Cigarette/AMG Offshore Powerboat - Page 7 - RC Groups
Sep 13, 2017, 08:50 AM
Boats on the brain!!
green-boat's Avatar
Splattered solder is a good indication that the windings got way overheated. Just curious did you ohm out the windings and to the core?
Sep 13, 2017, 10:39 AM
Grumpa Tom
Kmot's Avatar
No, how do I do that test Phil? Commutator segment to ...?
Sep 13, 2017, 10:55 AM
Also check each segment on the com to each other. You should only get a reading on the segment directly across the diameter. If you get a reading between any segments other than directly across from each other, the windings have shorted out between poles.
Sep 13, 2017, 02:19 PM
green-boat's Avatar
Set the meter to Ohm's (X1) and short out the leads. This will give you the resistance of the leads. Touch the probe to one segment and the other probe to the next one. With the wire as short as it is, it will be just above the leads ohm reading. You can also put one probe on a segment and the other on the shaft. This will tell you if it's shorted to the armatuer.
Sep 13, 2017, 02:24 PM
Grumpa Tom
Kmot's Avatar
Thanks fella's! I will test it and report back.
Sep 13, 2017, 02:36 PM
Grumpa Tom
Kmot's Avatar
Okay, shorting the meter leads gave me 0.4 ohms.
Testing commutator segments opposite each other, all the way around, gave me 0.5 ohms each.
Testing commutator segments side by side, all the way around, gave me 0.5 ohms each.
What do you guys think?
Sep 13, 2017, 02:41 PM
green-boat's Avatar
How many poles is the motor?
Sep 13, 2017, 03:18 PM
Grumpa Tom
Kmot's Avatar
It's a 2 pole motor.
https://www.saylor.org/site/wp-conte...5-CCupload.pdf
Sep 14, 2017, 08:42 AM
green-boat's Avatar
How many steel "segments" (poles) are there that the wire is wrapped around? I count 6 from what I can see but I can't see the back side.
Sep 14, 2017, 10:30 AM
Grumpa Tom
Kmot's Avatar
It has 12 segments.
Sep 14, 2017, 09:27 PM
Grumpa Tom
Kmot's Avatar
I have installed some CNC aluminum props. They were made for 1/8" shafts so I was able to drill and tap them to 4mm. The threaded output shafts on the Graupner Z-drives are very short and did not go all the way through the prop hubs, even though I ground off the front drive dog portion of the hubs. It left an opening at the back of the prop. Since the output shafts are also different sizes on each Z-drive, the depth of the hole was different. One of them was 1.5mm and the other was 7mm deep.
Ray from the Hansen Dam Violators (Robins Hobby on RCG) suggested adding bullet spinners to the backs of the props. Great Idea I thought!
I got some 3/16" aluminum hex bar and made a couple of bullet nuts. I cut down 4mm studs to fit. The short one only has 1.5mm of thread into the prop hub. I used thread locker and I hope they stay put!
Sep 14, 2017, 10:54 PM
boat butcher
the goon's Avatar
Nice .
Mark
Sep 14, 2017, 11:28 PM
Grumpa Tom
Kmot's Avatar
Thanks Mark.
Sep 15, 2017, 11:09 AM
Mopar Musclecar fanatic
xx29l9's Avatar
New bullet prop nuts look awesome. Hope you got all the gremlins out, this looks way too cool to not run great.
Bob
Sep 15, 2017, 11:45 AM
Grumpa Tom
Kmot's Avatar
Thanks Bob!
Video Offshore RC powerboat racing (Southampton, UK) DominicM Racing Boats - Internal Combustion 3 May 19, 2017 12:38 AM
Discussion Scale offshore brushless powerboats JGuilty13 Racing Boats - Electric 95 Dec 15, 2016 04:36 PM
Careful! Offshore Powerboat aftermath.... nick_75au Dock Talk 9 Aug 08, 2016 11:13 AM
Discussion Amg mercedes battery electric racing cigarette wingman69 Racing Boats - Electric 8 May 13, 2016 02:11 AM
Cool Offshore Powerboat Racing when boats were boats! AirDOGGe Dock Talk 5 May 10, 2016 06:06 AM
