it has current sense on both the input and each ESC output. This shouldn't be noticeable anyways (62.5mV drop @ 4x25A compared to 50mV @4x25A on normal current sensing PDBs)
Aug 29, 2017, 09:11 AM
It is 6S compatible, been updated on the page now.
Sep 03, 2017, 09:38 AM
RC Hobby Enthusiast
blackmennewstyle's Avatar
I'm about to buy one of these ESCs, i had a pretty cool experience with Typhoon Racer 4-in-1 30A ESC! Hope i won't be disappointed!
Sep 05, 2017, 12:01 PM
Team Rotor
DenRotor's Avatar
Hi All,
I have mine working in multishot .
dshot1200, 600 are not working for me. It will not arm after the 3 beeps.
Did I miss a setting or a board jumper?
FC- Airbot F7v2 running latest nightly build 1638.
dr
Sep 05, 2017, 02:34 PM
Hi there!
Do you have a multimeter? Try (with resistance measurement) to locate capacitors (the yellow components) on the ESC that is connected to the PWM signals from the FC. If you find one (per signal), desolder those and try again.
Sep 05, 2017, 04:26 PM
Team Rotor
DenRotor's Avatar
Originally Posted by Mark_DK
Hi there!
Hello Mark,
Excellent! thank you.
DR
Sep 11, 2017, 04:33 PM
Tr3TopFlyer
chyoung's Avatar
Which FC pairs best with this? Omnibus F4 V5? Thank you.
Sep 12, 2017, 05:05 AM
Can anyone share experience with those ESC ?
I'm considering them, but I can't see any review/test. A bit scared...
thanks.
Sep 13, 2017, 03:50 PM
Originally Posted by DenRotor
Hello Mark,
DR
Hello DR and Mark,
I have an omnibus f7 with the typhoon32 mounted with the 4in1 ESC PWM Cable 8pin beetwin the two and the build is super clean.
But it seems that i have the same problem that you. It only works with multishot and not with dshot.
Could you help me with showing the capacitor i have to removed with a pics?
Thanks you in advance
Sep 15, 2017, 06:20 PM
Hello,
Dshot is broken on betaflight 3.2 above rc4.
Try to flash the rc4 and it should be fine.
Edit: Dshot is broken on f7 board only.
Grimm
Sep 15, 2017, 07:59 PM
The motor order seem to be incorrect from the inscriptions in the PDB, it's just an error on writting or i need to remap M2 and M3?
Sep 16, 2017, 12:46 PM
Flip it around and it fits
Sep 16, 2017, 03:30 PM
Originally Posted by grimm95
Hello,
Grimm
Do you know where I can find the f7 v2 rc4, I have been looking all morning for it?
Sep 16, 2017, 04:01 PM
Hello,
Grimm
Hello Grimm,
Thank you, i will try that.
downloader9, it's not an error, it was designed to have the xt60 on the side, i turned mine to have the plug on the rear, and in this case you have to remap the two motors. For me i do it phisicaly on inverted the two PWM cables of those motors.
I'm interested to have a link to the precedent 3.2 too
GPW
Sep 16, 2017, 05:15 PM
Really? For me makes a lot more sense to have the xt60 in the rear, but I will just change two wires them.
Discussion Airbot BumpBee_S 3-6S 30A BLHeli_S ESC myairbot.com Multirotor Drone Electronics 197 Nov 22, 2017 01:32 AM
New Product EMAX Lightning_S 35A ESC (BLHeli_S ESC) EMAX Yin Yan Multirotor Drone Power Systems 225 Jan 05, 2017 09:52 AM
Discussion Has anyone used 2 Emax 25amp 4in1 ESC for an Octocopter ? hackerjoe Multirotor Drone Electronics 0 Mar 21, 2016 08:23 AM
Discussion Q-Brain 4in1 ESC 25A ArgoEngineering Multirotor Drone Electronics 9 Jan 07, 2016 06:28 AM
Discussion Issues with EMAX 4IN1 ESC s.mckenzie82 Eagle Tree Systems 4 Dec 09, 2015 08:40 PM
