Aug 25, 2017, 05:30 AM
A man with too many toys
Perfect
Originally Posted by ktrails
Hi Walt, you're flying through this build! It's looking good.
Here is the current state of my hog bipe build. Like you, I wanted the more rounded Waco type tail feathers. I used pictures of someone's 1/6 Pica Waco YMF build here on RCG blown up to the right size as templates.
That's the perfect look for a Hog Bipe. I will make my tail that shape.
Aug 25, 2017, 01:56 PM
I just want to go fly!
walter3rd's Avatar
Yes I think I'm going to make my tail similar to that as well. Just upgraded my building board a bit. New hollow core door and another layer of foam. Just looked it up and cited down the edge much much closer to dead flat now.
Aug 25, 2017, 05:12 PM
Lipoly Killer
Frank Hurd's Avatar
Walter-
I just put three flights on my Astro Hog. It has a Rimfire 80 and a 6s battery. Prop is an APC 15/8. Weight of the Hog is 8.25 lbs. porky but so am I. Anyway, the Rimfire pulls the Hog straight up. At 194 watts/lb, it is not lacking in power. Your Hog should be spectacular with the 80.
Aug 25, 2017, 05:28 PM
All Things RC
This is gorgeous!
Aug 26, 2017, 07:47 AM
walter3rd's Avatar
Thanks for the info frank.crisis averted! I had a bit of a dip in my top wing. After my new building board and sheeting the bottom front laying flat and weighted on my better board the dip is gone! So happy! Now I can relax and know my next wing will be money. Happy days.
Aug 28, 2017, 08:41 PM
walter3rd's Avatar
Test fitting the cowl. Going to look great painted to match her color whatever that is. not the correct prop but just need a stand in. 15x 8 on the way. Vented spinner looks sweet. the top and bottom of cowl are exactly the same size as the fuse front. happy accident. the sides flare out wider but look like exit vents anyway. similar to my bridi killer bee cowl fuse union. very happy with the fit so far. where the cowl stops at the top of fuse is where ill start my hatch opening. batts should angle in nicely. waiting on trailing edge and wingtips to dry then im almost ready for bottom wing construction. taking my time with this build. more fun that way. Walt.
Aug 31, 2017, 09:52 PM
All Things RC
Woot! Good progress!
Sep 01, 2017, 07:47 AM
Looking good! I like the cowl choice a lot, interested to see it all together
Sep 01, 2017, 11:52 AM
walter3rd's Avatar
Thanks a lot. I think the Cowl will give it a very sleek sporty look. At least that's what I'm hoping. Also going to do a full cockpit canopy as well. That should give it a streamlined look. Don't think I'm going to do open cockpit.
Sep 01, 2017, 05:07 PM
walter3rd's Avatar
Just received my canopy. Doing some Preliminary fittings. Much more aggressive than open cockpit. Me likely!
Sep 01, 2017, 05:24 PM
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
You're going to have to call it a Sig "Hog Bipe-roid" or something...
Sep 01, 2017, 08:30 PM
walter3rd's Avatar
I love kit bashing. Starting to glue the wingtip sheeting in place. im going for more of a aeromaster full canopy look.
Sep 02, 2017, 03:52 PM
walter3rd's Avatar
I'm putting 4 servos in the wing for Ailerons And obviously I need two more. What are a good servo for this particular build suggestions? Not too expensive but will do the job. Thanks. Walt
Sep 02, 2017, 04:22 PM
You are moving right along ! Your build makes me want to start on the Super Aeromaster kit that I have, but I think I will wait until I have a couple of builds completed... Looking good ! Mike
Sep 02, 2017, 04:58 PM
CryHavoc's Avatar
You don't full size servos for each aileron. Realistically, anything in the 40oz torque range will be more than enough. I would look for 17g-25g weight size "mini" servos.
Something like this - https://hobbyking.com/en_us/pdi-hv21...___store=en_us
or these - https://hobbyking.com/en_us/corona-d...___store=en_us
Discussion Sig Hog-Bipe... Is this a kit for first time kit builder? RCMikeofIndiana The Builders Workshop 17 Apr 16, 2023 10:39 PM
Discussion OS .61FX enough to pull a SIG Hog Bipe????????? flygilmore Fuel Plane Talk 11 Apr 20, 2017 01:11 PM
Question A few questions for items to build sig hog bipe Ultra Boom Fuel Plane Talk 28 Jul 17, 2013 09:58 AM
Build Log My First Build Log, First Peter Rake, First Biplane...too many firsts... Paul Bonati Scale Kit/Scratch Built 79 Jun 09, 2012 06:15 PM
Build Log Electric Sig Hog Bipe Build scott282 The Builders Workshop 44 Jun 08, 2010 10:35 AM
