Santa Barbara - RC Groups
Aug 05, 2017, 01:44 PM
Santa Barbara
I have a Vortex ocean racer Santa Barbara in extremely good shape. I am looking to bring her up
to the current Gold Fleet standard, has a Servo City gearbox and a new suit of Sirus sails are on a
hook waiting to go on the rig. what other changes are needed?
Aug 05, 2017, 10:25 PM
tbarjohn's Avatar
you might want to post this on the Santa-Barbara-One-Design
John R.
Aug 06, 2017, 12:06 AM
Put in a backstay adjuster servo, one of the linear drive servos by actuonix would be perfect.
A jib twitcher is very helpful as well. The rig, a stiff CF mast section will take you far and help you hold more consistent sail shape. Ryan
Aug 06, 2017, 10:55 PM
thx for the information
Thanks for the information. I was thinking about using a 2 to one purchase
using a block and a linear actuator for the back stay and a jib trim servo. I never thought about
using a stiff carbon fiber mast. thanks again for the response.
Aug 07, 2017, 11:50 AM
If it floats....sail it!
FoamCrusher's Avatar
We are lucky to have the West Coast certified builder in our club - Dan and Bill Robinson of SB Yachts. Because of that we have had a huge resurgence in the SB class as they build new hulls. We had a SB only event (20 heats) this last Saturday and we had ten boats on the line. With the resurgence of the class has come the upgrade of existing hulls. There seems to be three levels of build in our club:
1. Winch and rudder only with analog servos. The most common winch is a ServoCity gearbox with an analog servo geared at 5:1, but a few are keeping their old Probar bang-bang set ups. No one is using the old Vortex target drone servo bang-bang. There are only a couple in our club that are this "bare bones".
2. Take the above and add a servo to tighten the backstay to dump mainsail pressure in gusts. Most of the boats in the club are using this level. I am about the only one using a stiff carbon mast - most are using the Ludwig aluminum masts.
3. Top level builds have digital winch and rudder servos that use the higher voltage Li-Po battery packs - again in the Servo City gear box, either with the 3.8:1 or 5:1 depending how fast you like to bring in the sails. The digital servos have way more "grunt" and are not necessary in Sacramento, but don't require heading up or reduced response in the afternoon hurricane when sailing in San Francisco during the summer.
Some at Level 3 add a jib tweaker. I think I am the only one who has added a second level of backstay that releases all of the backstay tension for going down wind. (This is from my dinghy racing experience where we had adjustable shroud levers that would do the same thing. ) I find it makes my boat just a bit faster than other boats on a dead downwind run. I have also added a full fuse block so all servos are protected. If a sheet jams those $$$$ digital servos go up in smoke unless protected...and don't get a finger between a winch line under load and anything hard or you will regret it!
Obviously, the more you have the more things there are to fail in a race and as the old auto racing adage says, "You cannot place unless you finish", so it is a trade off. Each of the levels adds more complexity and additional points of possible failure, but also adds increments of speed if properly used. At some point you also have to consider information overload as well.
Some of the Wheeler guys in the Bay Area in addition to ALL of the above have power vangs on both the main and jib. You have to be a fighter pilot to deal with all those controls.
Aug 07, 2017, 10:26 PM
thanks for the information. for right now I am just going to add the
backstay control and jib trim. I will take particular attention to the sheet line
system. I have several large Marblehead masts in stock but that can
be done later.
Aug 08, 2017, 02:04 PM
Midwest Model Yachting, LLC sells a nice SAILSetc 12.7mm Carbon Fiber Groovy mast that can be used for a Santa Barbara Rig.
Aug 10, 2017, 12:53 AM
I use the exact rig sailfish mentions and to great success, it is plenty stiff. Only issue is having a sail maker build you a sail with slugs in it to fit the groove. Ryan
Aug 10, 2017, 08:06 AM
If using the SAILSetc mast then use the medium crimps being help on with pieces of deck patch material. This is the way Graham Bantock makes his sails for his groovy masts. Midwest Model Yachting stocks these crimps..
Sep 11, 2017, 12:24 AM
SailingJunkie's Avatar
Vortex 1079
Just out of the paint shop, 1079 is getting wet sanded with 1000 grit... next, deck hardware and deck installation. Running out of time. Lol
NCR is only a few weeks away.
Sep 11, 2017, 07:44 AM
thats a beauty
that's a beauty Chuck, I am just finishing up mine as well missed the invitational
shake down sail on the Chesapeake Bay last week for the Santa Barbara's.
this NCR should be epic.
Sep 11, 2017, 05:54 PM
You going to be joining us Mike? The distance race is limited to 16 boats due to the # of chase boats available. I was the 16th boat to register so I guess I'm going down the river. Should be fun.
Sep 11, 2017, 09:20 PM
Last bit of wet sanding followed by a bit of hand buffing with finess it. For a very old boat, she is starting to come around.
Sep 11, 2017, 09:35 PM
wish I could chuck
I wish I could do the distance race I have seen it done with laser's and it a blast.
My heath precludes me from going on the water right now. but I will be there
for the rest of the chaos.
Sep 11, 2017, 11:35 PM
Kevin Gault
poltergeist's Avatar
Coming out beautifully S-J!
S/B #2004
Question Request for list of Santa Barbara slope and DS spots Matt Galland Slope 5 Sep 27, 2016 05:00 PM
Discussion Santa Barbara Vortex project....Help needed new2this1 Sailboats 6 May 25, 2016 03:56 PM
Discussion Santa Barbara Nationals 2016 Rssailor Sailboats 0 May 13, 2016 10:04 AM
Discussion Santa Barbara mystery lines new2this1 Sailboats 5 Dec 15, 2015 11:52 AM
Discussion Santa Barbara mystery lines new2this1 Sailboats 1 Dec 14, 2015 07:20 PM
