Any interest in a "Jupiter Giant"? - Page 3 - RC Groups
Aug 22, 2017, 12:52 PM
I Look, Listen, and Learn
Timbo383's Avatar
My motor knowledge is very limited and the 15-16 inch prop sounded a little small to me, but a higher kv motor on a 4s or 5s battery would probably work with that prop. I just think it would not look right... "propositional"... with that plane. I think you are right to go with the 20 to 22 incher. Hopefully you'll get some help somewhere with that.
Aug 22, 2017, 01:07 PM
I agree completely.
The Bipe using a low pitch prop threw me off as well as the prop calculator calling for 16"
These calculators and "rules of thumb" are not meant for slow flying cartoon planes lol
I think I need large diameter (20-22"), medium pitch (6-8") and low kV (<700).
So far lots of lookers, but no suggestions....No hurry though
Aug 22, 2017, 01:47 PM
I 'tried' a turnigy sk3 350kv on 3S swinging a 24x12 prop in ecalc, got around 3500g of static thrust @ ~50A IIRC. That's the sort of setup I would use if I built something like this. What weight are you expecting for the airframe without gear?
Aug 22, 2017, 03:02 PM
Thanks for the reply, I haven't come across that motor in my search for low kV and that is a lot more thrust than my calculations say I need (is that a good thing?).
The 4 x 8 sheets of foam weight 2.7 lbs each and I will use about 3 sheets including waste.
so if we conservatively say only 10% waste that gets us to 6.75 lbs.
With glue, and hardware, let's call it about 7 lbs. without gear.
Aug 22, 2017, 03:44 PM
I have a (much smaller) quadruplane with that sort of thrust to weight ratio, and because it's so draggy (which I guess yours will be too!) and pitch speed is marginal it does not feel overpowered at all.
Aug 22, 2017, 04:01 PM
Oh yeah, she is going to have some drag, but she should also make some lift, so I am hoping to be able to slow her way down at times.
Off the shelf, I am only finding a 24 x 10 (in the antique prop type I want to use) - what did you use? Is that a problem?
Did you use the Turnigy prop adapter kit? I cannot find the specs on it, the 24 x 10 has a 10mm hole, but I think they will custom drill one if I need something different.
Aug 22, 2017, 11:14 PM
My plane is much smaller scale, only draggyness of airframe, wing loading, pitch speed and thrust/weight is very similar to the hypothetical setup I posted, so can't give advice on prop adapter for you.
But FWIW my setup is ~700g turning an 11x7 prop on a ~900kv sk3 @ 2S, so same pitch speed as a 12" pitch on 350kv @ 3S. For 10" pitch I would go with a slightly higher kv to compensate.
I do see why you'd want a Xoar scimitar prop though, I have pondered getting one myself but they are hard to come by without steep shipping fee in Sweden.
Aug 23, 2017, 06:39 AM
Good point
The next one up is 410kV
It doesn't match pitch speed as well as your example, but gets close
Aug 23, 2017, 09:37 AM
FYI the push for a motor selection is because one of the dimensional issues with just making the plans larger is the firewall location.
the other dimensional issue is making sure I have prop clearance with the floats and with the water.
Now that it looks like I have a motor/prop combo, I would assume I should mount the firewall so that the end of the motor (not the end of the shaft) is even with the front of the fuse?
EDIT: the dimensions I see do not include the motor mount, should I plan on 1/2", 3/4"?
Aug 23, 2017, 09:42 AM
The other dimensional issue is with the height of the fuse with thicker top and bottom decking
What I did was cut one side of the fuse to the drawing, then I compared the foam thickness to the relief found in the front where the hatch goes on
Doing so revealed that about another 3/16" needed to be removed (only on the areas that get decking)
I then taped a pen to a piece of foam so that as I dragged the foam down the side it made a new line 3/16" in
Once cut I traced that side onto the foam to cut the other side
I think this was easier than trying to fix the drawing YMMV
So I now have both sides of the fuse and the top and bottom wing cut
Aug 23, 2017, 10:18 AM
Sorry for all the questions, this is the first model I have built that didn't already have recommendations
for me learning this stuff is part of the point in building it
Soooo - what should I get for batteries that aren't too expensive?
Do they have to be sized to continuously handle the max amp draw of 55A?
EDIT: also is a 55A ESC sufficient or should i go with the 60A for about $15 -$20 more?
Aug 23, 2017, 12:36 PM
I would wait until I had the motor with mount physically available for measurements if I were aiming for a clean install
Regarding esc, these get good reviews
https://m.banggood.com/Hobbywing-Sky...l?rmmds=search
but I don't have first-hand experience with them yet (I have a pair that will be used in an upcoming giant twin bipe)
Aug 23, 2017, 01:15 PM
I'm spoiled and don't have the patience to wait for BangGood shipping lol
Are you saying I need an 80A ESC?
FYI on my motor thread in the motor forum, I am being steered toward a 23 x 8 prop with the 410kV motor
Aug 23, 2017, 01:26 PM
Ken's CAD Models
dz1sfb's Avatar
Watching with interest.
Ken
Latest blog entry: Ken's CAD Models new web site
Aug 23, 2017, 01:30 PM
Timbo383's Avatar
Don't forget that the esc is also for the servos, allow a little bit extra for those. They don't use much, but every little bit adds up.
Cool Any interest in a marketable Giant scale 3d foamy? taildragger21 3D Foamies 11 Aug 26, 2017 09:47 PM
Discussion Any interest in scanning 'Aircraft Described' drawings? WMD Vintage & Old-Timer Designs 34 Jan 22, 2016 08:31 PM
Discussion Any Oregon builders out there interested in a bunch of components and materials? esox Foamies (Scratchbuilt) 2 Nov 24, 2015 12:48 AM
Discussion Any interest in Original Hawkeye for sale? millerhill Aerial Photography 0 Oct 21, 2015 02:46 PM
Discussion Any interest in an electric fly-in in North East Texas? JIMA Scale Kit/Scratch Built 1 Oct 21, 2015 12:38 PM
