Nov 26, 2017, 08:10 PM
Originally Posted by Marcofan76
like SJ7 last year? waiting for october...... ehm no... february
Yup, hence 2018
Dec 10, 2017, 11:43 PM
Air should be ready first... Plus and Pro in Jan/Feb
Dec 18, 2017, 09:11 PM
SJCAM SJ8 Pro, SJ8 Plus, SJ8 Air 4K 60FPS Action Camera Series (7 min 54 sec)
Updates on the SJ8 pro, plus and air
Dec 19, 2017, 04:46 AM
TechTronic9000's Avatar
Originally Posted by sjcamhd
https://www.youtube.com/watch?v=zvDMRHzvU7Q
Hmm H.265 sounds great, i really hope to see some improvement in that !
Dec 20, 2017, 12:13 AM
Yes, you will be able to switch from h.264 and h.264 manually
Dec 26, 2017, 08:24 PM
Prototype SJ8 Air and SJ8 Pro housings are in!
SJ8 Pro, SJ8 Air, SJCAM A10, SJDASH+ Camera Previews! (14 min 39 sec)
Dec 31, 2017, 12:28 PM
andrewbt's Avatar
it looks thicker than my current SJ7 Star, and is it a plastic body? I'm thinking if i should upgrade, or wait for the SJ9 because i would like 4K 60fps and EIS...
Jan 01, 2018, 08:04 PM
I don't think it is a lot thicker... maybe just wider though as it has a larger screen. SJ8 pro or SJ8plus will be the one to upgrade to. SJ9 specs are still not confirmed
Jan 02, 2018, 04:28 AM
andrewbt's Avatar
It would be nice to stay within the dimensions of the GoPro or the SJ7 (58 x 41 x 20mm) which are smaller then the SJ5000X(61 ◊ 42 ◊ 25mm).
Early specs of the SJ8 say it will be about 70 x 40 x 30mm which is too big, but these specs might no be accurate yet and you could fit a 2.33' screen on the SJ7 dimensions as well.
Also will it be waterproof without a case?
Jan 02, 2018, 11:55 PM
Checking on these specs. Will revert back shortly. Thanks!
Jan 03, 2018, 12:17 AM
Okay, there will be at least two packaging options.
One with only the unit + cable, and one with all attachments, waterproof case and special frame mount....
Attached is preview pic of dimensions.
Jan 03, 2018, 03:45 AM
Will there be a 90 degree lens version or just the unuseably wide (to me) 170 or similar.
Jan 03, 2018, 02:13 PM
helitone's Avatar
+1 would like to have a 90 Degree as well. If sjcam would bring one out, it will be my first sjcam camera
Jan 03, 2018, 07:28 PM
We will suggest this to our R&D department. Hopefully, we can release a 90 degree solution in 2018!
Jan 30, 2018, 05:05 AM
When will the SJ8 Series release? Check this SJ8 Blog
Question F3/F4 Flight controller that supports GPS HoverThings Multirotor Drone Talk 19 Nov 10, 2017 07:07 AM
New Product Yuneec Breeze Selfie Drone WIFI FPV With 4K HD Camera APP Control GPS Follow Me reviewdroneworld Multirotor Drone Talk 1 Sep 18, 2016 03:36 AM
Mini-Review GPToys FX-21V - 2.4GHz 5CH Voice Control Micro Quad -under construction Danq0 Mini Multirotor Drones 11 Feb 25, 2016 10:44 PM
New Product WOW GoPro Hero 3: 4K/15fps, 2.7K/30p, 1080p/60p, and 720p/120 fps. WiFi 400$! aerorynamic Aerial Photography 12 Oct 20, 2012 01:12 PM
