This thread is privately moderated by Manudepron, who may elect to delete unwanted replies.
Aug 12, 2017, 03:20 AM
Manudepron's Avatar
Cool
120 % Jupiter Shrimp
This plane again is a hit. Here is my 120 % shrimp from Thomas' plan.
I found some 8 mm depron 2 years ago...
I had some electronics sleeping in a wreck: Turnigy D2822/14 - 1450 kv, 25 A Esc, 4 pces 9 grs servo's, 3S 1000 milis.
Some calculations.. and I decided for a 120 % version.
Wingspan: 80 cm
Finished at 440 grs rtf with battery.
The pod is not difficult to install on the wing: thanks to the template as drawn on the plan and I reinforced this templates by side plates.
I attached the pod with tape before placing the BBQ wood sticks. Because of the more powerfull motor, I placed 2 in parallel at each point. Gluing with PU glue and some water. It's the strongest gluing you can find with depron.
Flying is a blast: low speed, "high" speed, acro, water gliding....
2017 07 17 Shrimp (0 min 55 sec)
Jul 29, 2018, 04:48 AM
BELGIUM PILOT wanted !
aide sur namur RC
j'ai des soucis et helies RX et des problèmes de cablage dans mes quad, je fait du medelisme depuis 20 ans mais passer de spektrum à open tx je seche !!! del'aide svp merci d'avance
unicorn (est à beez)
Jan 30, 2019, 02:06 AM
Manudepron's Avatar
Bonjour, Je tombe par hasard sur ton message... Je n'y connais rien en Quad... et encore moins en Open TX... désolé... Par contre, tente le coup en allant à la Brocante de Wavre ce w-e, Hotel de Vilel de Wavre de 10 à 18 h environ...
Discussion POLYMORPH - Tips on using this fantastic stuff Berkie Foamies (Kits) 2 Mar 31, 2016 12:18 AM
Discussion AXI outrunner Fantastic Models Gee Bee Thunderjug Power Systems 1 Nov 19, 2015 11:20 AM
Rave fantastic STUKA tunakuts3d Fuel Warbirds 10 Nov 15, 2015 06:14 AM
Discussion Fantastic polymorph Berkie Foamies (Kits) 0 Sep 29, 2015 06:55 AM
FanTastic models, fantastic service. Arthur Foamies (Kits) 0 Dec 20, 2002 08:11 AM
