New canard build question - Page 2 - RC Groups
Aug 07, 2017, 03:18 PM
I Look, Listen, and Learn
Timbo383's Avatar
I had one similar to your design and it flew fine with no active canard. If you do decide to make them useful, I would then just use ailerons on the back....elevator up front AND rear would make for some interesting flights.
Aug 07, 2017, 06:30 PM
ninjasword71's Avatar
I'll just leave mine adjustable I think. Trying to get them to work good as an elevator would result in frustration and continuous parts cleanup. Timbo383, do you have a picture of yours?
Aug 07, 2017, 07:51 PM
Timbo383's Avatar
Don't know, I didn't start taking pics til later on when I really started to get into the builds. The pics and videos I do have are spread out between the computer, laptop and phone. But I'll look and see.
Aug 07, 2017, 08:09 PM
Timbo383's Avatar
Here's a simple and ugly way of doing a usable canard....did I already mentioned ugly, oh, yes I did...a piece of arrow shaft thru the fuse with a one size smaller diameter one glued to the canards inserted inside it and plastic bushings to keep it from binding. And, of course the servo mounted outside for ease of the build. This is just a test plane, so the looks are not currently too important. If it flys good the new one will have a full fuse to hide the servo inside.
Aug 07, 2017, 08:42 PM
Lol, I was brainstorming what the carbon rod will fit in nice. I remembered that I had a couple diabetic syringes. Was perfect length after I cut the tip and excess plastic.
Aug 07, 2017, 09:30 PM
Timbo383's Avatar
Oops, forgot the picture. Put it in previous post.
Aug 08, 2017, 02:44 AM
48" wingspan not 46"
This is what I got done so far. Really just putting in servos and a glide test left.
Aug 08, 2017, 07:18 AM
Timbo383's Avatar
Did you use the cg calculator? If you did, was it with the 46 or 48 inches there will be a slight difference in the cg. Pretty sure you know this , just wanted to remind you just in case.
Aug 08, 2017, 09:07 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
No verticals , or are you running split flaps ...
Aug 08, 2017, 11:08 AM
Yeah, without something for yaw stability, it will be a very short maiden flight...
Aug 08, 2017, 11:48 AM
There will be fins on all four wings for the vertical stab. Once the nose angle gets sorted out, I will probably tie it to a mild elevator while keeping elevons on main wings. I did the cg calculator and with motor mount and extra rear reinforcement, I was able to move battery forward a little which was needed for space.
Aug 08, 2017, 05:22 PM
gpw
gpw
gpw's Avatar
The fixed canard angle should be between 3 and 5 degrees … Just sayin’ …
And i don’t think you want verticals on the canard , that’s too much vertical area in front of the CG , which will make it unstable ...
Aug 08, 2017, 10:07 PM
I decided to hook up the canards for slight elevator movement. Static is about 3° and moves a few degrees each way. This way I can trim during flight. I have it with full movement off the rudder channel and minor movement mixed in elevator. Sorry, my work spot is very messy as I do model cars and other projects on it.
Aug 09, 2017, 05:13 AM
gpw
gpw
gpw's Avatar
NS, Great idea !!!
Aug 10, 2017, 09:02 PM
Ready to crash tomorrow wind permitting. The full canard is an elevator set initially at 3° and ailerons on the main wings.
Discussion 100g very easy to build Canard Delta Gregco10 Foamies (Scratchbuilt) 6 Jun 29, 2016 01:28 PM
Discussion 100g very easy to build Canard Delta Gregco10 Pusher Prop Jet Models 0 Jun 28, 2016 09:13 PM
Question New Alien 560 build motors and weight question aelectrician Multirotor Drone Power Systems 6 Dec 09, 2015 11:39 AM
Discussion New here, and new to building my own, equipment questions kenjancef Multirotor Drone Electronics 6 Nov 17, 2015 09:20 PM
Discussion Of canards and pusher props... (new Barracuda canard prototype) Rusty-Gunn Foamies (Scratchbuilt) 30 Mar 02, 2008 10:23 AM
