Aug 11, 2017, 02:59 PM
Build Log
Any interest in a "Jupiter Giant"?
On the Jupiter. Jr. thread we are having an interesting discussion about slow giant flyers.
So far 54" then 64" have a preliminary layout on MPF, but i am pushing for 80"!
The conversation started here:
https://www.rcgroups.com/forums/show...biplane/page27
But I'd like to see who else has input or might be interested in building one from a laser cut kit and didn't think it was getting visibility buried in the original thread.
I became interested when I found the Giant Slow Bipe Thread, and since that plane never became available I thought why not build a giant version of the little Jupiter that I am almost finished building instead!
Here is that video:
https://www.rcgroups.com/forums/show...-from-SlowBipe
Anybody else like this idea?
EDIT 10/20/2017: Because this thread has evolved from a discussion to a build log, I thought I would start listing the important details here.
Motor:
PROPDRIVE v2 5060 380KV Brushless Outrunner Motor
ESC:
HobbyKing 100A ESC 4A UBEC
Lipo:
ZIPPY Flightmax 8000mAh 3S1P 30C Lipo Pack
Prop:
XOAR PJWWI Scimitar 24x10 Light RC Warbird Airplane Propeller
Prop adapter:
NTM Accessory Pack for 63 Series Motors (required machine adapter to make it fit the above motor. See post # 113)
Wingspan:
80" (203 cm)
Estimated AUW:
10 lbs (22 kg)
Plans are below (consider making a gift PayPal payment to Bob @ Hoosier Cutout Service for enlarging the plans for us - I did):
Aug 11, 2017, 03:26 PM
Retired CAD guy
birdofplay's Avatar
OK ... I'm monitoring
I have a Router based CNC machine.
Lasers are costly to own and operate.
Aug 11, 2017, 03:28 PM
What do you think of my layout for an 80" span?
Aug 12, 2017, 06:17 AM
Larry P
Gofer 303's Avatar
Looks interesting keep us up to date. Thanks for your work on this was always hoping for a giant bipe seems no matter how I try I cant draw a straight line !
Aug 12, 2017, 11:38 AM
Retired CAD guy
birdofplay's Avatar
Here is a tentative 80" layout. on 4' x 8' foam sheeting.
I show two full sheets and still not enough room for all parts.
It would be difficult/expensive to ship these cut parts
No re-engineering here , just a simple scale up.
You are on your own regarding ...
1. the structural improvements necessary at this size.
2. choice of equipment ( motor ESC Servos etc )
Aug 13, 2017, 07:33 AM
I Used To Have More Free Time!
Anything new here?
Aug 13, 2017, 08:07 AM
Originally Posted by NCRealEstateGuy
Anything new here?
Thanks for checking in but I'm not sure what you are asking.
Bob is helping me layout an 80" Jupiter Giant on 1/2" foam - that is new.
I believe you might be able to talk him into cutting a 54" or 64" out of MPF for you - that is new.
Are you interested in building one?
Aug 13, 2017, 09:14 AM
Larry P
Gofer 303's Avatar
what would be the cost is what I would want to know? A 54 incher would be ideal for my area. Very interested.
Aug 13, 2017, 09:19 AM
Larry P
Gofer 303's Avatar
[QUOTE=birdofplay;38086501]Here is a tentative 80" layout. on 4' x 8' foam sheeting.
have a set of plans for a J N 3 looks like a cub in the basement will try to get a good picture and post it.
Aug 13, 2017, 10:14 AM
Retired CAD guy
birdofplay's Avatar
The builders of this monster will have to keep a balance of Strength vs Weight.
As with all aircraft.
More so if you really want this giant to fly very slowly.
Fortunately, just being Large should make it "appear" to be going slower than it actually is.
Ever watched a 747 or C5 landing or taking off. They look very slow.
As for pricing :
read here - http://www.hoosiercutoutservice.com/info/custom.htm
or read below ...
Figure $10-14 for shipping for 2017 -
LARGER kits might be double or triple that figure.
I only ask exact shipping.
Plus material. Most "stores" simply double their Wholesale cost. I do better.
Plus a cutting charge. $5-$8/sheet - What is your time and the Machine time worth ?
Boxing/Packing, labeling or just Handling is another cost and labor issue.
NOTE: I am not charging for the set up/prep/design time.
This is a one man shop and there are no Economys Of Scale for volume.
My service has been available since 2005 with hundreds of kits and custom project out the door.
I am retired ( now 70) and do this as a service for guys who either don't have
the Time or the Room or the Inclination or the Patience to do detailed cuttings.
I do CNC foam /ply Cutitngs, 3D Printing, CNC Milling of thick foams, and Custom CAD Design work.
My CNC machine is an old router based ShopBot the 3Dprinter is a Folger Tech FT-5
and the shop is always mess
(4 min 4 sec)
Best
Bob @ Hoosier Cutout Service ( google it )
Aug 13, 2017, 07:17 PM
[QUOTE=Gofer 303;38093614]
That's for sure!
Exactly zero Jupiters have been built to this scale, so if you cut it yourself or have Bob cut it - it is a scratch built model!
Aug 14, 2017, 12:09 PM
As for pricing :
or read below ...
Best
You are just the best kind of people.
Aug 14, 2017, 03:55 PM
So I had the plans enlarged 362% and printed on a large format printer
It took 18 sheets of 22" x 34" paper
This picture is the upper wing laid out on a large conference room table
Aug 14, 2017, 05:43 PM
Retired CAD guy
birdofplay's Avatar
You are certainly Industrious !
Just wondering ... Did you print the Originals or my layouts ?
I've never printed plans for foamys as I have always had my CNC.
And SRA: thanx for the Comps.
Some guys "get it some guys don't.
Aug 14, 2017, 07:53 PM
It's good to have friends in engineering who also"get it"
I printed the originals, I don't think the file you posted was large enough to survive a blow up without pixelating
Once taped together, I will cut individual parts out with scissors and lay them out like you did
Cool Any interest in a marketable Giant scale 3d foamy? taildragger21 3D Foamies 11 Aug 26, 2017 09:47 PM
Discussion Any interest in scanning 'Aircraft Described' drawings? WMD Vintage & Old-Timer Designs 34 Jan 22, 2016 09:31 PM
Discussion Any Oregon builders out there interested in a bunch of components and materials? esox Foamies (Scratchbuilt) 2 Nov 24, 2015 01:48 AM
Discussion Any interest in Original Hawkeye for sale? millerhill Aerial Photography 0 Oct 21, 2015 02:46 PM
Discussion Any interest in an electric fly-in in North East Texas? JIMA Scale Kit/Scratch Built 1 Oct 21, 2015 12:38 PM
