FrSky S6R will not go in bind mode - RC Groups
Aug 05, 2017, 08:09 AM
dIggO's Avatar
Question
Hello all!
My S6R gives me a solid green light when powered on with the failsafe button pressed. When just powered a blinking red light.
I'm not able to bind this thing...
I have a Taranis with international firmware, although I live in Europe. I flashed the receiver several times (international version), but I don't know if that was what it needed. Also I don't get the simultanious red and green as in wrong match. I don't come that far because i don't get in bind mode with it...
Anybody who can help please?
Thanks in advance!!
Richard
Aug 05, 2017, 09:00 AM
Sagitta Fanboy
Make sure you're using a fully charged pack when binding. I've had issues binding with low pack voltages
Aug 06, 2017, 07:41 AM
dIggO's Avatar
I did to no avail...
Thanks for the suggestion though!
Richard
Aug 24, 2017, 01:51 PM
I bought a S6R with international firmware but I have an early Taranis X9D with the DH16V2 RF board and LBT firmware loaded. I tried flashing all the available EU-LBT firmwares but I was unable to bind with any off them.
I tried binding the S6R to a friend's LBT X9D-Plus and it bound instantly. So the S6R was OK.
I had S6R FW170217 (S6R_LBT_20170217.frk) loaded but it would not bind to the X9D.
The I remembered that I read somewhere that there is a bug and it will only bind to even numbered receivers. I changed the receiver number from 3 to 8 and to my surprise it bound instantly.
I hope this helps.
Aug 29, 2017, 05:37 AM
dIggO's Avatar
I hope this helps.
Hey Crash_Harry,
Thanks for your answer! I have a question for you: When you bring the S6R in binding mode, does the led flash red(and a constant green led)?
Because I have only the constant green LED...
This is the procedure I follow: Keep the faisafe button pressed while power on the receiver. Then the LED is just constant green... When I just power it on I get a red flashing LED...
How do you change the receiver number?
Thanks in advance!
Richard
Nov 03, 2017, 12:01 PM
Hi. I'm experiencing the same behavior (solid green led) when trying to bind. Were you able to fix it?
Dec 03, 2017, 05:05 PM
This thread is a bit old, but still seems valid.
Like so many things Frsky, binding seems to work properly, but somehow is totally confusing. If you put the transmitter in bind mode, THEN put the receiver in bind mode, then unplug the power from the reciver, turn off bind mode on the transmitter, (you can leave the transmitter on, just get out of bind mode), and then turn the receiver back on again, it seems to work fine. This is what Frsky actually tells us to do.
Things that might confuse this-
-Receiver light is steady green much of the time, this in not in the instructions as a valid mode. (at least for the S6R)
-If you try to put the receiver in bind mode with the transmitter off, you get a steady green light with the S6R. However, the receiver is actually in bind mode at this time. If you put the transmitter in bind mode, the lights change to the proper ones. (green on, red flashing) Complete the bind procedure and all is well.
-I have a suspicion that if a receiver has never been bound, then one migtht get the proper green and flashing red lights when powering up the receiver without a transmitter on. But this needs to be tested. Maybe a firmware install on the receiver would create this condition. As I said, I'm not sure, but I swear it happened once.
Jan 08, 2018, 11:46 AM
Hello. I would like to ask how you solved the problem with paring and solid green color.
Thanks...
P.
Discussion Frsky XM+ will not bind if RSSI pad used? mactac FPV Equipment 2 Apr 28, 2017 10:21 AM
Discussion Flysky FS-iA6B will not enter into binding mode bleede Multirotor Drone Electronics 1 Dec 27, 2016 11:26 AM
Help! Blade Nano CPS will not bind in 'stability mode' mxlothar Beginner Training Area (Heli-Electric) 6 Jul 11, 2016 10:40 PM
Question FrSky DJT Module Wont go Into Binding Mode in 9XR MarylandFly Multirotor Drone Talk 1 Aug 11, 2014 07:55 PM
Discussion FrSky Binding Problem - RX wont go into bind mode squishio2 Radios 6 May 11, 2014 10:26 AM
