improved cooling for Volantex 28 - RC Groups
Aug 06, 2017, 07:58 AM
This boat comes with "water-cooling" that is really just a joke.
The cooling consists of a bit of aluminium tubing about 4mm dia that has a flat side pressed against the motor can. The tubing leading to this bit is routed so it has a kink, and the outlet is a hole in the hull smaller than the od of the tubing; the outlet tube is squeezed through the hole on the hull - another constriction. I never saw water coming out - or even any in the outlet tube afterwards.
I cut a bit of copper sheet to fit the motor and soldered it to a bit of copper tube that was the same as the aluminium bit the boat came with. Motor has a connector, that's part of the rx/esc replacement being done)
The inlet tube is better routed under the servo instead of above it, where it gets pinched at the rear corner.
I made an outlet fitting with an id the same as the tubing and expoxied it throught the hull. If anyone copies this there is a trick to get the tubing to push over the inner end: pass something through the hole from the other end (I used a hex key) and have a short bit projecting inside. You use the projecting bit as a guide for the tubing, and you grab the tubing with a set of small pliers about 3mm away from that - and push.
The last pic shows why I think it will need better cooling. There's a little white bit of hdpe replacing the top part of the deck latch, and the fpv case is screwed onto that.
Aug 06, 2017, 12:43 PM
Just Plane Nutts
AirDOGGe's Avatar
That boat's cooling system is similar to that of the discontinued Steerix STX-9.
http://www.rcsoup.com/wp-content/upl...005-Large3.jpg
https://images-na.ssl-images-amazon....1j54tfF7UL.jpg
I eventually applied some thermal transfer compound between the tube and the motor housing to help get the heat out. It's worked well so far.
Discussion Vector 28 by Volantex ParadoxNZ Micro and Sub-Micro Boats 10 Aug 06, 2017 01:27 PM
Video Volantex V792-4 ATOMIC 2.4GHz, 2Ch, Brushless RC Boat, Water-Cooling system (+ FPV) hermit81 Racing Boats - Electric 2 Jul 22, 2017 06:59 AM
Video Volantex V797-3 (Vector SR48) 2.4GHz, 2Ch, Brushless RC Boat, Water-Cooling (+FPV) hermit81 Racing Boats - Electric 12 Jun 22, 2017 12:49 AM
Mini-Review Volantex CLAYMORE V795-2 2.4GHz, 2Ch, Mini RC Boat with water-cooling system (RTR) hermit81 Micro and Sub-Micro Boats 1 Jul 11, 2016 07:25 PM
Help! Volantex Vector 28 Binding Problems MCSULY Dock Talk 7 Feb 03, 2016 04:30 PM
