retracts - electric mechanical combo - RC Groups
Aug 17, 2017, 07:32 PM
Hi all,
new to the forum. Looking to start a kit build with retracts (first experience with retracts). From my research, I'm leaning toward electric mains, and mechanical tail. My question is can these be combined? How do I connect all this to the receiver?
Aug 18, 2017, 02:18 PM
An itch?. Scratch build.
eflightray's Avatar
The 'mechanical' tail retract will need a servo, then there will be two 'servoless' retracts for mains.
You either need two 'Y' leads or a three into on lead if you can find one.
Quick sketch below -
Aug 18, 2017, 03:42 PM
Thanks. That seemed too easy... I figured the servoless mains would need to receive a different signal than three servo...
Aug 19, 2017, 02:09 AM
eflightray's Avatar
A servoless retract is still in a sense a servo. It operates the same as a 'retract servo', in that it just drives from one end to the other, there is no 'follow the stick' positioning or centering.
Aug 22, 2017, 05:12 PM
Cougar429's Avatar
Servoless retracts use the same signal as any other channel. In fact, a retract servo functions the same way. Only concern is you flip that channel far away from center each way to reliably activate up or down.
NOTE: Some makes of servoless retracts require seeing that signal switch at least once when power is applied to begin following your commands. What that means is if you power the aircraft the gear may not retract or extend until the switch is cycled at least once. Safety feature so if you have gear up selected and the craft is sitting on the ground when you switch it on the whole thing won't collapse.
Help! Nitro Planes Mechanical Retracts Jack_K Fuel Warbirds 1 Jun 26, 2017 07:32 AM
Discussion Top Flite P-51D .60 Size Mechanical retracts Flyboy81 Fuel Warbirds 3 Jun 23, 2017 12:57 AM
Question Mechanical Retracts On H9 Mustang 1.50, are they ok? gva1956 Fuel Warbirds 1 Jan 24, 2016 12:01 PM
Discussion Mechanical or electric retracts p3arljam Fuel Plane Talk 7 Dec 27, 2013 02:20 AM
New Product EPF electric retracts & F-14 combo Robert Wagoner Foamy EDFs 4 Dec 19, 2007 11:09 AM
