Aurora 9x flaperon overdriving servos - RC Groups
Aug 06, 2017, 11:08 PM
So I have a dream-flight ahi and I set endpoint adjustments with my ailerons and I have no binding but I also have them setup as flaperons using the butterfly mix and no binding or issues. When I have flaperons deployed and I max ailerons the travel goes way beyond my EPA. How do I stop this from happening?
Aug 07, 2017, 02:18 PM
All Thumbs
Ranald's Avatar
T. Limit p.89?
Hi Miguel, Travel Limit?
" a. Select T.Limit in model menu.
b. Select the servo channel that you want to set up.
c. Locate the Trim in L position by moving the aileron stick all the way to left.
d. Input the value that you want by using + RST - icon.
e. Repeat the above steps to set other channels
f. When you are finished, click the Exit icon to return to the model menu. "
This it?
Aug 07, 2017, 02:21 PM
Ok I will look into it .... I must have been under the gross misunderstanding EPA was travel limit.
Aug 07, 2017, 02:31 PM
Thank you. For some reason my default programming in T. Limit was set to 150% . I reduced this value until it stopped overdriving the servos. Thanks for this tip!
Aug 07, 2017, 09:44 PM
All Thumbs
Ranald's Avatar
Some discussion about EPA and T.Limit
Question Aurora 9X - 'flaperon - spoileron' mix method? Ranald Hitec/Multiplex USA 16 Jul 08, 2017 10:58 PM
Discussion review aurora 9 vs aurora 9x griesel Radios 2 Apr 03, 2017 07:49 AM
Discussion Hitec 180 degree servo with Aurora 9x funkyfreestyler Hitec/Multiplex USA 10 Sep 28, 2016 10:41 AM
Discussion Aurora 9x, FrSky taranis, or Spektrum 9x dwp7715 Radios 16 Aug 02, 2014 05:22 PM
Discussion Hitec Aurora 9 & Aurora 9X Simulator Interface Function Set-up A.T. Hitec/Multiplex USA 6 May 31, 2011 09:53 PM
