Oct 09, 2017, 03:29 PM
Bill Glover's Avatar
Originally Posted by mrmurder19.75
Tiny, weigh next to nothing, full range, telemetry and now compatible with lua script.
And cheap
Latest blog entry: Eachine QX65 FPV quad review
Oct 09, 2017, 05:37 PM
Originally Posted by Mosch
maybe you guys are interested - my uninverted mod of the R-XSR.
works for me at the bench. will try it tomorrow.
1. cut trace on the upper side
2. clean the PCB (remove paint) and pre-solder the small solder point (red arrow)
3. connect to pin 3
As mentioned, not tried in-flight yet! if you want to try it do it on your own risk
I did this (with the newer version with the solder pad) and can confirm that it works. I tried this on a BFF3 board because my F4 board isn't working, but I turned telemetry inversion on (tlm_inverted = off is default in BF, per the S.Port standard) and the R-XSR was reporting telemtry.
I'd wager that the resistor that connects the trace could also be removed, and the (un)inverted S.Port signal soldered to it.
Originally Posted by AndreaHuang
Hi, we uploaded the latest firmware today and this firmware adds the lua script to let you adjust the PID parameters for your FC. Here is the link: https://www.frsky-rc.com/r-xsr/
Hello, please find the picture here, and we add the 2 soldering points for real "inverted SBUS out" and "inverted S.Port" on the board. Please check the picture below.
Attachment 10417355
I believe what Andrea is saying is that the standard for S.Port and SBUS signal is "inverted" from the FC point of view, but from the standard point of view it isn't inverted, its the standard. The FC and the SBUS just weren't aligned at their inception. So to get an "(un)inverted SBUS" and "(un)inverted S.Port" you "invert" them from the standard, making them appear uninverted to the FC.
What the FC says is inverted and what the SBUS/S.Port standard says is inverted are opposite.
Hope that makes sense, but its basically two standards arguing which is right.
Oct 09, 2017, 07:10 PM
As any engineer will tell you, the nice thing about standards is that there are so many of them........
Oct 09, 2017, 08:28 PM
FrSky-MKT
Hello sir,
Thank you for trying to clarify these ports. Please let me clarify here again.
We should clarify that the protocol and the definition of the S.Port were defined previously as 2013 by FrSky for all our S.Port RX. So please be clear that the standard S.port and SBUS out ports are the misunderstood "inverted" ports you said.
Description:
Thank you.
Oct 10, 2017, 02:26 AM
Sidewinder, did you just get the “uninverted” signal on the P pad? It looks like you scrapped the surface...is there more than just soldering to p pad?
Then it looks like you soldered the other end directly to the pin (I am assuming you first “desoldered the pin” or cut its source?
Oct 10, 2017, 03:40 AM
A F4 needs uninverted TLM as long as you have a board which doesn’t have a HW inverter... The default of the r-xsr is inverted
The P pad seems to be uninverted. Used a brand new 2nd r-xsr and was able to do discover the sensors
Oct 10, 2017, 09:47 AM
Krotow
What? R-XSR have clearly distinguished pads of non-inverted signals? Love it. Someone with R-XSR and F4 FC board - please test them.
Correct me if I’m wrong but the P pad is still the inverted signal, right? Confusing write up
SBUS concept (all channels transmitted as serial digital signal) came from Futaba where SBUS signal was inverted. Others started to use the same signal for their RX-es to be compatible with FC-s that initially was intended for Futaba RX-es. We still are affected by this legacy. So think opposite. Logically non-inverted digital signal (high signal level have high voltage and low level - zero or very low voltage) are inverted from Futaba SBUS perspective and vice versa. So all is good with R-XSR pads
Oct 10, 2017, 11:08 AM
Many serial protocols over the years have used inverted logic. IMO the inversion should be provided on the FC boards.
Oct 10, 2017, 11:34 AM
Tested. Updated my post
https://www.rcgroups.com/forums/show...&postcount=125
Oct 10, 2017, 11:55 AM
Nice clean mod!
Oct 11, 2017, 11:14 PM
Glasairsportsman,
I did the mod that Mosch did, but instead of having to scratch the trace as was shown, the later versions of the receiver have exposed solder pads, so no scratching the board required ( the later versions) I cut the trace leading to the pin on the connector as Mosch did, and was able to solder the pad to the pin directly.
To avoid any more confusion over what's inverted and isn't. A uart without an inverter on it can receive and transmitter the telemetry information via the provided P pad. All you have to do flight controller side is turn tlm_inverted =off ( default) to on.
Oct 12, 2017, 04:00 PM
Thanks!
Oct 12, 2017, 04:42 PM
I am the market for a new quad, and quite interested in this new R-XSR. If I understand correctly, apart from a money point of view, there is not really so much more interest in going XM+?
Oct 12, 2017, 04:58 PM
Rotozuk's Avatar
It is smaller and has telemetry. What is not to like?
https://alofthobbies.com/frsky-r-xsr.html
Oct 13, 2017, 07:02 AM
That's what I supposed, but as I'm a beginner I'm trying to confirm I understand everything before investing
Using it with an HGLRC F425, would there be any need and point to do the uninverted trick? What kind of telemetry data could I get with this stack?
Discussion FrSky Redundancy Bus - PowerBox FJH Radios 1944 Today 06:39 AM
Discussion FrSky Redundancy Bus -10 Discussion erieqc Radios 1 Nov 29, 2016 04:39 AM
Discussion Ultra Light Power Board, optimized for FrSky D8R receivers GTiDonavan Radios 3 Mar 31, 2012 02:56 PM
