Aug 07, 2017, 04:59 AM
FrSky-MKT
New Product
FrSky new arrival - Full range ultra mini redundancy receiver R-XSR!
This upgraded version of XSR receiver includes all the features of the original FrSky XSR receiver like "Full Range" "Telemetry" and "SBUS/CPPM signal outputs". Besides, this ultra mini item supports the redundancy function with a detachable antenna! So do you like it? ;P
INFORMATION
  • Dimension: 16*11*5.4mm (L x W x H)
  • Weight: 1.5g
  • Support redundancy function
Aug 08, 2017, 12:36 AM
Alex
Datos's Avatar
Sounds interesting. Having this I can build redundant system on a very small models like 210 fpv racing quad....
A question - if this R-XSR receiver accepts signals from salve receiver - as I understand slave can be any other FrSKY SBUS receiver as well as another R-XSR itself.
I wonder whether interconnecting 2 R-XSR whould give us full duplex redundant system as it was with RX8R.
Aug 08, 2017, 05:08 AM
I don't understand the intended use for this.
So are you saying the XSR can be be made to have a redundancy feature? If so how do you connect up a 2nd rx?
If it's for ones like the RX8R and the new sail plane one with built in Vario, then what's different about it to say the XM+ other than its got a plug ready soldered?
I read it a few times and to me it's now sounding like this is a XSR but as small as the XM+ so basically a XM+ with telemetry? Or have I got that wrong?
Aug 08, 2017, 07:26 AM
Alex
Datos's Avatar
Yep, seems that this tiny receiver is like RX8R - having the redundancy feature. I would say that the main use is for planes or FPV copters for those who fly in places with many obstacles and afraid to loose the signal. With 2 of this or R-XSR + XSR (or other) we can have up to 4 antennas + one repeating the other....
Aug 08, 2017, 07:43 AM
So could this also be used standalone?
If so then that makes the XM+ obsolete now as this is just as small/lighter but with full telemetry?
Curious to see where you plug in the 2nd rx too.
Aug 08, 2017, 08:04 AM
So the difference from the recently released XSR-M is the redundancy?
https://www.frsky-rc.com/product/xsr-m/
Aug 08, 2017, 08:31 AM
So it has a SBus input also for a secundairy receiver like a XM+? So it is a small SBUS / CPPM Only version of the RX8R? That would be very usefull
So..... can i test?
Aug 08, 2017, 08:43 AM
Sagitta Fanboy
No, you'll still want the XM+, in fact with the new redundancy receivers coming from FrSky, the XM+ is even more valuable. Think of it as a Remote Receiver.
Remember, for every redundancy unit, you need a non-telemetry-bound SBus receiver as a remote unit. Given pricing, that says XM+ to me.
This makes the XSR obsolete. I see no reason to buy the larger and less featured XSR over the R-XSR unless the XSR is decidedly cheaper.
I can actually see a really cool setup for this R-XSR.
Your base unit is an RX8R or G-RX8R in the fuselage. You have an SBus link to the R-XSR bound no-telemetry in one remote location, which in turn takes a feed from an XM+ in a second location. Or in an RB setup, 2 R-XSR's feeding the RB (one bound non-telemetry), each with a XM+ as a remote.
BTW, definitely want the R-XSR to be able to be bound no-telemetry, so it can support RB's and being a source for other redundancy receivers.
Aug 08, 2017, 08:45 AM
Sagitta Fanboy
S-Bus in is a single pin on the header, you can see they added a pin (from 4 to 5 pins)
Aug 08, 2017, 08:58 AM
Ahh i get it now.
Winner all round then and no need for the regular XSR anymore?.
Frsky really upping the game!
Aug 08, 2017, 12:15 PM
Alex
Datos's Avatar
Yes, can be used as standalone. Any other receiver with SBUS should do as slave receiver.... Hope that I am right.
Aug 08, 2017, 01:03 PM
Yeah think i get it now, basically it's gonna replace the standard XSR but have more features/uses and be smaller/lighter and hopefully around the same price or cheaper.
Aug 08, 2017, 03:04 PM
The picture shows two receivers. One looks like an XSR and one looks like something new...probably the R- XSR.
So I suspect the new R-XSR is designed to work with an XSR (with new firmware) to create a redundant micro receiver system.
Aug 08, 2017, 10:10 PM
FrSky-MKT
Hello sir,
Yes, this can be used standalone, actually, this is the upgraded xsr receiver and ultra mini. Plug in the 2nd rx through SBUS iN.
Aug 08, 2017, 10:12 PM
FrSky-MKT
And its ultra mini size and weight. ; )
Discussion FrSky Redundancy Bus - PowerBox FJH Radios 1944 Dec 15, 2018 06:39 AM
Discussion FrSky Redundancy Bus -10 Discussion erieqc Radios 1 Nov 29, 2016 04:39 AM
Discussion Ultra Light Power Board, optimized for FrSky D8R receivers GTiDonavan Radios 3 Mar 31, 2012 02:56 PM
