CCGS Samuel Risley 1:90 scale - RC Groups
Aug 17, 2017, 07:28 PM
Build Log
More pictures of this build. I am new to this forum and there are first photos under the same title marked as "discussion".
Aug 18, 2017, 12:00 AM
boat butcher
the goon's Avatar
Really nice, clean work .
Aug 18, 2017, 02:29 AM
Po' boys does w/ Po'boys ways
haxawsnavy's Avatar
Welcome,!! And I agree with Mark,!! I like it,! Tim aka Cap'n Hax
Aug 18, 2017, 01:10 PM
How do I add more pictures to the same "Build log"? Cannot find any advise in the FAQ.
Aug 18, 2017, 03:09 PM
haxawsnavy's Avatar
Hippo, Are you wanting to add more pic's to an existing post,?? You do that in edit mode but you also must use the "advanced" setting button to do so. If you just want to add pic's to a post you are replying to in your own thread simply scroll down your current reply and add them the same way you did the first ones here before you submit it, other wise then you can do it by the method I just tried to explain in edit "Go Advanced" mode. If this helps , If not PM me n I'll get you my ph # n talk you through it together next time you want to add some pic's.! Tim aka Cap'n Hax P.S> just remember too there is a size limit here on each post. If you have a lot of pic's sometimes you have to add them by making back to back posts so they will follow as a series.
Aug 18, 2017, 09:07 PM
Thanks Capt Hax.
Aug 18, 2017, 09:13 PM
More CCGS Samuel Risley Pictures
Additional work with styrene and brass.
Aug 19, 2017, 02:47 PM
haxawsnavy's Avatar
Looking good so far Hip,!! Tim aka Cap'n Hax
Last edited by haxawsnavy; Aug 19, 2017 at 02:49 PM. Reason: Added Big Smiley (hav to go advance for that TOO,!!)
Aug 19, 2017, 05:11 PM
Very nice, kinda looks like a deep sea tug with an icebreaking bow. interesting design. I will be watching for video!
Aug 19, 2017, 08:42 PM
Hi Jeno, it will take a long time before I will be able to do a video. For now, you can see the real thing here
SAMUEL RISLEY breaks ice in Thunder Bay harbour, March, 2016 (3 min 40 sec)
and here
3rd Officer aboard the Canadian Coast Guard ship Samuel Risley - Icebreaking (3 min 53 sec)
Sep 11, 2017, 03:04 PM
Fabrication of cabins and bridge
This is the 3rd attempt with the red colour. Tamiya X-7 red was too dark. The one in the picture is from Michaels. It would be nice if all the paints had a RGB reference numbers instead of the fancy names - e.g. True red.
Sep 11, 2017, 03:51 PM
Looking great. I like the videos as well. Nice looking crew, the ship is not bad either.
Sep 13, 2017, 07:35 PM
Ballast test
SR will need 1610 g (+210g battery and 45 g ESC) of ballast in front and 727g at the rear.
The desired load line is on top edge of the white masking tape.
Sep 28, 2017, 02:03 PM
Making a flag 10x20 mm
I have tried a permanent red marker, but it was bleeding through the threads too much. WHat seemed to work fairly well was acrylic through a packing tape stencil.
Sep 29, 2017, 07:43 PM
Stuffing Box
I have done the "stuffing boxes" as shown in the attached picture. I was reading yesterday about some folks running brass shaft in a brass sleeve. I would not recommend the brass-brass combination, it is better to run two dissimilar metals. There is fairly good selection of good quality bushings for RC cars, one just have to find a suitable K&S brass tube diameter.
Discussion CCGS Samuel Risley - scale 1:90 Hippocan Scale Boats 5 Aug 18, 2017 03:15 AM
Build Log 1:50 CCGS Tanu Cadmunkey Scale Boats 82 Dec 06, 2015 03:09 AM
Build Log 1/50 CCGS Samuel Risley Guard - Chief Scale Boats 24 Mar 09, 2015 06:57 PM
Build Log CCGS Samuel Risley - Retirement gift Guard-Officer Scale Boats 5 Jan 11, 2010 11:10 PM
Build Log CCGS Samuel Risley - retirement gift Guard-Officer Scale Boats 1 Jan 09, 2010 06:20 PM
