BFight 210 -ULRTRALIGHTWEIGHT!! Omnibus F3+OSD 30a --March 2018 SALE $107! - RC Groups
Aug 08, 2017, 01:55 PM
youtube.com searchfor danqfpv
Danq0's Avatar
New Product
BFight 210 210mm Brushless FPV Racing Drone
BFIGHT or BFLIGHT- I've seen them called both... it is an ULTRA lightweight quad for racing, or if you simply like to go fast!
SALE
BFight 210 210mm Brushless FPV Racing Drone - BNF FLYSKY AFHDS 2A BLACK AND BLUE
https://www.gearbest.com/brushless-f...?lkid=13486184
107.99 BFGB4
BFight 210 210mm Brushless FPV Racing Drone - BNF FRSKY BLACK AND BLUE
http://www.gearbest.com/brushless-fp...?lkid=11079267
109.99 BFFGB4
Review:
BFight210 -210mm Superlight - Best bang for your buck 5" Drone -just $150 (14 min 30 sec)
Bfight210 FLYSKY 2A
https://www.gearbest.com/brushless-f...?lkid=11079273
Bfight210 frSKY
BFight 210 DSMX
http://www.gearbest.com/brushless-fp...?lkid=11079263
Coupon: RC18OFF
PNP- https://goo.gl/iXXnMG
DSMX- https://goo.gl/JPafia
FRSKY- https://goo.gl/vK4K4g
FLYSKYA- https://goo.gl/aEdc2U
FLYSKY2A- https://goo.gl/FsXEJa
Specifications:
Wheelbase: 210mm
Weight: 267g
Size: 178 x 178 x 38mm ( not including propellers )
Frame material: 3K carbon fiber
Bottom plate thickness: 4mm
Top plate thickness: 1.5mm
Flight controller: OMNIBUS F3 Pro with OSD
Brushless motor: F2205 2300KV
Brushless ESC: 4-in-1 BLHeli - S 30A
Propeller: Gemfan 5152 three-blade
Camera: HS1177, 650TVL ( black and white ), 600TVL ( color )
Image sensor: 1/3 inch Super HAD II CCD
Video transmitter: 5.8G 40CH 25mW / 200mW
Power supply: 11.1 - 14.8V ( 3 - 4S LiPo )
● Neat structure and good heat dissipation with 3 PCB boards of flight controller, 4-in-1 ESC and video transmitter at the center
● 4mm ultra thick 3K carbon fiber chassis consists of 4 independent arms, which increases the ease of maintenance
● 4-in-1 BLHeli - S 30A ESC supports Oneshot, Multishot, the latest DShot digital signals as well as firmware updates
● 5.8G 40CH real-time FPV, with MICRON CCD camera, 1km image transmission range, remotely adjustment of frequency / band ( receiver SBUS support required )
Click here to know more about the resolution.
Click here to download the FPV camera user manual.
Aug 19, 2017, 06:04 AM
Im really leaning toward purchasing this as my first 210mm frame. But I am definitely not using the stock vtx or the camera and will be using my runcam micro swift with adapter to fit and the eachine vtx03 because thats what i have already and the frame doesnt seem to protect the stock camera much with the lens protruding out past the posts and cf. Also to keep the weight down even more thats why i'd run the micro camera and tiny eachine vtx. The ease of use of the eachine vtx with display i like over the different colored led system on the Bfight.
Sep 08, 2017, 12:26 PM
<Marty>
Just got one of these few days ago and love it..Very powerful even on a 3s pack..Have only tested it on LOS so far but plan on trying some FPV this weekend hopefully..Great platform to practice with before moving on to something more expensive, just wish they offered replacement parts such as arms and plates..
Sep 08, 2017, 01:02 PM
Danq0's Avatar
your wish is my command:
bfight arms - https://www.gearbest.com/racing-fram...?lkid=11313795
frame- https://www.gearbest.com/racing-fram...?lkid=11313797
Sep 08, 2017, 01:20 PM
<Marty>
Wow thanks ..didn't know they had them available. .
Sep 08, 2017, 07:49 PM
What is this adapter you speak of???? I was thinking exactly the same thing using a micro swift....
Sep 09, 2017, 07:55 PM
<Marty>
The Frsky version has very short range from my experience earlier i had 2 failsafes at around 100 feet ..I have one of the frsky r-xsr pre-ordered to replace the rx with but not sure when it will be in stock and ship out..
Sep 10, 2017, 03:01 PM
Danq0's Avatar
i agree, the receiver that comes with this model is more so meant for micro quadsm defintely a good idea to replace, or simply buy the pnp version
Sep 10, 2017, 03:39 PM
<Marty>
I have a Flysky X6B but everything is so tight and compacted not sure how i could fit it to the frame unless i could squeeze it behind the camera..Really don't want to mount externally on top of the top plate and there's no way it will fit between the FC and VTX..
I adjusted the Freq fine adjustment on my tx to hopefully increase the connection strength..
Sep 10, 2017, 09:23 PM
<Marty>
Still getting the drop outs so i don't think its the rx range cause a couple times it was really close to me..And when it does it i hear 2 beeps from the beeper i installed and the motors stop instantly like the esc put full brakes on them..So i did some voltage checking and found the rx is only getting 4.48v which i believe could have been causing brownouts..What i did was hooked the rx to the 5v on the vtx which is showing 5.11v so hopefully next time i fly i wont have any more drop outs..Only thing that worries me is if the 5v on the FC is only 4.48 maybe the rx is not browning out but rather the FC is rebooting/browning out...If it still does it i will add a 5v regulator to power the FC and see if that resolves the issue...Don't know why the 4n1 esc is only putting out 4.48v when it should be putting out minimum 5v or like most a tiny bit above 5v..
Sep 11, 2017, 12:11 AM
Fan of just about anything RC
SoloProFan's Avatar
What receiver do they ship it with? I used the XM+, plenty of range, and RSSI on OSD. Lowest RSSI value I got when flying around is about 70%, so I have confidence Radio range exceeds VTX range by a fair distance.
Maybe use longer standoffs to raise the top plate, and put the receiver underneath it?
Maybe something it creating a short and draining some power from the 5V line? Or it's just a faulty regulator.
Sep 11, 2017, 12:24 AM
<Marty>
Does anybody know what brand esc is being used on the Bfight 210? And does it have a 5v bec output?
The rx shipped with it is the same size as the XM but only 8ch and has the little short wire antenna...
Sep 11, 2017, 11:09 AM
Danq0's Avatar
I swapped mine out for an xm too, I was worried the included receiver would fail.... but I may have jumped the gun on this one.
its a little d8 receiver. https://www.gearbest.com/radios-receiver/pp_631089.html
I just checked the website, and it says that its good for over 500meters! that is actually really good distance. i will refrain from assuming things
Sep 11, 2017, 11:12 AM
Danq0's Avatar
i scoured the internet this past weekend, looking for a match and came up with some racerstar esc's that were identical, ill post it here when i have a little time to find it
nm, maybe i was just dreaming....
these are the ones
https://www.gearbest.com/esc/pp_689046.html
Sep 12, 2017, 04:20 PM
I ordered the FrSky BNF version (will replace RX with xm+ if it is crap), but how is the switch to change the VTX channel meant to work? Can it be set on a 2 position switch light Sh on Taranis X9D Plus?
Discussion Airbot F3 Omnibus F3 Nano (Flip 32) - 20x20 OSD, Current Sensor run Multirotor Drone Electronics 492 Jun 17, 2018 04:34 PM
Discussion Racerstar StarF3S 30A BL_S 4 In 1 ESC 5V BEC w/ F3 Flight Controller AIO OSD BEC Curr scousethief Banggood.com 26 Jun 09, 2018 04:31 PM
New Product $23 F3 FC /w OSD - OMNIBUS F3 AIO V1.1 Flight Controller with Integrated OSD for BF Nickz88 Multirotor Drone Electronics 21 Feb 11, 2018 02:10 AM
Help! Flip32-f3-omnibus aio asgard (f3+esc+osd+cs) Chad2323 Multirotor Drone Electronics 1 Jul 13, 2017 03:44 PM
New Product Bflight 210 210mm Omnibus F3 Pro FPV Racing Drone w/ 40CH 25/200mW Switchable VTX 650 smg24 Banggood.com 0 Jun 26, 2017 03:15 AM
