HAKRC BLHeli32 ESCS - RC Groups
Aug 07, 2017, 12:20 AM
New Product
HAKRC BLHeli32 ESCS
HAKRC BLHeli32 Bit 30A 2-4S ESC Support Dshot1200 Multishot
Product Link:
https://www.banggood.com/HAKRC-BLHeli32-Bit-30A-2-4S-ESC-Support-Dshot1200-Multishot-for-FPV-Racing-p-1182390.html?rmmds=category
Description:
Description:
Description:
Description:
Description:
Specification:
Item name: HAKRC BLHeli32 bit 30A ESC
Firmware: BLHeli32 bit
MCU: STM32F051
Con. current: 30A
Input voltage: 2-4s lipo
PCB: 3OZ copper, Gold-plated
Weight: 5.9g
Support Oneshot125, Oneshot42, Multishot, Dshot150, Dshot300, Dshot600, Dshot1200
Package included:
1* HAKRC BLHeli32 bit 30A ESC
Nov 08, 2017, 12:14 AM
Anyone tested these? They look great for that price. I can see a telemetry pad but do they have current sensing?
Nov 09, 2017, 06:34 AM
UFOFPV 30A clone ?
http://www.blheli32.com/ufofpv-30a-t...est-blheli_32/
Nov 10, 2017, 01:07 AM
They are curiously absent from the official list of blheli32 escs. Are they actually genuine blheli32? Or are they hardware clones of the ufofpv escs with different firmware?
Nov 10, 2017, 08:14 AM
What is landing :O
Yes they work fine. Been using them for a while. They're genuine and official and can be updated
Nov 23, 2017, 05:25 PM
This interesting, it is only $6,88 on GB right now, but hard to find info and review about this one.
Feb 24, 2018, 08:38 AM
Problems with these esc HAKRC 30A
Hi everyone,
I bought about a month ago, 4 of these esc HAKRC 30 A 32BIT ,(Bangood)
I had problems, solder tin to a FC Dys F4 pro V2 ,
I set the FC on Betaflight and everything is OK.
The problem was that when I try the engines and ESC from betaflight (motor EMAX 2306 -2400KW ) they work fine,
when instead (without propellers) the motors are active, the motors make a left and right shift continuously and become crazy.
I tried to change the PID on betaflight, change the settings on the esc, but I did not solve anything.
Here is a video of how the drone, ESC and engines behave :
HAKRC BLHeli32 Bit 30A 2-4S ESC Support Dshot1200 (0 min 24 sec)
I did another test: I welded these ESCs on other engines (emax 2205-2300 kw) and this problem does it again, plus it smells like burn....
Has anyone happened to such a problem?
Thank you and greetings.
Help! HAKRC Storm32 gimbal lost yaw motor after firmware upgrade Tachikoma Multirotor Drone Electronics 2 May 13, 2017 12:33 PM
Discussion HAKRC Storm32 3 Axis sloth711 Multirotor Drone Electronics 0 Apr 04, 2017 10:08 AM
Discussion Making a smartphone gimbal with Hakrc 3 axis goPro gimbal!! Problems...help required TheRCking Multirotor Drone Talk 0 Aug 26, 2016 01:45 AM
Discussion HAKRC STorM32 3 axis gimbal - control follow mode FabriceW Aerial Photography 2 Jun 28, 2016 03:32 PM
Discussion HAKRC STORM32 Gimbal Falgoriend Multirotor Drone Talk 1 Feb 11, 2016 03:17 PM
