Generating Airfoils on cad. - RC Groups
Aug 11, 2017, 12:42 PM
charlieuk's Avatar
Im looking to generate some really thick airfoils for my hydrofoil I have been working on. until now I have been using airfoils that I have downloaded the points for however I would like to try modifying some to make them thicker ect.
I have been looking at profili but wondering if there was anything out there for free that would allow me to do similar and just adjust the basics and then be able to import it in to my cad software?
At first I am basically just trying to generate a 15% thickness Clarke Y
many thanks
edit ( I may have found a 15% Clarke y but not tested it yet, if there are any other programs I would be very interested.
edit ( I cant seam to download the .dat file for the above so still trying)
Aug 11, 2017, 01:09 PM
supreme being of leisure
ZAGNUT's Avatar
javafoil can generate all the various NACA foils as well as modify any other foil and spit out a DXF file. 100% free but can be a bit quirky to learn. pretty adept at it myself so if you run into problems i could probably help you figure it out.
Aug 12, 2017, 02:01 AM
dpot's Avatar
look her for the price you just can not beat it http://www.compufoil.com/download_cf.shtml
what cad are you using if you post all the info of the cord that you wont i can do it for you
Aug 12, 2017, 04:39 AM
charlieuk's Avatar
I think I have managed to find a way to use the airfoils too website to do what I need and import them into fusion 360 using a csv file.
Aug 12, 2017, 05:14 PM
To change the thickness of an asymmetric airfoils you must do more complex things than just scaling the y coordinates...
Aug 13, 2017, 03:17 AM
dpot's Avatar
have a look at zip CLARK-YCOR20015thk3.56cmb by compufoil3d
Oct 19, 2017, 05:54 PM
I use Profili Pro, it can exp0rt DXF's
Bob
Oct 20, 2017, 01:57 AM
dpot's Avatar
i find to design and adjust the airfoil compufoil3d is easier to use and you get a very good finish serif
Bob
Oct 20, 2017, 03:47 AM
Oct 20, 2017, 09:06 AM
dpot's Avatar
read the pots again
Originally Posted by durone
This is not right, Profili Pro can for sure export to DXF!
Of course you need the license, to do that.
Oct 20, 2017, 10:13 AM
How does a fully symmetrical airfoil generate lift? AndrewsJr Power Systems 26 May 10, 2018 07:21 PM
Discussion Getting a NACA airfoils into cad. akschu The Builders Workshop 2 Mar 08, 2007 11:11 PM
Discussion Airfoils in CAD programs (Alibre) Boo Modeling Science 9 Oct 08, 2006 03:15 PM
HLG CAD airfoils? Ryan2200 Hand Launch 5 Aug 06, 2005 08:09 PM
Plotting Airfoils in CAD Neil Stainton Power Systems 6 May 17, 2002 11:50 AM
