Xiaomi "Mini" 4K 30fps Mijia Action Camera - RC Groups
Aug 22, 2017, 07:39 AM
TechTronic9000's Avatar
New Product
Xiaomi is releasing their first 4K action camera under the Mijia brand. The specifications place it next to the SJCam SJ7 and the YI2 4K, it will record real 4K video. Some other specification include: a 7 glass lens 145-degree wide angle, Six-axis EIS: three-axis gyroscope and three-axis accelerometer, WiFi: IEEE802.11 b/g/n, Bluetooth Version: 4.1
The camera is already available to order from
GearBest
Coupon available: "GBCE", final price: $122.24
TomTop
Coupon available "HTYMJC30", final price: $ 119.75
Brand: Xiaomi
Model: Camera Mini
Type: Sports Camera
Type of Camera: 4K
Chipset Name: Ambarella
Chipset: Ambarella A12S75
Sensor Brand: Sony
Function: Anti-Shake,WiFi
Application: Bike,Extreme Sports,Motorcycle,Ski
Features: Cool,Mini,Wireless
Storage
Max External Card Supported: TF 64G (not included)
Display
Screen: With Screen
Screen size: 2.4 inch
Screen resolution: 960 x 480
Power
Battery Type: Removable
Battery Capacity (mAh): 1450mAh
Charge way: AC adapter
Working Time: About 2 hours
Standby time: About 4 hours
Primary Info.
Wide Angle: 145 degrees wide angle
Video/Image/Audio
Decode Format: H.264
Video format: H.264,RAW
Video Resolution: 4K (3840 x 2160)
Video Frame Rate: 30FPS
Image Format : JPG
Image resolutions: 38402160 (8.3MP)
Audio System: Built-in microphone/speaker (AAC)
Microphone: Built-in
Functions
WIFI: Yes
WiFi Function: Image Transmission,Remote Control
G-sensor: Yes
Auto-Power On : Yes
Camera Timer: Yes
Time lapse: Yes
Auto Focusing: Yes
Anti-shake: Yes
Interface Type: Micro USB,TF Card Slot
Dimension/Weight
Product weight: 0.0990 kg
Package weight: 0.3000 kg
Product size (L x W x H): 7.15 x 4.27 x 2.95 cm / 2.81 x 1.68 x 1.16 inches
Package size (L x W x H): 10.00 x 8.00 x 6.00 cm / 3.94 x 3.15 x 2.36 inches
Package Contents
Package Contents: 1 x Camera, 1 x Battery, 1 x USB Cable
Together with the Mijia Action Camera there is also a gimbal that is being lunched soon.
Xiaomi 3-axis Handheld Gimbal
Specifications:
Built-in battery capacity: 5000mAh
Operation time: 4 - 8 hours
Charge time: about 4 hours
Compatibility: Mijia mini action camera
Specification
Gimbal Type: 3 Axis
Compatible Camera: Mijia mini action camera
Dimension and Weight
Product weight: 0.3400 kg
Package weight: 0.6400 kg
Product size (L x W x H): 7.65 x 7.10 x 25.80 cm / 3.01 x 2.8 x 10.16 inches
Package size (L x W x H): 26.60 x 12.10 x 4.65 cm / 10.47 x 4.76 x 1.83 inches
Package Contents
Package Contents: 1 x Gimbal ( Battery Included ), 1 x USB Cable, 1 x English Manual
Mijia mini action camera adopts for Ambarella A12S75 high technology chip and for Sony IMX317 high light sensitivity image sensor. It can capture 4K ultra HD video and max. 3840 * 2160 high definition photo. The 7 layers glass 145 wide angle lens offer a wider and deeper perspective for better vision. 6 axis EIS anti-shake function enable you to capture clear dynamic image. You can connect the camera to smartphone APP via WiFi or BT function. Compact, mini and lightweight for portable carry. A perfect recorder for your journey.
Features:
Adopt for Ambarella A12S75 professional grade chipset, RAW undamaged format save every detail.
Ultra HD 4K(3840 * 2160)30fps video shooting, 4 times clearer than 1080P video.
3840 * 2160 photo resolution, capture wonderful moment in high definition.
145 wide angle lens widen your vision, F/2.8 enhance sense of depth.
2.4inch highly sensitive touch screen, bigger than ever.
6 axis EIS anti-shake, with keep fuzzy image away.
Image calibration and low noise process, truer and better.
Multiple shooting modes including Time Lapse Video/ Slow Motion/ Timed Photo/ Burst Photo & so on.
Support 2.4GHz WiFi / BT wireless connection for smartphone real-time share or control.
Compact, pocket-size and lightweight, portable for outdoor.
Ideal recorder for family-fun, pets time, extreme sports activities & etc.
Specifications:
Brand: Xiaomi
Color: Black
Chipset: Adopt for Ambarella A12S75
Sensor: Adopt for Sony IMX317, 8MP
Lens: 145 Wide Angle Lens, 7 Layers Glasses, F/2.8
Focal Length: 3.2mm
Video Resolution: 4K (3840 * 2160) 30fps, 2.5K(2560 * 1440), 1080P 100fps, 720P 200fps
Photo Resolution: 3840 * 2160
Format: JPG/RAW (Photo)
Time Lapse Video/Photo: 0.5/ 1/ 2/ 5/ 10/ 30/ 60s Interval
Slow Motion: 8x (702P), 4x(1080P), 2x(1080P)
Loop Recording: 1/ 2/ 5min
Photo + Video: 5/ 10/ 30/ 60s Capture Interval
Time Photo: 3/ 5/ 10/ 15s
Continue Shot: 3/5/10 photo/second, 10p/2s, 10p/3s, 30o/6s
BT Version: 4.1
Audio: Dual Microphone
Storage: Support up to 64GB Micro Memory Card (Not included.)
Battery: 3.8V 1450mAh Rechargeable Li-ion Polymer Battery, Built-in
Item Size: 71.5 * 42.7 * 29.5mm / 2.8 * 1.7 * 11.6"
Item Weight: 99g / 3.5oz (With Battery)
Package Size: 11.5 * 8.5 * 5.4cm / 4.5 * 3.3 * 2.1"
Package Weight: 227g / 8oz
Package List:
1 * Camera
1 * Battery
1 * USB Cable
1 * User Manual
Note:
Memory card is not included, and class 10 or above is highly recommended to ensure smooth camera operation.
Aug 22, 2017, 07:49 AM
Marcofan76's Avatar
Coupon coming soon...
here my article for Italian audience: ActionCamItalia
Aug 22, 2017, 08:00 AM
Pixelpeter's Avatar
Don't see 'fisheye removal' or the likes mentioned. Does it have one?
Aug 22, 2017, 08:09 AM
Coupon is now active: "GBCE", final price: $122.24
Limited to only 100pcs.
Aug 22, 2017, 08:17 AM
Marcofan76's Avatar
awesome.. maybe Gearbest made a mistake
It's an Ambarella A12 platform based camera, until now all action cameras that use this chispet such as ThiEye T5, SJCam Sj7, Firefly 8S miss this feature. The only "reported" functional and correction is achieved in the GitUp F1.
Possible as only the ThiEye was as low as 100-110$ and that was after ~6 months from lunch date.
Latest blog entry: Xiaomi MITU Mini Drone Review
Aug 24, 2017, 06:00 AM
TomTop has it on sale also, similarly priced with the Coupon "HTYMJC30", final price: 129.99$
#updated post 2 with more info and pictures
Aug 24, 2017, 09:19 AM
Pixelpeter's Avatar
Nice and stylish minimalistic look; nice big screen too Haven't got a 4K television yet
Sep 13, 2017, 01:32 AM
Added new coupon offer:
TomTop
Sep 24, 2017, 09:19 AM
Specifications:
Specification
Gimbal Type: 3 Axis
Package Contents
Oct 10, 2017, 06:10 AM
Flash Sale: 111.99$: "HERE"
Oct 10, 2017, 02:31 PM
Here is my review of the camera:
Xiaomi Mijia Action Camera REVIEW / ОБЗОР (РУССКИЕ СУБТИТРЫ) (8 min 44 sec)
Xiaomi Mijia, SJCAM SJ7 Star, SJ6 Legend, M20 COMPARISON (10 min 15 sec)
Can be bought here for $109.99 with coupon GBXMINI
Oct 15, 2017, 04:55 AM
Would not jump to conclusion about being best or not. The Mijia mini offers some features that are unique.
It is also missing plenty as a package. It is cheap, though I'm wondering if saving the last dollar is a reasonable move.
This space of the market is competitive. With many choices to consider as far as at A12S75 chip is concerned.
Anyhow, here is my review of the camera:
Xiaomi Mi Mijia Mini Cheap 4K action camera - Review (7 min 28 sec)
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 5 May 06, 2018 12:50 AM
New Product Xiaomi Mi Drone WIFI FPV 4K 30fps & 1080P Camera 3-Axis Gimbal Squirrels Mini Multirotor Drones 81 Jul 22, 2017 09:04 AM
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 0 Jan 17, 2017 07:49 PM
